Atxmega32e5
Tiny
PostPosted: Sun Apr 12, 2015 10:37 am    Post subject: Atxmega32e5 Reply with quote
Hello,
For A new design is want to use the Atmega32e5-au
Is the Atmega32e5-au supported?
Witch DAT File must i Select for this cpu?
Reguards,
Tiny
PostPosted: Sun Apr 12, 2015 5:56 pm    Post subject: Reply with quote
hello,
you must use xm32E5def.dat, I test the Atmel module . It works but finally, I go back to the Arduino M2560
JP Wink
Tiny
PostPosted: Sun Apr 12, 2015 6:04 pm    Post subject: Reply with quote
Thankx JP Cool
Tiny
PostPosted: Wed May 06, 2015 9:06 pm    Post subject: Reply with quote
I want to use both the uarts on portD, but de compiler give a error "uart is not available " on com4
The second problem i get is how to calibrate the 32mhz internal clock?
i get a error "Error : 41 Line : 158 Variable can not be used with SET [DFLLRC2M_CTRL]
regard Tiny
$regfile = "xm32E5def.dat"
$crystal = 32000000                                         '32MHz
$hwstack = 60
$swstack = 30
$framesize = 30
Config Submode = New
'  Config Clock
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
Osc_dfllctrl = &B00000000
'Enable DFLL and autocalibration
Set Dfllrc2m_ctrl.0
Set Dfllrc32m_ctrl.0
'  Config compoort
'  Com4 as direct serial port to main cpu
'  Com3 as RS485 bus communication port
Config Com4 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM4:" For Binary As #3
Config Com3 = 19200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Config Portd.1 = Output                                     ' Dir rs485
Config Print = Portd.1 , Mode = Set
PostPosted: Wed May 06, 2015 9:26 pm    Post subject: Reply with quote
- DFLLRC2M_CTRL : this register is not available in this chip so you can not set it. The fact that the IDE does not color this register gives that away too.
- the config comx in the help shows the map of the usarts. use com1 and com3 since only usartc0 and usartd0 exists in this chip!
Tiny
PostPosted: Wed May 06, 2015 9:39 pm    Post subject: Reply with quote
Oke thats clear,
how do i calibrate the internal 32mhz clock then ?
regard Tiny
