Posted: Sun Jan 24, 2016 11:05 am Post subject: Bluetooth HC05 Bootloader.
Hello
I'm working on making a wireless bootloader. I've been hanging on a Attiny45 on a HC05 listening and when they hear 123 so resettar the processor to be programmed and it works. Now for my question I detect the beginning but how I detect the end of the programming broadcast MCH something or they are someone that something advice. You can use the bootloader as to put low on PB.3 when the boot sequence is complete but I do not. I do not want to use more pins than needed.
Thanks in advance Maxneo
The code i use
$regfile = "attiny45.dat"
$prog &HFF , &HD2 , &HDC , &HFF
$hwstack = 64
$swstack = 64
$framesize = 64
Dim Bstatus As Byte
Dim Bretries As Byte
Const On = 1
Const Off = 0
'Ddrb = &B00011001
Led Alias Portb.4 'fungerar inte
Res Alias Portb.3
Ok Alias Pinb.2
Config Pinb.2 = Input
Config Led = Output
Config Res = Output
Config Ok = Input
Res = On 'set Res
Led = Off 'Reset Led
Ok = On
Open "comb.1:38400,8,n,1" For Input As #2
'Open "comb.0:38400,8,n,1" For Output As #1
Bretries = 10
Bstatus = Waitkey(#2) '{ did we received value 123 ?
If Bstatus = 123 Then
Led = On 'Set Led
Res = Off 'Reset Res
Waitms 5
Res = On
nop
