Posted: Fri Sep 20, 2013 11:34 am Post subject: Serial to wireles to Ethernet |
I recently received a HLK-RM04 wireless router serial to tcpip development module with this you can send two serial ports via TCPIP to anywhere via the internet. You can create virtual serial ports on a PC with software you can get from the Hi-Link site. The unit is 40mm x 28mm in size with two rows of header pins to bring out the connections with the development board you already have two Ethernet ports a serial port with DB9 and provision for a second serial port. Now not only do you get two serial ports to TCPIP you also get a full Linux based router with all the features like firewall , NAT , filtering , DHCP , Security etc The cost is less than that of a Wiznet module. When I have played with it a bit more I might start another blog using this with an AVR.
Here are some shots of the set-up pages.
Regards Paul |
Posted: Tue Oct 01, 2013 10:22 pm Post subject: |
module seems interesting but : i downloaded the docs and the info is very limited. did you find a complete listing of AT commands?
such a module is only usable (IMO) when it can controlled completely by AT commands otherwise you need tools and setup to make it work which is not very convenient for a product.
the module sure has potential and a good price so with a good AT command description it would be a great WIFI module. _________________ Mark |
Posted: Wed Oct 02, 2013 12:36 am Post subject: |
Hello Mark
Yes I found a full set of AT commands you can control and get information about all the settings of the unit but I did have to dig a bit for them from what I can tell (will have to test) the HLK-WIIF-M04 is the same thing just boxed I have seen comments also that the company is very responsive to questions. I see having this in front of an AVR with its full fire wall , NAT etc a great way to add security to an AVR used for a remote sensor you may be able to turn this into a product you can sell.
Regards Paul |
Posted: Sat Oct 05, 2013 7:12 am Post subject: |
Here is the user manual for HLK-WIFI-M04 which should have the same AT commands as the HLK-RM04 I have yet to confirm this but I will when I have a chance.
Regards Paul |
amir30
Posted: Thu Nov 06, 2014 9:11 pm Post subject: |
I have the base board model of HLKRM04 and i want to use it in Ethernet mode (transferring data between two microcontrolers using 2 of these modules). I have been struggling to run this module for so long, it's driving me crazy. I've searched a lot hoping to get a sample code but i couldn't find any. I use bascom compiler but any sample code will help.
I'm a liitle bit familiar with at commands but still a beginner.
I could really use your help.
Thanks. |
Posted: Thu Nov 06, 2014 10:31 pm Post subject: |
I found some manuals here : http://www.hlktech.net/download.php?CateId=2
I would advise to start with just 1 module connected to a terminal emulator. Setup all parameters and learn the AT command set so it does what you want.
The next step would be to connect it to a micro.
When you want to exchange data you need to ask yourself how : one module is server? and the other client? or you use UDP on both?
Maybe someone used this module and has some code to share. it is indeed a nice module and affordable. i found a complete AT list from the link above so it seems well documented now. _________________ Mark |
Posted: Fri Nov 07, 2014 9:33 am Post subject: |
Hello amir30
I have not had time to do much with the module but with the software to set them up via TCPIP on your PC there was a mode that connects two modules together so that a transparent link is achieved so the two AVRs would appear to be directly connected to each other.
Regards Paul |
amir30
Posted: Tue Nov 11, 2014 1:16 am Post subject: |
thanks a lot dear Albert and Paul
I really appreciate it
I'll try my best to get it started. I'm going to need your help for sure |
maloldis
Posted: Tue Dec 02, 2014 9:50 pm Post subject: HLK-RM04 |
Hey Paul VK.
I am also purchased this module HLK-RM04.
I was wondering what you have been able to do with it.
Can power and TXD RXD be enough to start with??
Mal |
Posted: Mon May 04, 2015 11:50 am Post subject: |
Here is how to use it to send and receive HTTP data
http://rayshobby.net/first-impression-on-hlk-rm04-serial-to-wifi-module/
Very easy, not fast but if you use it for simple web pages it should work well.
Going to need a big buffer in the AVR so the mega1284p would be good.
Notes
I am using one to monitor a solar inverter over the net as a virtual serial port, that is like having a 250Km cable!
Regards Paul |
amirf
Posted: Mon Jun 01, 2015 10:38 am Post subject: |
Ordering serial to wifi modul : ESP8266 |
