Bascom-51 & Windows-7. Problems...
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
Alexander-Dan
PostPosted: Fri Feb 26, 2016 9:02 am    Post subject: Bascom-51 & Windows-7. Problems... Reply with quote
Hi all Bascom-51 users!
I wanted to install the program in windows-7. Installation completed successfully.
But after the start I see an error message "Class not registered"
I tried to run a program with administrator permissions, change will solve the compatibility of the file properties.
But the problem is not corrected.
Maybe someone has information that can help me?
thanks in advance, Alexander
PostPosted: Fri Feb 26, 2016 10:11 pm    Post subject: Reply with quote
this is a case of wrong installation.
- install with admin rights
- reboot
- run the first time with admin rights
that should solve it. if not, let me know.
Alexander-Dan
PostPosted: Sat Feb 27, 2016 6:22 am    Post subject: Reply with quote
Yes, I did just that.
after the error of program I closed the window with the text of the error.
But program remains in memory and require a lot of CPU power. Computer freezes
PostPosted: Sat Feb 27, 2016 10:49 am    Post subject: Reply with quote
which version do you try to install?
Alexander-Dan
PostPosted: Sat Feb 27, 2016 12:52 pm    Post subject: Reply with quote
http://www.mcselec.com/index.php?option=com_docman&task=doc_download&gid=166&Itemid=54
2.0.14.0
PostPosted: Mon Feb 29, 2016 9:55 pm    Post subject: Reply with quote
When you have a full version i recommend to use the latest. if you use the demo, you can try this :
- Make a DOS/Command window with ADMIN rights
- CD to the Bascom application dir that you selected ie c:\program files\mcs electronics\bascom-8051
- type : REGSVR32 MFC42.DLL
You should receive a message that it registered ok.
- type : REGSVR32 MHCOMM32.OCX
now this OLE error should be gone.
Alexander-Dan
PostPosted: Tue Mar 01, 2016 4:28 am    Post subject: Reply with quote
REGSVR32 MFC42.DLL >> OK
REGSVR32 MHCOMM32.OCX >> Error!
module MHCOMM32.OCX is loaded, but could not make a call DllRegisterServer, error code: 0x80040201
I reboot the computer in Administrator mode and see the message:
Alexander-Dan
PostPosted: Tue Mar 01, 2016 4:32 am    Post subject: Reply with quote
O!!!
I found a solution to this problem in a network: i performed registration of some files manually. Thanks for the help!
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
