Zvoc47
Posted: Sun Apr 12, 2015 1:51 am Post subject: Can't compare strings! |
Code: | $regfile = "xm128a1def.dat"
$Crystal=32000000
$hwstack=4160
$swstack=16
$framesize=32
$baud = 115200
'Config Serialin = Buffered , Size = 80
'Config Serialout = Buffered , Size = 254
Declare Sub UsartInput(byref Target As String, byval MaxChars As Integer)
'Enable interrupts
Dim ime As String * 8
Call UsartInput(ime,8)
Print ime
Loop until lcase(ime)="over"
print "Over!"
Waitms 100
Local A As Byte
Local Index As Integer
Local WhiteSpace As Byte
Local I As Byte
InputAgain:
Target=""
Index=0
WhiteSpace=0
A=WaitKey()
If A=8 Then
If Index>0 Then
Print Chr(8);" ";Chr(8);
Decr Index
Target=left(Target,Index)
End if
If A>31 And A<127 Then
If Index<MaxChars Then
Incr Index
Target=Target+Chr(A)
Print Chr(A);
Loop Until A=13
WhiteSpace=1
For I=1 To Index
If Target[I])<>" " Then WhiteSpace=0
Next I
If WhiteSpace=1 Then Goto InputAgain
Print ""
End Sub |
The error is in "If Target[I])<>" " Then WhiteSpace=0". It says Code: | Error : 31 Line : 58 Invalid data type [[0011] 0[TARGET[I]]] , in File : (censored)\noname2.bas
I'm trying to iterate through the array of chars if there is a non-space character and say that WhiteSpace is 0 and go to input again
Posted: Sun Apr 12, 2015 2:08 am Post subject: typo |
There is a extra ) in your code. After Target [I])
have fun
Ben Zijlstra |
Zvoc47
Posted: Sun Apr 12, 2015 2:10 am Post subject: |
Doesn't fix. Still the same error |
Posted: Sun Apr 12, 2015 8:14 am Post subject: |
"Target" is by definition data type "string" and not "array".
It's inefficient anyway, to test the string and set a flag for white spaces in a separate loop, if this can be done easily in the input code before.
If out of any reason, a separate loop is desired, then string function mid() needs to be used for accessing single chars in a string. It will also work to overlay the global variable ime with a char array and forward this array as argument to the sub routine. However, the code in the sub needs to be rewritten then, to handle an array instead of a string. |
Posted: Sun Apr 12, 2015 8:25 am Post subject: |
Posted: Sun Apr 12, 2015 8:36 am Post subject: |
Yes, I don`t analyze the code. Only this "If Target[I])<>" " Then WhiteSpace=0 " I want fix... |
Zvoc47
Posted: Sun Apr 12, 2015 7:29 pm Post subject: |
I solved it by using mid() |
Posted: Sun Apr 12, 2015 9:01 pm Post subject: |
when the assigned variable is a byte you can also use ASC() like : bSomeByte=asc(sSomestring, bIndex). The index is optional. _________________ Mark |
Zvoc47
Posted: Tue Apr 14, 2015 11:09 pm Post subject: |
The problem is solved. However, I'd sometimes have problems with ASC().
Sometimes ASC() would give me incorrect data type error. Can ASC convert 1 character (character as in byte, not byte and zero byte) from a string into a number that I can later convert into hex? I need this for my debugging program that reads from the program and data memory and prints out hex display like this
Code: | 0x002000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ |
Posted: Tue Apr 14, 2015 11:36 pm Post subject: |
asc() expects a string. And it will return a byte so it should be used on a numeric data type:
dim b as byte, s as string * 10, idx as byte
s="abcd"
idx=1
b=asc(s,idx)
but there is a catch : when you use the optional index, there is a protection so that you do not index past the end of the string. This means that when the string contains an end of string marker (0) it will end.
If you want direct access you can also consider overlay :
dim s as string * 80
dim b(80) as byte AT S OVERLAY
b() is not a byte array at the same location as String S. Thus b(1) would return the first character.
Using hex() you can print a numeric value. _________________ Mark |
Zvoc47
Posted: Fri Apr 17, 2015 3:44 pm Post subject: |
That means I would need to have an overlay over the whole memory. Is it possible to use C-style pointers instead? I need to be able to load any byte from anywhere in any memory and display it in hex format. |
Posted: Tue Apr 21, 2015 3:28 pm Post subject: |
why not using INP() function? _________________ Mark |
