programming the DigiSpark with BASCOM
MJB
PostPosted: Thu Jun 11, 2015 12:35 pm    Post subject: programming the DigiSpark with BASCOM Reply with quote
just saw the DigiSpark modules 5 for 12.69 €.
can those be programmed with BASCOM just using the Arduino programming mode?
Anyboy experience with the DigiSpark?
I don't want to go to the ArduinoIDE Wink
thanks MJB
PostPosted: Thu Jun 11, 2015 1:09 pm    Post subject: Reply with quote
when it has the arduino v1 or v2 bootloader (stk500 v1 or stk500v2) loader it should work. just ask the vendor for information on the used bootloader.
MJB
PostPosted: Thu Jun 11, 2015 10:21 pm    Post subject: Micronucleus USB boot loader for ATTiny Reply with quote
Thanks Mark,
this is what I found so far.
Maybe you know it.
https://github.com/micronucleus/micronucleus
http://www.instructables.com/id/Digispark-DIY-The-smallest-USB-Arduino/
This DigiSpark with BASCOM would be great for little creating 'things'.
PostPosted: Thu Jun 11, 2015 10:34 pm    Post subject: Reply with quote
it seems they use a piece of the usbasp protocol. i do not think they support to read the device id. and they use a different usb id.
this means that it is not the normal arduino protocol. but a simplified usbasp protocol.
if you send a device i can add it. maybe they use a different pid for each micro, i did not check that.
of course you can also use their command line loader and use bascom external programmer.
