twi and i2c, LCD and twi clock.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive
zolsi
PostPosted: Tue Mar 14, 2006 12:25 pm    Post subject: twi and i2c, LCD and twi clock. Reply with quote
Hi all
When you use a easy tcp/ip board twi(i2c like), can you use 2 i2c sensor on the same bus (with right pull up resistor..)?
Other question :
when i set the clock of the twi tcp/ip board, i cant use a lcd ( it shows strange characters).
If i use the tcp/ip init comand : Config Tcpip = Int0 , Mac = 12.128.12.34.56.78 , Ip = 192.168.0.8 , Submask = 255.255.255.0 , Gateway = 0.0.0.0 , Localport = 1000 , Tx = $55 , Rx = $55
The lcd work! but if add the 2 commands to use the tcp/ip board in twi mode, Twi and especially clock ( Twi = &H80 , Clock = 400000 ) the lcd start to display strange caracters.
Any idea ?
Thank you for help
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive All times are GMT + 1 Hour
