Arduino Mega Timer/Counter0 Not working
snow
PostPosted: Mon Jul 13, 2015 10:12 am    Post subject: Arduino Mega Timer/Counter0 Not working Reply with quote
Hi All
I must be overlooking something real simple. I cant get the Timer/Counter0 to work on the Arduino Mega as a counter
'                   Counter testing
'                              21-june-15
'Version 1. .
'Testing to read the timer/counter0 on the proto board
$regfile = "m2560def.dat"
$crystal = 8000000                                                              ' used crystal 8MHZ frequency
$hwstack = 32        ' default use 32 for the hardware stack
$swstack = 10        ' default use 10 for the SW stack
$framesize = 40
'---******* setup LCD pinouts ******----
Config Lcdbus = 4
Config Lcd = 16x2
Config Lcdpin = Pin , Db4 = Porte.3 , Db5 = Portg.5 , Db6 = Porte.5 , Db7 = Porte.4 , E = Porth.4 , Rs = Porth.3
Config Lcd = 16 * 2
Display Off
Cls
Cursor Off
Waitms 100
Display On
'---*** Finishing setting up LCD Pinouts ***----
Config Timer0 = Counter , Edge = Rising , Prescale = 1
Enable Timer0
Start Timer0
     Cls
     Lcd "Count: " ; Timer0
     Waitms 100
It just seem to run all the time with no pulse input even when i tie pin 38 of the baord low
Cheers
Snow
PostPosted: Wed Jul 15, 2015 7:12 pm    Post subject: Reply with quote
hello,
If you post here it means that it is on an Arduino mega2560 ? so why Crystal 8Mhz ???
in this case indicated you must update
$crystal = 16000000
$hwstack = 40 ' mini
$swstack = 16 ' mini
$framesize = 40 ' mini
You have lots of ram, use them for the stacks
an lcd display is a relatively slow
CLS and waitms 100 is a little short for a change
use locate x, Y: lcd Spc (4) to clear only the number
Off display
CLS
Off cursor
Waitms 100
Display On
all this is useless
Config Lcdbus = 4
Config Lcd = 16 x 2 are not necessary, they are the default value.
test the display with
CLS
Locate 1.1: lcd "hello word"
Locate 2.1: lcd "Hello!"
wait 2
CLS
then your program
very long ago I played with counters on an M8
Here is the program
CLS
Config Timer0 = Counter, Edge = Rising
Tcnt0 = 0
Enable Counter0 ' allows timer0
Locate 1, 1: Lcd "register:"; Tcnt0 ' number of rotation
If <>0 Then Gosub Suite2 Tcnt0 ' or: one ovf0 suite
End ' end program
Suite2:
Disable Counter0 ' otherwise the prog is blocked, it cannot do anything in the gosub
K = K + 1
Locate 2, 1: Lcd "counter:"; K
Tcnt0 = 0 ' for the TCNT0 <>condition 0
Waitms 100 'no cls !
bon courage
JP
Wink
