harrydejonge
Posted: Wed Feb 10, 2016 5:55 pm Post subject: |
Did you disconnect the ISP programmer. ??
It use com1 also. |
Posted: Thu Feb 11, 2016 11:49 pm Post subject: |
I think at this stage I would be sending just one repeated character, while looking at the signal line with a CRO to see what pattern is actually being sent. But I must admit that its odd that it seems to work ok in upper case but not lower. The difference is only that bit 5 is set to send lower case.
Maybe a look also with some terminal program like Realterm, which allows to display the Hex code of what is received would show up what is wrong. The characters you quote seem to indicate that bit 7 is being set, but that may just be a terminal trying to interpret garbage. _________________ Adrian Jansen
protoncek
Posted: Tue Feb 16, 2016 7:24 am Post subject: |
Hi!
nothing has been said about what program is used as terminal on PC side? I've had problems with bray terminal, who CAN corrupt characters for no reason, so i rarely use it. Funny thing is that when i used it on xmega128 @46MHz it corrupted data at 9600 baud, but worked perfect at 256000
So, maybe changing terminal program is a start... |
Posted: Tue Feb 16, 2016 8:01 am Post subject: |
Since I happened to be playing with serial comms on another project, I ran this:
$regfile = "m644pdef.dat"
$crystal = 3686400 'clock speed
$hwstack = 130
$swstack = 50
$framesize = 80
Config Clockdiv = 1
$baud1 = 9600
Config Com2 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Serialin1 = Buffered , Size = 250
Config Serialout1 = Buffered , Size = 250
open "com2:" for binary as #1
Print #1, "mworld.be"
waitms 100
Yes its a different processor, clock speed, serial port, etc
Result on Teraterm was "mworld.be" for as long as I let it run, about 10 mins. No errors.
Seems to me its a hardware problem.
By the way, and totally unrelated, its very rarely necessary to buffer serial output, and it takes out yet one more point at which something can fail. Especially when testing and trying to track down some obscure fault. _________________ Adrian Jansen
