How to detect the RJ-45 cable plug in or not ?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive
odinfang68
PostPosted: Fri Feb 24, 2006 12:43 pm    Post subject: How to detect the RJ-45 cable plug in or not ? Reply with quote
I need a function to know whether the cable plug in or not ? Can anybody help me ? thanks.
Bascom Ambassador
PostPosted: Tue Mar 07, 2006 6:52 pm    Post subject: Signal on link ethernetcontroller Reply with quote
If I look at the WebTiger from www.achatz.nl and unplug the RJ45 cable, I see the LINK-led going off. So I think it should be possible to check if a cable is inserted and if there is a link to a switch.
Perhaps check the datasheet of the ethernetcontroller. Specially the LED's. Perhaps you can connect this signal to an input on your microcontroller.
Have fun
Ben Zijlstra
george2002
PostPosted: Mon Mar 20, 2006 11:58 am    Post subject: Reply with quote
in my opinion ther are two options to check is there connected cable Smile
first option is to connect to microprocesor to rtl8019as pin60 or 61 or 62 or 63 because that pins are showing status of connection but i dont know which led showing it Razz
second idea is to ping some ip adress and when ping is working then cable is connected and when there is no ping then cable is not connected but in this option pinged computer/slave device must be on whole time Smile
ps
sorry for my poor english Very Happy
regards
george2002
Hi 4 all Smile
odinfang68
PostPosted: Wed Apr 05, 2006 9:29 am    Post subject: Use W3100A Pin36 /Link for Input Pin Reply with quote
I use W3100A Pin36 "/Link" for Input pin. It can work very well.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Easy TCP/IP Archive All times are GMT + 1 Hour
