MIKRO_MAN
Posted: Tue Sep 15, 2015 11:04 pm Post subject: i need simple experiment arduino+hc05 |
i need simple experiment connect arduino + hc05 to led on/off
pin connection
i need just simple bascom code ?
Printpix52
Posted: Wed Sep 16, 2015 12:12 am Post subject: |
Code: | Do
'>[Turn Led1 on ]
Set Led1 : Waitms 500
'>[Turn Led1 off ]
Reset Led1 : Waitms 500
End |
MIKRO_MAN
Posted: Wed Sep 16, 2015 12:47 am Post subject: |
Printpix52 wrote: | Code: | Do
'>[Turn Led1 on ]
'>[Turn Led1 off ]
End |
thanks for help
but i wont full code --> config pins and serial received & send ?? |
MIKRO_MAN
Posted: Wed Sep 16, 2015 9:26 pm Post subject: |
i find this code [lcd+hc05]
i need to comments to explained how to tx and rx hc05
Code: |
$lib "LCD-pcf8833BR2.LBX"
$regfile = "m8def.dat"
$crystal = 11059200
Config Graphlcd = Color , Controlport = Portb , Cs = 3 , Rs = 0 , Scl = 2 , Sda = 1
Const Blue = &B00000011
Const Yellow = &B11111100
Const Red = &B11100000
Const Green = &B00011100
Const Black = &B00000000
Const White = &B11111111
Const Brightgreen = &B00111110
Const Darkgreen = &B00010100
Const Darkred = &B10100000
Const Darkblue = &B00000010
Const Brightblue = &B00011111
Const Orange = &B11111000
'lcdat y,x (satr bayad 10 ta 10 ta ziad shavad, pixel ra mibinad na satr)
Ddrb.5 = 1 ' pb.5 = out
Portb.5 = 0
Open "comb.4:38400,8,n,1" For Input As #1
Dim A As Byte
Dim Ch As String * 1
Cls
Setfont Color8x8
Lcdat 0 , 0 , "Ready..." , Black , White
A = Inkey(#1)
If A > 0 Then
Ch = Chr(a)
Lcdat 10 , 0 , Ch
If Lcase(ch) = "a" Then Portb.5 = 0
If Lcase(ch) = "b" Then Portb.5 = 1
$include "color8x8.font"
'end of file
what is function of code
Code: |
Posted: Thu Sep 17, 2015 5:22 pm Post subject: |
hello,
see the help for "open"
"So that is why the OPEN statement must be used. It tells the compiler about the pin you use for the serial input or output and the baud rate you want to use.
COMB.0:9600,8,N,2 will use PORT B.0 at 9600 baud with 2 stop bits."
JP |
MIKRO_MAN
Posted: Thu Sep 17, 2015 5:46 pm Post subject: |
Duval JP wrote: | hello,
JP |
thanks a lot
i need to connect hc05 to arduino i search in forum not find simple tutorial ?? |
MIKRO_MAN
Posted: Fri Sep 18, 2015 1:33 pm Post subject: |
i find simple code and working good
but i need to update code to send data from arduino to hc05 to android app
Code: |
$programmer = 23
$regfile = "m328pdef.dat"
$crystal = 16000000
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 9600
Dim A As String * 2
Dim B As Word
Config Portb.5 = Output
If Ischarwaiting() = 1 Then
A = Inkey()
If A = "A" Then
Portb.5 = 1
If A = "B" Then
Portb.5 = 0
bzijlstra
Posted: Fri Sep 18, 2015 2:36 pm Post subject: Search for Android2Arduino |
Do a search on Android2Arduino in this forum.
On the Arduino side a Bascom-Avr program
On the Android side a Basic4Android program
Connection between both platforms with a OTG USB connection.
It can be done...
Have fun
Ben Zijlstra |
MIKRO_MAN
Posted: Fri Sep 18, 2015 10:43 pm Post subject: Re: Search for Android2Arduino |
bzijlstra wrote: | Do a search on Android2Arduino in this forum.
It can be done...
Have fun
Ben Zijlstra |
Code: |
$regfile = "m2560def.dat"
$crystal = 16000000
$hwstack = 64
$swstack = 64
$framesize = 64
$baud = 9600
Open "Com1:" For Binary As #1
Dim A As Byte , S As String * 2
A = Ischarwaiting(#1)
If A = 1 Then 'we got something
A = Waitkey(#1)
Select Case A
Case 49 : Print #1 , "A";
Case 50 : Print #1 , "B";
Case 51 : Print #1 , "C";
Case 52 : Print #1 , "D";
End Select
Code: | Open "Com1:" For Binary As #1 |
i wont to ask about this code
1- this code to make any pin tx or rx ?
i understand that from help index Code: | COMB.0:9600,8,N,2 will use PORT B.0 at 9600 baud with 2 stop bits. |
Code: | Dim A As Byte , S As String * 2 |
2- why s string * 2
Code: | Case 49 : Print #1 , "A"; |
this code will send tx binary value for what ??
i wont to correct for above commends about code
thanks for helping |
bzijlstra
Posted: Fri Sep 18, 2015 11:40 pm Post subject: Some info |
Oke. No problem.
With opening the COM1 the hardware UART is used.
With opening b.0 a software UART is created.
Perhaps you can check the help for the difference between a hardware and a software UART.
With a software UART check the help for the tx and rx pin.
While checking the help have a look at the ASCII chart. 49 is the ASCII value for 1. So the Android app is sending a 1, 2, 3 and 4 for the four buttons in the app. And the Arduino is printing A, B, C and D.
The communication port that was opened got a number, in this case #1. When we want to send someting to this port we can use print #1. There are microcontrollers with more then 1 hardware UART.
And about the DIM of S as string, I see this variabele is not used anymore so the DIM for S can be deleted.
About non-used variables: when you do a compile you can check in the report of the compile if there are variables dimmed that are not used.
Oke, have fun
Ben Zijlstra |
MIKRO_MAN
Posted: Sat Sep 19, 2015 1:32 am Post subject: Re: Some info |
bzijlstra wrote: | Oke. No problem.
Oke, have fun
Ben Zijlstra |
thank you for helping
i will more search [difference between a hardware and a software UART]
and how to make any pin rx or tx
final the simple ex- rx and tx between phone && arduino
Code: |
$programmer = 23
$crystal = 16000000
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 9600
Dim A As String * 2
Dim B As Word
A = Inkey()
If A = "A" Then
Portb.5 = 1
Print "led on" //send data to phone
If A = "B" Then
Portb.5 = 0
Print "led off" //send data to phone
i used this code
Code: | Dim A As String * 2 |
but i cant understand why product A * 2 |
bzijlstra
Posted: Sat Sep 19, 2015 3:00 am Post subject: Hold text in string |
A string is used to hold text
In this case it holds the incoming character and can hold 2 characters.
Read the Bascom language fundamentals.
The dim a as string * 2 reserves two bytes in ram named A and can hold 2 characters.
Have fun
Ben Zijlstra |
