Backspacing on input inputs backspaces!
Zvoc47
PostPosted: Sat Apr 11, 2015 11:17 pm    Post subject: Backspacing on input inputs backspaces! Reply with quote
When I try to input an 8 character long string and use backspaces, the backspaces actually enter the array! Instead, they should remove the last character in the input buffer, but why don't they?
Here's my code
Dim ime As String * 8
Input ime
Print ime
On the terminal, when you enter ABCD(backspace)(backspace)EFGH, the input doesn't let you enter GH because the buffer is filled with the backspaces. However, the output is ABEF.
Is there a way to go around this?
bzijlstra
Bascom Ambassador
PostPosted: Sat Apr 11, 2015 11:55 pm    Post subject: Search for inkey(), Waitkey, ischarwaiting and $timeout Reply with quote
Search in the help for inkey()
Returns the ASCII value of the first character in the serial input buffer.
var = INKEY()
var = INKEY(#channel)
Byte, Integer, Word, Long or String variable.
Channel
A constant number that identifies the opened channel if software UART mode
If there is no character waiting, a zero will be returned.
Use the IsCharWaiting() function to check if there is a byte waiting.
The INKEY routine can be used when you have a RS-232 interface on your uP.
The RS-232 interface can be connected to a comport of your computer.
As zero(0) will be returned when no character is waiting, the usage is limited when the value of 0 is used in the serial transmission. You can not make a difference between a byte with the value 0 and the case where no data is available.
In that case you can use IsCharwaiting to deterimine if there is a byte waiting.
WAITKEY , ISCHARWAITING , $TIMEOUT
Have fun
Ben Zijlstra
Paulvk
PostPosted: Sun Apr 12, 2015 12:20 am    Post subject: Reply with quote
Hello Zvoc47
If you are entering characters via a computer and terminal program
and want the backspace to remove characters in a buffer in the AVR
you need to write a sub that does this
I found that more than one value was sent by different terminal programs.
The good news is I have already done all the work.
In the blog section http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewforum&f=19
You will find my Web Servers
The code for a working command prompt with backspace is there as a separate sub that you can use in your own program.
Regards Paul
Zvoc47
PostPosted: Sun Apr 12, 2015 1:09 am    Post subject: Reply with quote
But which file is it?
Paulvk
PostPosted: Sun Apr 12, 2015 10:30 am    Post subject: Reply with quote
Ok I cut out the code so you can see it
now it depends which terminal program you use as to which character is backspace
some I have found send more than one character
here it is chr 8
so just attach an LCD to the avr and print the character number to the lcd
this is what I did to see what was received in the buffer
Uartrx is the sub that decides what to do with the data sent
Regards Paul
'--This will create a command line prompt so that
'--we can use rs232 to communicate with the AVR
 Charwaiting = Ischarwaiting()
   If Charwaiting = 1 Then
      Uart_char = Inkey()
      'Print Uart_char;
    If Len(uart_command) > 30 Then
    Uart_char = 13     'this is the Enter  key
     Select Case Uart_char
     Case 27                                                'the escape character to abort entry
         Print Prompt;                                      'Using a constant will let us change the prompt
         Uart_command = ""
    '--- here we backspace characters in the buffer
      Case 8
        Print Chr(8);                                       'the backspace
        Karpos = Len(uart_command)                          'find the length of Uart_command
        If Karpos > 0 Then                                  'if it has characters
             Delchar Uart_command , Karpos                  'delete last character
      Case 13
         Call Uartrx
         Uart_command = ""
      Case Else
         Uart_command = Uart_command + Chr(uart_char)       'this adds each character to the string
         Print Chr(uart_char);                              'this echos the commad back to the screen
                                                             'so the user can see what they have typed
     End Select
Zvoc47
PostPosted: Sun Apr 12, 2015 8:24 pm    Post subject: Reply with quote
Thanks.
If uart_command is long 78 characters, will
use up 157 bytes? I need to be cautious with the space I use and I must know how long the frame should be.
Paulvk
PostPosted: Mon Apr 13, 2015 9:45 am    Post subject: Reply with quote
You would need one byte for every character then there is another byte at the end of the string.
I see you are using Local variables this is good as it saves ram but remember they do not get cleared.
I use split to search strings it can replace mid() in many cases but it needs a global array
It has saved me a lot of code.
If you use a mega128 you should not run out of ram I have variables that are 1000 characters in my web servers
and still have spare ram I run out of flash before ram.
Also I use IsCharwaiting so that I do not stop and wait.
Regards Paul
Zvoc47
PostPosted: Mon Apr 13, 2015 2:54 pm    Post subject: Reply with quote
Don't worry. They don't need automatic clearing. And as much as I see, they are "popped" from the stack in such a way when the function is re-entered, they are overwritten with new ones. This means no memory leak Smile
This is my code:
$regfile = "xm128a1def.dat"
$Crystal=32000000
$hwstack=4160 ' This is because I put SPH to $2F instead of $3F
$swstack=16
$framesize=32
$baud = 115200
Config Serialin = Buffered , Size = 80
Config Serialout = Buffered , Size = 254
Declare Sub UsartInput(byref Target As String, byval MaxChars As Integer)
Enable interrupts
SPH=$2F
Call UsartInput(ime,8)
Print ime
Loop until lcase(ime)="over"
do
print "Over!"
Waitms 100
loop
   Local A As Byte
   Local Index As Integer
   Local WhiteSpace As Byte
   Local I As Byte
   InputAgain:
   Target=""
   Index=0
   WhiteSpace=0
   A=WaitKey()
   If A=8 Then
      If Index>0 Then
         Print Chr(8);" ";Chr(8);
         Decr Index
         Target=left(Target,Index)
      End if
   Else
      If A>31 And A<127 Then
         If Index<MaxChars Then
            Incr Index
            Target=Target+Chr(A)
            Print Chr(A);
   Loop Until A=13
   WhiteSpace=1
   If Index>0 Then
      For I=1 To Index
         If Mid(Target,I,1)<>" " Then WhiteSpace=0
      Next I
   If WhiteSpace=1 Then
      Print ""
      Goto InputAgain
   Print ""
End Sub
And I'm using ATXMEGA128A1.
And the best of all, the code works!
Except for waitms 100 waiting 1.5 seconds.[/code]
bzijlstra
Bascom Ambassador
PostPosted: Tue Apr 14, 2015 1:08 am    Post subject: pll Reply with quote
For the wait problem do a search on PLL.
in the wiki, the 7 inch display is driven bij an Atxmega128a1 and at the top of the program PLL settings.
Have fun
Ben Zijlstra
Zvoc47
PostPosted: Fri Apr 17, 2015 3:46 pm    Post subject: Reply with quote
I don't understand. I don't think I'm using PLL. I have a 32MHz crystal. Is there a way to check this?
