Joystick bluetooth Commander
maxneo
PostPosted: Wed Jun 17, 2015 12:50 pm    Post subject: Joystick bluetooth Commander Reply with quote
Hi
I try to use an Android app to run a robot "Joystick bluetooth Commander"
but do not know how I should decoda input data flow.Android app
sends ASCII characters'
The data frame is send via BlueTooth to the arduino board and decoded.
'2' is Ascii 32 hex (decimal 50)
'0' is Ascii 30 hex (decimal 4Cool
Data frame: <0x02 0x32 0x30 0x30 0x32 0x30 0x30 0x03>
Data is sent as ascii shall I handle it as a close and use the ASC ()
data flow in my terminal Hex
02 31 36 38 31 39 32 03 02 31 36 38 31 39 32 03
exampel for ardunio
void getJoystickState(byte data[8]) {
int joyX = (data[1]-4Cool*100 + (data[2]-4Cool*10 + (data[3]-4Cool; // obtain an Int from the ASCII representation
int joyY = (data[4]-4Cool*100 + (data[5]-4Cool*10 + (data[6]-4Cool;
joyX = joyX - 200; // Offset to avoid
joyY = joyY - 200; // transmitting negative numbers
link to Joystick bluetooth Commander
https://play.google.com/store/apps/details?id=org.projectproto.btjoystick&feature=search_result
Does anyone have any suggestions?
many greetings Maxneo
maxneo
PostPosted: Wed Jun 17, 2015 12:52 pm    Post subject: Jag försöker igen utan smilys Reply with quote
Hi
'0' is Ascii 30 hex (decimal 48)
exampel for ardunio
int joyX = (data[1]-48)*100 + (data[2]-48)*10 + (data[3]-48); // obtain an Int from the ASCII representation
int joyY = (data[4]-48)*100 + (data[5]-48)*10 + (data[6]-48);
PostPosted: Wed Jun 17, 2015 1:18 pm    Post subject: Reply with quote
there are multiple ways to do it. you get : 02 31 36 38 31 39 32 03 02 31 36 38 31 39 32 03
which means 02 is the start of the frame and this is what you need to watch for.
the 03 seems to mark the end of a frame. I think you also get CR + LF ?
That would make it simple. Just use INPUT and store the data into a line. Then extract the data using mid()
dim s as string * 50, dgt2 as String*2
s= "02 31 36 38 31 39 32 03 02 31 36 38 31 39 32 03"
dim dgt as string * 3,j as Byte,b as Byte
for j=4 to 10 step 3 'get 32 36 38
  dgt2=mid(s,J,2) 'get 2 digits
  b=hexval(dgt2) -48
  dgt=dgt + str(b)
next
dim value1 as Integer
value1=val(dgt)
you can also check out split()
maxneo
PostPosted: Wed Jun 17, 2015 1:53 pm    Post subject: Android Reply with quote
Thanks for the reply Mark, I have tried to use the hex (), Val (), Chr () and it has not been good. It says in the text that should (data [X] -4Cool * 100 -48 is well because it is ASCII can not load byte for byte and decod directly? No, now I will test your proposal many thanks Maxneo
