hgrueneis
Joined: 04 Apr 2009 Posts: 902 Location: A-4786 Brunnenthal
Posted: Thu Sep 24, 2015 8:08 pm Post subject: LOAD value in HELP |
The Load value in Help is not supposed to be calculated from 256 but 255 for 8-bit Timers.
"Load Timer0, 10", will load the timer with a value of 245.
Respectively for 16-bit, not from 65536 but 65535.
Count position and count value differ by 1.
Not a big deal but it can have a big effect.
Best regards
Hubert
Quote of text in LOAD HELP:
The TIMER0 does not have a reload mode. But when you want the timer to generate an interrupt after 10 ticks for example, you can use the LOAD statement.
It will do the calculation : (256-value)
So LOAD TIMER0, 10 will load the TIMER0 with a value of 246 so that it will overflow after 10 ticks.
TIMER1 is a 16 bit counter so it will be loaded with the value of 65536-value. |
Posted: Thu Sep 24, 2015 8:24 pm Post subject: |
i do not understand what you mean.
from the help and my understanding of timers :
Quote: | The counting direction is always up (incrementing), and no counter clear is performed. The counter simply
overruns when it passes its maximum 8-bit value (MAX = 0xFF) and then restarts from the bottom (0x00).
In normal operation the Timer/Counter Overflow Flag (TOV0) will be set in the same timer clock cycle as
the TCNT0 becomes zero. |
this means that the overflow occurs when timer goes from 255 to 0.
when you load 246 in the timer we get after 10 ticks an overflow.
i have glared at code all day so i could be missing something. please point out what it is i am missing. _________________ Mark |
hgrueneis
Posted: Thu Sep 24, 2015 11:54 pm Post subject: |
Yes, I know.
Maybe I did not express myself the right way.
The fact is, that there is no value of 256 in an 8-bit system,
other than an overflow that would again represent 0.
The overflow occurs to 0 from 255 Value (the 256th counter state with value 255).
There is no 256 which would be H100 or B1_0000_0000 and therefore 9-bit,
overflow without an additional complete clock cycle to go to 0.
After value 255 it goes directly to B0000_0000.
At least that is my view of the matter.
Best regards
Hubert |
Posted: Fri Sep 25, 2015 3:21 pm Post subject: |
yes i know all that
but this is what i wrote ;
it will do the calculation : (256-value)
To make it simpler here is a value for 1 : 256-1=255.
So when i want the timer to overflow after one tick, i need to load 255. with one clock , the timer overflows to 0 causing the interrupt flag to be set.
I hope it is clear now. _________________ Mark |
