nicofer
Posted: Sun Feb 22, 2015 9:19 am Post subject: |
Regarding the pcb that was mentioned early January - well at last a few photos to show what is happening .
Still need a lot of work on the display and layout during use .
The green led is a 1pps indication , if no 2d/3d fix it will flash red - led on other side is red for charging and green for user .
Vib motor , 4 buttons , power on/off "( Power on/off auto standby with buttons )but gps rtc get direct feed from batt , li charger , micro sd card with power control , 3 axis acceleration sensor , 14 pin programming / serial output port ,
5x5 mm beeper , 0,96 " oled , ( 1.3" will also fit ) micro usb for charge , G-Top 16 x 16 gps module , 1.2 mm pcb with "ears " for wrist strap .
Pcb size 42 x 32 mm (without ears , can be cut off if not required , can be worn in landscape or portrait mode )
At the moment I have an external gps antenna hooked up to the module - on the ext ant input- for testing since some functions will only work with valid fix .
Cheers |
snipsnip
Posted: Mon Feb 23, 2015 1:45 am Post subject: |
Hi nicofer,
nice work
Are you going to be selling these? put me down for a couple.
Also
what speed are you running the gtop comms at? I'm using same module but
I cant get it to work at 115200, only 38k is working for me.
Cheers |
nicofer
Posted: Mon Feb 23, 2015 10:19 pm Post subject: |
Thanks - yes , there will be a few pcb's for those who would like to experiment , maybe with a few odd parts until my stock dries up .
My GPS data rate is still 9600 - default , have not tried any other .
I want to make one or 2 changes to the pcb before I set them free.
The main idea is the logging of the track for GPX file upload to Strava or similar application (working fine ) - the on screen info during use is second in line but still very important .
There are 2 fields of further exploring - the gps data filter / calculation ( metrics ) - and then the display .
The last is the hardware and enclosure - way off topic ....
So I hope that this project will set the creative minds free and we can share a bit of code.
The big problem with AVR compared to ARM is the internal RAM - 4k is quite limited once you have a sd flash disk and a graphics screen . One way to solve it is to use a AT90USB1287 with 8kb RAM - and the USB - I have not used any of the AVR USB devices so it will be uncharted waters .
At the moment firmware upload is via ISP , want to add usb-uart converter so that the firmware can be uploaded via usb/serial bootloader - ( only one external connector required )
I still need to decide on std mega128 (4k ) with an external usb bridge or a USB1287 cpu with more memory ( 8 k ) and internal USB - any feedback ?
Best might be to just add the usb/uart bridge chip ( PL2303 SA ) , mainly for serial debugging and maybe bootload later , do not want to create more problems .
Will advise when rev 2 pcb's are ready .
Cheers |
snipsnip
Posted: Tue Feb 24, 2015 12:10 am Post subject: |
Quote: |
I still need to decide on std mega128 (4k ) with an external usb bridge or a USB1287 cpu with more memory ( 8 k ) and internal USB - any feedback ? |
Yeah, but what about the 2561 and an external 16u2? If you keep it Arduino compatable there would be a much bigger market, Tindie, adafruit, sparkfun resellers etc. |
snipsnip
Posted: Tue Feb 24, 2015 12:32 am Post subject: |
Day, Time and date stamp.
Function Timestamp(timezone As Word , Plusneg As Byte)as String
Local X As Byte
Local Timez As String * 8 : Local Datez As String * 8 : Local Dayz As String * 4
Local Tmp As String * 2 : Local Tmp1 As String * 2 : Local Tmp2 As String * 2
Local Sissec As Long
Timez = Commapos(1 , "GPRMC")
Timez = Left(timez , 6)
Tmp = Left(timez , 2)
Tmp1 = Mid(timez , 3 , 2)
Tmp2 = Right(timez , 2)
Timez = Tmp + ":" + Tmp1 + ":" + Tmp2
Datez = Commapos(9 , "GPRMC")
Datez = Left(datez , 6)
Tmp = Left(datez , 2)
Tmp1 = Mid(datez , 3 , 2)
Tmp2 = Right(datez , 2)
Datez = Tmp + "/" + Tmp1 + "/" + Tmp2
Sissec = Syssec(timez , Datez)
Timezone = Timezone * 3600
If Plusneg = 0 Then Sissec = Sissec - Timezone
If Plusneg = 1 Then Sissec = Sissec + Timezone
Datez = Date(sissec)
Timez = Time(sissec)
X = Dayofweek(sissec)
Select Case X
Case 0 : Dayz = "MON "
Case 1 : Dayz = "TUE "
Case 2 : Dayz = "WED "
Case 3 : Dayz = "THU "
Case 4 : Dayz = "FRI "
Case 5 : Dayz = "SAT "
Case 6 : Dayz = "SUN "
Timestamp = Dayz + Timez + " " + Datez + " " + Valid
End Function
snipsnip
Posted: Tue Feb 24, 2015 12:47 am Post subject: |
odometer
pretty much working - matches car odo (+/-) 200m over a 32k drive
Function Odo(startlat As Single , Startlon As Single , Startalt As String ) As String
Local Tempstring As String * 10 : Local Y As Byte
Dim Temp As Single : Dim Total As Single
Dim Alti As Single
Dim Store(6) As Single
Dim Initflag As Byte
Dim Togglebit As Bit
Alti = Val(startalt)
if Initflag < 3 then
Store(1) = Startlat
Store(2) = Startlon
Store(3) = Startlat
Store(4) = Startlon
Store(5) = Alti
Store(6) = Alti
incr Initflag
endif
If Togglebit = 0 Then
Store(1) = Startlat
Store(2) = Startlon
Store(5) = Alti
If Togglebit = 1 Then
Store(3) = Startlat
Store(4) = Startlon
Store(6) = Alti
Temp = 3ddistance(store(1) , Store(2) , Store(3) , Store(4) , Store(5) , Store(6))
Total = Total + Temp
Toggle Togglebit
Tempstring = Str(total)
Y = Charpos(tempstring , "." )
Y = Y + 3
Tempstring = Left(tempstring , Y)
Tempstring = Tempstring + " ODO"
Odo = Tempstring
End Function |
nicofer
Posted: Tue Feb 24, 2015 5:52 am Post subject: |
I have not thought about the "other " market , but not a bad idea . I used the cpu that I had but the 1280 or 2561 is a good improvement and the 16u2 will help even more. Will have to see what will still fit on the pcb .
Cheers |
snipsnip
Posted: Wed Mar 04, 2015 2:54 pm Post subject: |
another basic one - returns the difference between the last and current headings.
doesn't give a direction (WIP) just returns the angle.
Function Deviation(starthead As String)as String * 7
Local Tmp As Integer : Local Stmp As String * 6
Tmp = Val(starthead)
''togglebit is global - toggled on each gps read.
If Togglebit = 0 Then Tmp3(1) = Val(starthead)
If Togglebit = 1 Then Tmp3(2) = Val(starthead)
Tmp = Tmp3(1) - Tmp3(2)
Tmp = Abs(tmp)
'this is to get rid of the 360 - 0 degree crossover / rollover.
If Tmp => 180 Then
Tmp = 360 - Tmp
Stmp = Str(tmp)
Deviation = Stmp + " "
End Function
max
Posted: Tue Apr 14, 2015 12:54 pm Post subject: |
snipsnip wrote: | anchor / proximity alarm, not tested yet
'anchor / proximity alarm returns "anchor" in meters from target when setdistance is exceded
'lat,lon in decimal meters,
'to_from.. 0=to 1=from ie 1=anchor and 0=proximity alarm conviguration
Function Anchor (anchlat , Anchlon , Curlat , Curlon , Setdistance , To_from ) As Single
Local Tmp As Single
Setdistance = Setdistance / 1000
'couldnt be stuffed rewiting the dist function here. if stack / portability is an issue rewrite it
Tmp = 3ddistance (anchlat , Anchlon , Curlat , Curlon , 1 , 1)
If To_from = 1 And Tmp > Setdistance Then
Tmp = -tmp
Elseif To_from = 0 And Tmp < Setdistance Then
Tmp = -tmp
'convert to meters
Tmp = Tmp * 1000
Anchor = Tmp
End Function
End Function
I live on my boat now and was looking to make one of these. Any more work done on this?
Thanks |
snipsnip
Posted: Wed Apr 15, 2015 6:08 pm Post subject: |
max wrote: |
Thanks |
Hi mate, not much at the moment - working on the hardware side of things.
So you getting nervous when the wind picks up? Rum helps |
max
Posted: Fri Apr 17, 2015 7:16 am Post subject: archor drag |
Just for info, why am I wanting to make my own anchor drag when they are available on the commercial chart plotters etc..
They false alarm a lot due to the way they work.
Imagine if you will a 20 meter circle based on where the anchor it sitting. Then imagine a 20 metre circle where the chart plotter etc is after the chain/rope is paid out. if the wind is from the north when you set the anchor point and it changes to the south, with the rope paid out you will swing way over 20 metres.
I need to make a unit which takes a reading from the GPS as it is let go, that way the 20 metre arc is relative to the anchor and not the boat. This will mean the anchor drag is a circle from the point of anchor and not the boat GPS location. With 15 ton of yacht, I want to be able to sleep better.
Rather than average, I will take the most common ten samples and ignore anything out side of those. Always comparing the latest 10 samples. |
snipsnip
snipsnip
Posted: Sun Nov 10, 2019 12:05 pm Post subject: |
a few years later and just wrote this for spitting out basic kml info for google earth
just does pins, but enough for testing.
Code: | Sub genKML()
local a as byte
print "<?xml version=";chr(34);"1.0";chr(34);" encoding=";chr(34);"UTF-8";chr(34);"?>"
print "<kml xmlns=";chr(34);"http://www.opengis.net/kml/2.2";chr(34);
print " xmlns:gx=";chr(34);"http://www.google.com/kml/ext/2.2";chr(34);">"
print "<Document>"
print "<LookAt> <longitude>";
print fencelon(1);
print "</longitude> <latitude>";
print fencelatt(1);
print "</latitude> <range>1300.000000</range> </LookAt>"
print "<Folder>"
for a = 1 to index
print "<Placemark>"
print "<name>";a;"</name>"
print"<Point> <coordinates>"
print fencelon(a);
print ",";
print fencelatt(a);
print "</coordinates></Point></Placemark> "
next a
print "</Folder> </Document></kml>"
wait 10 'just for testing
end sub
Cheers
Simon |
