Posted: Sun Jun 21, 2015 5:40 pm Post subject: Wireless transmission of programs.
I have been using blutooth along with a bootloader. To avoid having to use the code in program I use a ATTiny to sniff rx and detects when the 123 will come then puts attinyn a reset pulse and waits until PB3 goes low then then it starts listening efer 123 again. It works, but you can do it more smoothly? I using HC05 as a transmitter and the transmitter operates up to 10 m.
The program
' Reset signal for MCS Bootloader
$regfile = "attiny45.dat"
$prog &HFF , &HD2 , &HDC , &HFF
$hwstack = 64
$swstack = 64
$framesize = 64
Dim Bstatus As Byte
Const On = 1
Const Off = 0
'Ddrb = &B00011001
Led Alias Pinb.4 'fungerar inte
Res Alias Pinb.3
Ok Alias Pinb.2
Config Led = Output
Config Res = Output
Config Ok = Input
Res = On 'set Res
Led = Off 'Reset Led
Ok = On
Open "comb.1:38400,8,n,1" For Input As #2
'Open "comb.0:38400,8,n,1" For Output As #1
Bstatus = Waitkey(#2) '{ did we received value 123 ?
If Bstatus = 123 Then
Led = On 'Set Led
Res = Off 'Reset Res
Waitms 5
Res = On
Bitwait Ok , Reset
nop
Maybe there's something smarter way to do this. But it works just fine.
Sincerely Maxneo
