Can't compare strings!
Zvoc47
PostPosted: Sun Apr 12, 2015 1:51 am    Post subject: Can't compare strings! Reply with quote
$regfile = "xm128a1def.dat"
$Crystal=32000000
$hwstack=4160
$swstack=16
$framesize=32
$baud = 115200
'Config Serialin = Buffered , Size = 80
'Config Serialout = Buffered , Size = 254
Declare Sub UsartInput(byref Target As String, byval MaxChars As Integer)
'Enable interrupts
Dim ime As String * 8
Call UsartInput(ime,8)
Print ime
Loop until lcase(ime)="over"
do
print "Over!"
Waitms 100
loop
   Local A As Byte
   Local Index As Integer
   Local WhiteSpace As Byte
   Local I As Byte
   InputAgain:
   Target=""
   Index=0
   WhiteSpace=0
   A=WaitKey()
   If A=8 Then
      If Index>0 Then
         Print Chr(8);" ";Chr(8);
         Decr Index
         Target=left(Target,Index)
      End if
   Else
      If A>31 And A<127 Then
         If Index<MaxChars Then
            Incr Index
            Target=Target+Chr(A)
            Print Chr(A);
   Loop Until A=13
   WhiteSpace=1
   For I=1 To Index
      If Target[I])<>" " Then WhiteSpace=0
   Next I
   If WhiteSpace=1 Then Goto InputAgain
   Print ""
End Sub
The error is in "If Target[I])<>" " Then WhiteSpace=0". It says
Error : 31    Line :   58    Invalid data type [[0011] 0[TARGET[I]]]  , in File : (censored)\noname2.bas
I'm trying to iterate through the array of chars if there is a non-space character and say that WhiteSpace is 0 and go to input again
bzijlstra
Bascom Ambassador
PostPosted: Sun Apr 12, 2015 2:08 am    Post subject: typo Reply with quote
There is a extra ) in your code. After Target [I])
have fun
Ben Zijlstra
Zvoc47
PostPosted: Sun Apr 12, 2015 2:10 am    Post subject: Reply with quote
Doesn't fix. Still the same error
PostPosted: Sun Apr 12, 2015 8:11 am    Post subject: Reply with quote
I test if this compile without errors for sure so here You have whole code.
$Crystal=32000000
$hwstack=4160
$swstack=16
$framesize=32
$baud = 115200
'Enable interrupts
Print ime
do
print "Over!"
Waitms 100
loop
   Local A As Byte
   Local I As Byte
   InputAgain:
   Target=""
   Index=0
   WhiteSpace=0
   A=WaitKey()
   If A=8 Then
      If Index>0 Then
         Decr Index
      End if
   Else
            Incr Index
            Print Chr(A);
   Loop Until A=13
   WhiteSpace=1
   For I=1 To Index
      If Target(i) <> " " Then Whitespace = 0
   Next I
   Print ""
End Sub
This is very simple. Letters and control keys from keyboard are located in ASCII table. Values from 32 to 127 are letters that You can see. In lower values, from 0 to 31 You have "control keys" For example 13 is an Enter Key - You can`t see it but it works Smile
Have a nice day Very Happy
PostPosted: Sun Apr 12, 2015 8:14 am    Post subject: Reply with quote
"Target" is by definition data type "string" and not "array".
It's inefficient anyway, to test the string and set a flag for white spaces in a separate loop, if this can be done easily in the input code before.
If out of any reason, a separate loop is desired, then string function mid() needs to be used for accessing single chars in a string. It will also work to overlay the global variable ime with a char array and forward this array as argument to the sub routine. However, the code in the sub needs to be rewritten then, to handle an array instead of a string.
PostPosted: Sun Apr 12, 2015 8:25 am    Post subject: Reply with quote
PostPosted: Sun Apr 12, 2015 8:36 am    Post subject: Reply with quote
Yes, I don`t analyze the code. Only this "If Target[I])<>" " Then WhiteSpace=0 " I want fix...
Zvoc47
PostPosted: Sun Apr 12, 2015 7:29 pm    Post subject: Reply with quote
I solved it by using mid()
PostPosted: Sun Apr 12, 2015 9:01 pm    Post subject: Reply with quote
when the assigned variable is a byte you can also use ASC() like : bSomeByte=asc(sSomestring, bIndex). The index is optional.
Zvoc47
PostPosted: Tue Apr 14, 2015 11:09 pm    Post subject: Reply with quote
The problem is solved. However, I'd sometimes have problems with ASC().
Sometimes ASC() would give me incorrect data type error. Can ASC convert 1 character (character as in byte, not byte and zero byte) from a string into a number that I can later convert into hex? I need this for my debugging program that reads from the program and data memory and prints out hex display like this
0x002000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
PostPosted: Tue Apr 14, 2015 11:36 pm    Post subject: Reply with quote
asc() expects a string. And it will return a byte so it should be used on a numeric data type:
dim b as byte, s as string * 10, idx as byte
s="abcd"
idx=1
b=asc(s,idx)
but there is a catch : when you use the optional index, there is a protection so that you do not index past the end of the string. This means that when the string contains an end of string marker (0) it will end.
If you want direct access you can also consider overlay :
dim s as string * 80
dim b(80) as byte AT S OVERLAY
b() is not a byte array at the same location as String S. Thus b(1) would return the first character.
Using hex() you can print a numeric value.
Zvoc47
PostPosted: Fri Apr 17, 2015 3:44 pm    Post subject: Reply with quote
That means I would need to have an overlay over the whole memory. Is it possible to use C-style pointers instead? I need to be able to load any byte from anywhere in any memory and display it in hex format.
PostPosted: Tue Apr 21, 2015 3:28 pm    Post subject: Reply with quote
why not using INP() function?
