Help _ simple examble for RX UART data
Goto page 1, 2  Next
MIKRO_MAN
PostPosted: Thu Jan 28, 2016 3:11 am    Post subject: Help _ simple examble for RX UART data Reply with quote
i have simple example for rx data (uart)
when i rx one chr like A OR B OR ANY NUMBER 1,2,3.....9 code is working
but when i rx statement code not work
problem _ the code not work what is the worng ?
$regfile = "m8def.dat"
$crystal = 4000000
Dim Value As Byte
Config Portb.0 = Input
Config Portb.1 = Output
Portb.1 = 0
Portb.0 = 1
Open "comd.6:9600,8,n,1" For Output As #6
Open "comd.7:9600,8,n,1" For Input As #5
'tx value
Value = Inkey(#5)
A = Inkey()
If Value > 0 Then
If Value = "AAAA" Then Toggle Portb.1
i.dobson
PostPosted: Thu Jan 28, 2016 9:20 am    Post subject: Reply with quote
Hello,
If I understand you correctly:
inkey does that, it returns 1 key press (character) from the serial port (not a string of characters.)
You have defined "value" as a byte which can only hold 1 character.
Have a look at the input command (which returns a string), or you need to use inkey in a loop grabbing the individual characters from the serial port and adding then to a string.
Regards
Ian Dobson
Paulvk
PostPosted: Thu Jan 28, 2016 12:27 pm    Post subject: Reply with quote
The way I do this is..
You see we get a character from the buffer
look at it
decide what it is maybe end of command
or add it to the string
Regards Paul
Portb.1 = 0
Portb.0 = 1
Dim Uart_command as string * 20  "room for 20 characters
Dim Rs232 as string * 1
   If Ischarwaiting(#5) = 1 Then
      Rs232 = Inkey(#5)                                       'get a character from the buffer
      If Rs232 = 13 Or Len(uart_command) > 19 Then         'uart_command full or enter key sent
             Delchars Uart_command ,(13)
              if Uart_command ="
AAA" then
                      Toggle Portb.1
             Uart_command = "
      ' we can use this Exit Do to continue to the next part of our program
        ' Exit Do
      Else
         Uart_command = Uart_command + Chr(rs232)           'add the character to the uart_command buffer
PostPosted: Thu Jan 28, 2016 4:01 pm    Post subject: Reply with quote
paul,
in the help :
IsCharWaiting can NOT be used with a software uart (SW-UART). This because a SW-UART does not buffer the data is receives or sends.
it seems Mikro_man use a M8, afaik M8 as only one Hw -uart DO D1
if he wants more HW-UART he needs to use a bigger one as M2560
Wink
jp
MIKRO_MAN
PostPosted: Fri Jan 29, 2016 5:36 pm    Post subject: Reply with quote
Duval JP wrote:
paul,
in the help :
Wink
jp
i cant understand what is M8 & M2560
PostPosted: Fri Jan 29, 2016 7:11 pm    Post subject: Reply with quote
$crystal = 4000000
M8 means atmega 8
M2560 means ATMEGA 2560
Arduino use ATMEGA328 or ATMEGA2560 for the arduino usable with BASCOM
Wink
jp
MIKRO_MAN
PostPosted: Fri Jan 29, 2016 7:39 pm    Post subject: Reply with quote
$crystal = 4000000
M8 means atmega 8
Wink
jp
Ok Thank
i need to know how can i update my code to RX [AAAA] or any statement [string]
by using arduino atmega328p
$regfile = "m328p.dat"
$crystal = 16000000
Dim Value As Byte
Portb.1 = 0
Portb.0 = 1
'tx value
Value = Inkey(#5)
A = Inkey()
If Value > 0 Then
bzijlstra
Bascom Ambassador
PostPosted: Sat Jan 30, 2016 7:59 am    Post subject: Check Weatherstation source Reply with quote
In this forum check Bascom Project Blog, and get the source code of the weatherstation. In it a routine for the Arduino Mega with just what you want. Below the inkey part. There is checked on all kind of keywords like "temperature=" and "humidity=".
Must do the trick..
Have fun
Ben Zijlstra
MIKRO_MAN
PostPosted: Mon Feb 01, 2016 3:35 am    Post subject: Re: Check Weatherstation source Reply with quote
Must do the trick..
Have fun
Ben Zijlstra
i find weatherstation
but i cant understand how can i rx string to uart
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13038
MIKRO_MAN
PostPosted: Mon Feb 01, 2016 3:37 am    Post subject: Re: Check Weatherstation source Reply with quote
Must do the trick..
Have fun
Ben Zijlstra
bzijlstra
Bascom Ambassador
PostPosted: Mon Feb 01, 2016 8:07 am    Post subject: Byte and string Reply with quote
What I don't understand is how you Dim value as byte and later on check if value = "AAA" A byte is a value of 0 - 255. What you need is a string to hold the characters.
You first have to grab all incoming characters in a string and check the string for "AAA"
In the weatherstation that is done. Inkey to check for a character, add it to a string and with instr a check is done if some keywords are in the string.
You are nearly there...
Have fun
Ben Zijlstra
MIKRO_MAN
PostPosted: Fri Feb 12, 2016 7:41 am    Post subject: Re: Byte and string Reply with quote
Have fun
Ben Zijlstra
atmega8 _ 1
$crystal = 4000000
Dim Value As String*6
Portb.1 = 0
Portb.0 = 1
Value = Inkey(#5)
If Value > 0 Then
If Value = "AA" Then Toggle Portb.1
'recived value
If Pinb.0 = 0 Then
Print #6 , "AA"
Waitms 100
atmega8 _2
$crystal = 4000000
'Ucsrb = 0
Portb.1 = 0
Portb.0 = 1
Open "comd.6:9600,8,n,1" For Output As #5
Open "comd.7:9600,8,n,1" For Input As #6
Value = Inkey(#6)
If Value > 0 Then
'recived value
If Pinb.0 = 0 Then
Print #5 , "AA"
Waitms 100
the circuit and code NOT WORKING ???
i hope to update this code to working
PostPosted: Fri Feb 12, 2016 11:38 am    Post subject: Reply with quote
- I'm sorry but I don't understand why you don't use PD.O and PD1 the hard serial pin for your communication.? on your schematic they are free...
- sometimes serial communications are difficult to adjust because following the sentence you print you have CR+LF
see the help :
You can use a semicolon ( ; ) to print multiple variables or constants after each other.
so
while never right be cause, in fact you send AA+CR+LF
- split you program in small parts, then try them, use simulator, it works well
JP Wink
MIKRO_MAN
PostPosted: Fri Feb 12, 2016 12:13 pm    Post subject: Reply with quote
see the help :
so
JP Wink
ok i already use PD0 PD1 in another project _ this circuit for explanation simply what I want
i cant understand [ in fact you send AA+CR+LF ]
bzijlstra
Bascom Ambassador
PostPosted: Fri Feb 12, 2016 12:22 pm    Post subject: 1 or 4 Mhz Reply with quote
From the factory the ATmega8 comes with its CKSEL fuses programmed for 1 Mhz.
What about your fusebit settings?
You got an atmega8 and a LED. Is it possible to write a small program to just blink the LED at an interval of 1 second?
And if you Print "AA" you are sending AA+CR+LF
If you just want to send "AA" you do a Print "AA";
Ben Zijlstra
Goto page 1, 2  Next
Page 1 of 2
