' Config_MMCSD_HC.BAS
' Config File for MMC/SD/SDHC Flash Cards Driver
' (c) 2003-2012 , MCS Electronics / Vögel Franz Josef
' Place MMCSD_HC.LIB in the LIB-Path of BASCOM-AVR installation
'Connection as following for XMEGA the MMC is connected to PORTC
'MMC M128/M103
'1 MMC_CS PORTB.0
'2 MOSI PORTB.2
'3 GND
'4 +3.3V
'5 CLOCK PORTB.1
'6 GND
'7 MISO, PORTB.3
' you can vary MMC_CS on HW-SPI and all pins on SOFT-SPI, check settings
' ========== Start of user definable range =====================================
' you can use HW-SPI of the AVR (recommended) or a driver build in Soft-SPI, if
' the HW-SPI of the AVR is occupied by an other SPI-Device with different settings
' Declare here you SPI-Mode
' using HW-SPI: cMMC_Soft = 0
' not using HW_SPI: cMMC_Soft = 1
Const Cmmc_soft = 0
#if Cmmc_soft = 0
' --------- Start of Section for HW-SPI ----------------------------------------
'FOR XMEGA DEVICES
#if _xmega = 1
Portc_pin6ctrl = &B00_011_000 ' MISO pin pull up
Config Pinc.4 = Output ' define here Pin for CS of MMC/SD Card
Mmc_cs Alias Portc.4
Set Mmc_cs
' Define here SS Pin of HW-SPI of the CPU (f.e. Pinb.0 on M128)
Spi_ss Alias Portc.4
'SPI Configuration for XMEGA
'The MMC-XMEGA.LIB expect SPIC
'If you want to use SPID, SPIE or SPIF you NEED TO CHANGE THE MMC-XMEGA.LIB
'It is documented in MMC-XMEGA.LIB where you need to change the Library
Config Spic = Hard , Master = Yes , Mode = 0 , Clockdiv = Clk2 , Data_order = Msb
Open "SPIC" For Binary As #14
Const _mmc_spi = Spic_ctrl
#else
' define Chip-Select Pin
Config Pinb.0 = Output ' define here Pin for CS of MMC/SD Card
Mmc_cs Alias Portb.0
Set Mmc_cs
Config Pinb.0 = Output ' define here Pin of SPI SS
Spi_ss Alias Portb.0
Set Spi_ss ' Set SPI-SS to Output and High for Proper work of
Portb.3 = 1 'pull up on miso
' HW-SPI is configured to highest Speed
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
' Spsr = 1 ' Double speed on ATMega128
Spiinit
#endif
' --------- End of Section for HW-SPI ------------------------------------------
#else ' Config here SPI pins, if not using HW SPI
' --------- Start of Section for Soft-SPI --------------------------------------
#if _xmega
' Chip Select Pin => Pin 1 of MMC/SD
Set Mmc_cs
' MOSI - Pin => Pin 2 of MMC/SD
Config Pinc.5 = Output
Set Pinc.5
Mmc_portmosi Alias Portc
Bmmc_mosi Alias 5
' MISO - Pin => Pin 7 of MMC/SD
Config Pinc.6 = Input
Mmc_portmiso Alias Pinc
Bmmc_miso Alias 6
Portc_pin6ctrl = &B00_011_000 ' pull up
' SCK - Pin => Pin 1 of MMC/SD
Config Pinc.7 = Output
Set Portc.7
Mmc_portsck Alias Portc
Bmmc_sck Alias 7
#else
Set Mmc_cs
Config Pinb.2 = Output
Set Portb.2
Mmc_portmosi Alias Portb
Bmmc_mosi Alias 2
Config Pinb.3 = Input
Mmc_portmiso Alias Pinb
Bmmc_miso Alias 3
Portb.3 = 1 ' pull up
' SCK - Pin => Pin 5 of MMC/SD
Config Pinb.1 = Output
Set Portb.1
Mmc_portsck Alias Portb
Bmmc_sck Alias 1
#endif
' --------- End of Section for Soft-SPI ----------------------------------------
#endif
' ========== End of user definable range =======================================
'==== Variables For Application ================================================
Dim Mmcsd_cardtype As Byte ' Information about the type of the Card
' 0 can't init the Card
' 1 MMC
' 2 SDSC Spec. 1.x
' 4 SDSC Spec. 2.0 or later
' 12 SDHC Spec. 2.0 or later
Dim Gbdriveerror As Byte ' General Driver Error register
' Values see Error-Codes
' ==== Variables for Debug =====================================================
' You can remove remarks(') if you want check this variables in your application
Dim Gbdrivestatusreg As Byte ' Driver save here Card response
' Dim gbDriveErrorReg as Byte at GbdriveStatusReg overlay '
' Dim gbDriveLastCommand as Byte ' Driver save here Last Command to Card
Dim Gbdrivedebug As Byte
' Dim MMCSD_Try As Byte ' how often driver tried to initialized the card
'==== Driver internal variables ================================================
' Dim _mmcsd_timer1 As Word
' Dim _mmcsd_timer2 As Word
' Error-Codes
Const Cperrdrivenotpresent = &HE0
Const Cperrdrivenotsupported = &HE1
Const Cperrdrivenotinitialized = &HE2
Const Cperrdrivecmdnotaccepted = &HE6
Const Cperrdrivenodata = &HE7
Const Cperrdriveinit1 = &HE9
Const Cperrdriveinit2 = &HEA
Const Cperrdriveinit3 = &HEB
Const Cperrdriveinit4 = &HEC
Const Cperrdriveinit5 = &HED
Const Cperrdriveinit6 = &HEE
Const Cperrdriveread1 = &HF1
Const Cperrdriveread2 = &HF2
Const Cperrdrivewrite1 = &HF5
Const Cperrdrivewrite2 = &HF6
Const Cperrdrivewrite3 = &HF7
Const Cperrdrivewrite4 = &HF8
$lib "MMCSD_HC.LIB"
$external _mmc
' Init the Card
Gbdriveerror = Driveinit()
' you can remark/remove following two Code-lines, if you dont't use MMCSD_GetSize()
$external Mmcsd_getsize
Declare Function Mmcsd_getsize() As Long
' you can remark/remove following two Code-lines, if you dont't use MMCSD_GetCSD()
' write result of function to an array of 16 Bytes
$external Mmcsd_getcsd
Declare Function Mmcsd_getcsd() As Byte
' you can remark/remove following two Code-lines, if you dont't use MMCSD_GetCID()
$external Mmcsd_getcid
Declare Function Mmcsd_getcid() As Byte
' you can remark/remove following two Code-lines, if you dont't use MMCSD_GetOCR()
' write result of function to an array of 4 Bytes
$external Mmcsd_getocr
Declare Function Mmcsd_getocr() As Byte
' you can remark/remove following two Code-lines, if you dont't use MMCSD_GetSDStat
' write result of function to an array of 64 Bytes
$external Sd_getsd_status
Declare Function Sd_getsd_status() As Byte
' check the usage of the above functions in the sample MMCSD_Analysis.bas
' check also the MMC and SD Specification for the content of the registers CSD, CID, OCR and SDStat
