gilson163
Posted: Sat Nov 14, 2015 1:20 pm Post subject: m64def.dat or m64m1.dat |
I'm developing a project using ATMEGA64L-8MU (QFN 64) and BASCOM I have to use '$regfile = "m64def.dat" to build the softare and not give error. If use "$regfile = "m64m1.dat" of the following error # 41. Would anyone can help me or explain me why this error? Or why can not I use the "m64m1.dat"? Here below file for analysis
Thank you.
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.7.8 ) |
_kaktus_
Posted: Sat Nov 14, 2015 1:42 pm Post subject: |
You tried on an earlier version of Bascom? |
Posted: Sun Nov 15, 2015 9:19 am Post subject: |
Looks as if the m64m1.dat is missing the port definitions for porta/data direction Register A.
In the IO section of the dat file I see
PORTE = $0E
DDRE = $0D
PINE = $0C
PORTD = $0B
DDRD = $0A
PIND = $09
PORTC = $08
DDRC = $07 ; New
PINC = $06 ; New
PORTB = $05
DDRB = $04
PINB = $03
This is in Bascom Version 2.0.7.9
If you find the correct addresses for PortA, PinA and DDRA and add them to the data file the code should work.
Posted: Mon Nov 16, 2015 10:50 am Post subject: |
you can not simply add them. they are not missing : this PORTA does not exist in the mega64M1.
Have a look in the datasheet and the pinout. you will not find any pin named with PA. At least, i did not find any.
That a chip has a similar name does not mean much. you can upgrade from 16M1 to 32M1 to 64M1 without problems, but you can not from a normal mega64 to an M. _________________ Mark |
Posted: Mon Nov 16, 2015 6:25 pm Post subject: |
Oh, OK I've learnt something new. I always thought that AVR's started with PortA.
gilson163
Posted: Mon Nov 16, 2015 9:50 pm Post subject: |
I did not understand completely . How then do detail to cancel this error in BASCOM compiler ? |
Posted: Mon Nov 16, 2015 10:00 pm Post subject: |
it is not a problem of the compiler.
you try to access hardware (a PORTA) that does NOT exist for that chip !
- please check the PDF of the used processor
- lookup PORTA
- you will see it does not exist _________________ Mark |
gilson163
Posted: Mon Nov 16, 2015 10:20 pm Post subject: |
so if I use $regfile(m64def.dat) for atmega64L-8mU (QFN64) will have no problem. I develop the software with this? All functions work normally? |
Posted: Mon Nov 16, 2015 10:28 pm Post subject: |
if your processor is atmega64L, then yes, that would be the proper thing to do.
but if your processor is atmega64M1, it will not work when using portA. _________________ Mark |
gilson163
Posted: Mon Nov 16, 2015 11:23 pm Post subject: |
I understand, thank you for the explanation. |
