benoit
Posted: Thu Apr 23, 2015 7:48 am Post subject: |
TO AMIRF
HELLO TRY AT EB AY it is cheaper
have fun |
Deanus
Posted: Mon Jul 13, 2015 8:25 am Post subject: |
Hello Benoit,
How fast is it from playing one Wav, to the the loading and running of another wave? The files would be reasonably small, the files I created @22k are around 500bytes to 1K so far.
Would it be fast enough that "Strings of words" could be spoken without significant delay betreen using small strings of words or spoken numbers. (as each individual wavs)
Regards
Dean |
Posted: Mon Jul 13, 2015 6:18 pm Post subject: |
Here You have this project tunned for Internal 8MHz countdown from 10 to 0 and Ignition (file in attachment)
Words on card could be further trimmed...
You can look how this work on my channel on YouTube https://youtu.be/BNt-JCinm94
I decided to create a channel with the same name as my homepage.
Loading files is not a problem as You can see. "POOF" is generated when files change. I had no time and no need yet to look how this fix.
Maybe You can
So look into code. I optimize interrupt with my new tool for Bascom. Also CTC mode is used instead load_timer..there will always be something to improve..
Have a nice day |
benoit
Posted: Mon Jul 13, 2015 8:26 pm Post subject: |
HELLO deanus
as show in the demo of EDC it is quick enouth, i have not check time exactly
just try
hello EDC
nice video
Deanus
Posted: Mon Jul 13, 2015 9:17 pm Post subject: |
Excellent thank you both.
Regards
Dean |
djalltra
Posted: Thu Jul 16, 2015 12:04 pm Post subject: |
good job but my question is how did you convert the files to cs format |
Posted: Thu Jul 23, 2015 12:07 pm Post subject: |
I use Audacity Freeware.
When You have file recorded 22kHz then
->Export audio -> (find between Mp3,Wav ) "Another File Format" ->Non Compressed PCM Wav 8bit
This will save file as WAV so You must rename it to 11 characters long name. Best way to do this is copy new name from Bascom code, then right click on file name ane select "rename" and paste this copied name from bascom code. I use this way because in Windows I cannot add spaces to name of the file but when they are copied file name have 11 characters. |
Ross_ValuSoft
Joined: 20 Nov 2005 Posts: 275 Location: Melbourne, Australia
Posted: Mon Jul 27, 2015 4:40 am Post subject: |
EDC,
Do you hear the "click" sound after each file if you replay them in Audacity or any other player? Is the click caused by the Bascom code perhaps?
Cheers,
Ross _________________ Ross McKenzie
Melbourne Australia |
benoit
Posted: Tue Aug 11, 2015 4:19 pm Post subject: |
HI
DOES THE CLICK SOUND IS DURING PLAY WITH ATMEGA ?
OR
DOES THE CLICK SOUND IS IN AUDACITY ? |
Posted: Tue Sep 15, 2015 2:06 pm Post subject: |
Hello
I like your project, and I want to test it but I also need some help for another project. Please try to contact me by private mail , it will be easy to write in French
many thanks
JP |
benoit
Posted: Wed Sep 16, 2015 7:19 pm Post subject: |
OK |
Posted: Thu Sep 17, 2015 8:58 am Post subject: |
Benoit,
You can reach me through this link
http://bils-instruments.pagesperso-orange.fr/ it was my own company before I'm retired. follow the link "nous joindre" I will explain what I need
Merci d'avance
JP |
benoit
Posted: Fri Sep 18, 2015 6:25 pm Post subject: |
SALUT
please check your mail
MERCI |
Posted: Sat Sep 19, 2015 10:15 am Post subject: |
jeanpierre.duval2 at orange.fr
ça doit marcher enfin j'espère ! |
