mototest2
Posted: Sat Dec 05, 2015 11:45 am Post subject: xmega how redirect PWM to PortB |
Hi guys
Plese help me how I can redirect for example timer Tce1 (pwm) to portb.3 ?
or other suggestion for achieve pwm on portb.3 ?
Config Tce1 = Pwm_topbot , Prescale = 256 , Comparea = Enabled , Compareb = Enabled , Comparec = Enabled , Compared = Enabled , Resolution = 8
Bob
Posted: Sat Dec 05, 2015 6:12 pm Post subject: Re: xmega how redirect PWM to PortB |
mototest2 wrote: | or other suggestion for achieve pwm on portb.3 ? |
A piece of wire and a soldering iron.
Or soft-PWM.
Quote: | xmega how redirect PWM to PortB |
Ahh, yes, THIS xmega. Sure, Atmel did create only one model... |
Posted: Tue Dec 08, 2015 10:20 pm Post subject: |
some new xmega have the REMAP register which can remap pins (on the same port)
but not from one pin to another port.
what about using the event system? you can have an event for the timer or the port pins and replicate the state. _________________ Mark |
mototest2
Posted: Tue Dec 08, 2015 10:28 pm Post subject: |
I don't know how use event system to generating PWM on portB |
Posted: Wed Dec 09, 2015 11:18 am Post subject: |
the idea is to generate it on the normal pins, then use the even system to replicate the pin state on any other port pin.
maybe you know the pcint of the normal avr ? it can react on a pin change. like :
pcint_change:
'pin has changed so duplicate it on another pin
portb.0 = portE.2 ' just for example
return
check the data sheet and the even system samples. _________________ Mark |
Meister
Posted: Wed Dec 09, 2015 8:20 pm Post subject: |
To be more specific ...., you might wish to have a look at this:
http://bascomforum.de/
Regards, Meister |
