Using the LCD Display on the XMEGA A3BU Xplained board
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Share your working BASCOM-AVR code here
MAK3
PostPosted: Tue Feb 05, 2013 10:57 pm    Post subject: Using the LCD Display on the XMEGA A3BU Xplained board Reply with quote
here is an example of how to use the LCD Display on the XMEGA A3BU Xplained board:
Based on the library from here:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=download&id=2447
I made an example which I have tested in hardware:
$regfile = "XM256A3BUDEF.DAT"
$crystal = 32000000                                         '32MHz
$hwstack = 64
$swstack = 40
$framesize = 80
$lib "glcdeadogm128x3.lib"                                  ' Lib for the XMEGA A3BU-XPLAINED Display
Config Portr.0 = Output
Led0 Alias Portr.0                                          'LED 0 (XMEGA-A3BU XPlained board from Atmel )
Config Portr.1 = Output
Led1 Alias Portr.1                                          'LED 1 (XMEGA-A3BU XPlained board from Atmel )
Config Porte.4 = Output
Display_backlight Alias Porte.4
' DISPLAY_SS = PF3
' DISPLAY_RS = PD0 --> A0 (REGISTER_SELECT)
' SPI_SCK --> PD1
' SPI_MOSI --> PD3
Config Graphlcd = 128x64eadogm , Cs1 = Portf.3 , A0 = Portd.0 , Si = Portd.3 , Sclk = Portd.1 , Rst = Porta.3
'specify the font we want to use
'Setfont Font8x8tt
Setfont Font8x8
Set Display_backlight
Lcdat 1 , 1 , "11111111"
Lcdat 2 , 1 , "88888888"
Lcdat 3 , 1 , "MCS Electronics" , 1
Wait 2
    Waitms 500
    Lcdat 1 , 1 , "22222222"
    Set Led1
    Reset Led0
    Waitms 500
    Reset Led1
    Set Led0
'include used fonts
'$include "font8x8TT.font"
$include "font8x8.font"
MAK3
Meister
PostPosted: Sat Mar 02, 2013 11:52 am    Post subject: Reply with quote
Thanks,
Will graphics (like point, line etc.) work with the library?)
regards, Meister
PostPosted: Sat Mar 02, 2013 10:08 pm    Post subject: Reply with quote
no. the reason is that the manufacturer of the LCD did not allow the user to read the data. I do not understand why they do not simply add a command to read out the data.
Anyway, when you can not read the memory, you can not read a byte, alter a bit, and write the byte back. setting a pixel would require this.
A workaround is to use the processor memory as a buffer and work on that. But it is a waste of memory. For a smaller display that might not be a problem. 128x32 for example requires 4096 bits = 512 bytes. 512 is still a lot of sram IMO.
Jerry
PostPosted: Tue May 26, 2015 3:51 pm    Post subject: Reply with quote
Thanks for good information MAK3.
I have a couple questions.
Where did this library come from?
I am using BASCOM-AVR 2.0.7.8 and I do not see this library.
Where did you get, or how did you create?
Thank you,
Jerry
Jerry
PostPosted: Tue May 26, 2015 8:18 pm    Post subject: Reply with quote
Never mind. Got it.
Jerry
Meister
PostPosted: Tue May 26, 2015 10:04 pm    Post subject: Reply with quote
There is a recent nice graphics application for the XMEGA A3BU-XPLAINED board:
http://bascomforum.de/
Scroll down to the last post (#159).
Regards, Meister
Jerry
PostPosted: Wed May 27, 2015 5:34 am    Post subject: Reply with quote
Thank you very much Meister.
jynx
PostPosted: Sat Apr 30, 2016 8:19 pm    Post subject: Reply with quote
Where did you find the file "font8x8.font"? I cannot find it in the Bascom folder. Thanks!
jynx
PostPosted: Sat Apr 30, 2016 10:58 pm    Post subject: Reply with quote
Meister
PostPosted: Sun May 01, 2016 8:21 am    Post subject: Reply with quote
jynx
PostPosted: Sun May 01, 2016 9:30 pm    Post subject: Reply with quote
Awesome! Thanks.
Paisley
PostPosted: Fri Dec 07, 2018 11:07 pm    Post subject: Reply with quote
is the glcdeadogm128x3.lib library still available somewhere? The link just gives an invalid .zip and I would looooove to use the LCD on my Xplained board..
Thank you and kind regards!
PostPosted: Sat Dec 08, 2018 8:44 pm    Post subject: Reply with quote
It comes with BASCOM-AVR, you find it in the LIB folder.
Paisley
PostPosted: Sun Dec 09, 2018 11:03 am    Post subject: Reply with quote
Negative, I downloaded the recent version of BASCOM to check but it is not there. If you have it, could you upload it please? That would be really really helpfull for me Smile
I can see glcdEADOGM128x6.lib and other libs, but the one I need is not there.
PostPosted: Sun Dec 09, 2018 11:23 am    Post subject: Reply with quote
The file is there.
This forum is not intended to upload normal system files from BASCOM. The reason is simple : if we change the files we have to deal with them on the forum as well.
Post new topic   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> Share your working BASCOM-AVR code here All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
