sstewart
Posted: Fri Apr 11, 2014 8:54 pm Post subject: Fast library for ILI9325 LCD |
I've attached a more complete 56 pixel font, going from 0 to capital Z. You have to set " Digit_font = 0 " or it displays a character 15 places back.
In the original Font36x56 it seems to use the Digit_font variable to enable a smaller font table for 0 to 9 by setting 0 in the ! location ( ascii 33 ), 1 in the " location ( ascii 34 ), etc... |
Posted: Fri May 16, 2014 6:30 pm Post subject: |
Hi mister,
I would like to use your program with an Arduino mega 2560 and
http://www.gotronic.fr/art-shield-ecran-tft-tactile-itead-20390.htm
my questions,
it is compatible with your program ? I understand, perhaps, I have to change the pin configuration.
must I use the 8bit or the 16bits version ?
many thanks to you answers
Jean-Pierre  |
Mrshilov
Posted: Fri Feb 20, 2015 10:14 am Post subject: |
Library updated.
Touch example is specially based on Arduino 2560. Sorry for the delay. You may use both 8 or 16 bit versions on it - depend on display model. |
boeseturbo
Arek2014
Posted: Wed Nov 18, 2015 11:31 pm Post subject: |
Hi.
i have lcd with 16bit interface.
http://allegro.pl/tft-lcd-2-8-ili9325-ekran-dotykowy-i-o-3-3v-5v-i5386083275.html
problem
Lcd_clear Black it not work properly, lcd put black color for while and set white !!!
Lcd_clear works with other colors !!!
when i use:
Lcd_clear Black
Lcd_set_pixel 10 , 10 , White
then lcd will go black with one pixel white
or
Lcd_clear Black
Lcd_text "Pixels" , 90 , 10 , White , Blue ' it works
Lcd_clear Black
Lcd_text "Pixels" , 90 , 10 , White , Black 'black will not do !!
BTW: i must had change this in library for my lcd.
Res_disp = 0 : Waitms 5 : Res_disp = 1 : Waitms 5 'Hardware Reset
when was: Res_disp = 0 : Waitms 5 : Res_disp = 1 'Hardware Reset
don't work
btw nokia n73 have better black color, better contrast - but soldering connector is horror
ili9325 on pcb is super
Pozdrawiam Arek |
Mrshilov
Posted: Thu Nov 19, 2015 1:30 am Post subject: |
If you using long wires or display has slow controller the speed may be too fast. Try to slower it:
Code: | Macro Send_data
Rs_disp = 1 : Nop : Nop : Wr_disp = 0 : Nop : Nop : Wr_disp = 1
End Macro
Macro Send_com
Rs_disp = 0 : Nop : Nop: Wr_disp = 0 : Nop : Nop : Wr_disp = 1
End Macro
Macro Send
End Macro |
Arek2014
Mrshilov
Posted: Fri Nov 20, 2015 6:36 am Post subject: |
Arek2014 wrote: | Lcd_clear Black
Lcd_text "Pixels" , 90 , 10 , White , Black 'black will not do !! |
Can you photo this error? |
Arek2014
Posted: Fri Nov 20, 2015 6:47 pm Post subject: |
my board lcd is v1.2 2.8 TFT240x320
problem is with black color and others colors near &H0000, i think, some test...
https://youtu.be/KnptuE9TsOw
code for this video is:
Macro Send_data
End Macro
Macro Send_com
Rs_disp = 0 :WAITuS 10 : Wr_disp = 0 :waitus 10 : Wr_disp = 1
End Macro
Macro Send
waitus 10 : Wr_disp = 0 : waitus 10 : Wr_disp = 1
End Macro
Lcd_clear White
Restore Color8x8 '****** Color Font Text
Lcd_text_color "Color Font text 'Color8x8'" , 55 , 65 , Black , White
Restore Color16x16
Lcd_text_color "Font 'Color16x16' " , 25 , 100 , Darkgreen , White
Wait 2
Lcd_clear White
Restore Font12x16
Lcd_text "Clear Screen" , 11 , 80 , Black , White '****** Clear Screen
Lcd_text " B&W" , 11 , 120 , Black , White
Wait 2
Lcd_clear Black
Lcd_text " " , 90 , 10 , blue , red
Lcd_clear White
Lcd_clear Black
Lcd_clear White
Restore Font12x16
Lcd_text "Clear Screen" , 11 , 80 , Brown , white
Lcd_text "with color" , 35 , 120 , Blue , white
Wait 2
Lcd_clear Red : Waitms 500
Lcd_clear Green : Waitms 500
Lcd_clear Blue : Waitms 500 |
Arek2014
Posted: Sun Nov 22, 2015 3:21 pm Post subject: |
i try run touchpad XPT2046, no succes....
when tap finger lcd feel it, but x,y are 0,0  |
Mrshilov
Posted: Sun Nov 22, 2015 4:08 pm Post subject: |
I test your source. All works fine. Check hardware. Especially this:
Code: | Dout_touch Alias Portd.3 : Config Dout_touch = Output 'XPT2046 Din Pin
Din_touch Alias Pind.4 : Config Din_touch = Input 'XPT2046 Dout Pin |
Dout_touch must be connected to Din LCD pin.
Din_touch must be connected to Dout LCD pin. |
Posted: Sun Nov 22, 2015 4:10 pm Post subject: Touch on ili9325 |
Have used the ILI9325 display in several projects, one of them is the Word Clock. It is published in this forum. Perhaps you can have a look at the touchscreen part of that program to get your touchscreen running.
Interrupt driven.
Have fun
Ben Zijlstra |
Arek2014
Posted: Sun Nov 22, 2015 10:14 pm Post subject: |
problem solved: pin dout was connected to lcd dout , same with din to lcd din
my mistake...
BTW: in future with library great will be circuit amtega vs lcd connections...
touchpad works fine with setup:
Const Portrait = 0 '0=Landscape, 1=Portrait
Const Rotate180 = 1 '0=Normal, 1=Rotate 180°
$nocompile
Sub Read_touch()
Touchx = 0 : Touchy = 0 : Clk_touch = 0 : Cs_touch = 0
Shiftout Dout_touch , Clk_touch , X_dout , 1 , 8 , 1 'X request
Waitms 3
Shiftin Din_touch , Clk_touch , Touchy , 1 , 12 , 1 'X answer
Shiftout Dout_touch , Clk_touch , Y_dout , 1 , 8 , 1 'Y Request
Waitms 3
Shiftin Din_touch , Clk_touch , Touchx , 1 , 12 , 1 'Y answer
Cs_touch = 1
If Touchy > 3500 Then Touchy = Touchy - 3500 Else Touchy = 0
Touchy = Touchy / 110
If Touchy > 239 Then Touchy = 239
If Touchx > 3500 Then Touchx = Touchx - 3500 Else Touchx = 0
Touchx = Touchx / 83
If Touchx > 319 Then Touchx = 319
Touchx = 319 - touchx
Touch_flag = 0
LCD still don't do lcd_clear black - i don't know what to do... |
Mrshilov
sstewart
Posted: Mon Apr 04, 2016 5:15 pm Post subject: |
When using 56 pixel height fonts, Blocksize and Colums need to be changed from bytes to words. Also added an extra 5ms wait after Res_disp pin high
Local Row As Byte , Block As Byte , Byteseach As Byte , Blocksize As Word
Local Colums As Word , Columcount As Byte , Rowcount As Byte , Stringsize As Byte
Res_disp = 0 : Waitms 5 : Res_disp = 1 : Waitms 5 'Hardware Reset |
