ksrm
Posted: Fri Mar 27, 2015 2:00 pm Post subject: I2Creceive Help |
Hello together,
is anybody out there, who has successfully programmed I2Creceive command ?
I2creceive ADR, ARRAY(), BTS, BTR:
Array() or VAR can be byte or word/ Integer, so I should calculate 4 words as 8 bytes as BTR at MASTER?
At SLAVE it looks like ARRAY(1) = GETADC(1), ARRAY(2) = GETADC(2), ....
SELECT CASE TWI_BTR
case 1: TWI = ARRAY(1) ? That does not work. Do I have to divide in High and Low?
Is there any example, which shows the real power of this command?
best regards
KSRM
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.7.8 ) |
Posted: Fri Mar 27, 2015 3:20 pm Post subject: |
Look at samples.. Folder I2C\Clock.bas |
ksrm
Posted: Fri Mar 27, 2015 6:09 pm Post subject: I2C\Clock.bas |
Thanks,
pls precise location to find, this AVR Forum, Bascom literature, ?
KSRM |
Posted: Fri Mar 27, 2015 9:22 pm Post subject: |
samples from bascom-avr sample folder : access them directly from bascom file open sample.
this is the file :
Code: | '------------------- AN 4 -----------------------------
' Copyright 1998-2002 MCS Electronics
' CLOCK.BAS
'This AN shows how to use the PCF8583 I2C clock device
'The PCF8583 is a PHILIPS device. Look at the datasheet for more details
'I have used the STK200 to test the program with a 8515
$regfile = "m88def.dat"
$lib "mcsbyte.lbx" ' use the byte lib since we do not need longs
$baud = 19200
$hwstack = 40
$swstack = 40
$framesize = 40
'declare used subs
Declare Sub Settime(byval S1 As Byte , Byval M1 As Byte , Byval H1 As Byte , Byval D1 As Byte , Byval Month1 As Byte)
Declare Sub Gettime()
'Declare variables
Dim Tm(5) As Byte
Dim I As Byte , Temp As Byte
'These are pointers to tm() for simple handling.
Dim S As Byte At Tm Overlay
Dim M As Byte At Tm + 1 Overlay
Dim H As Byte At Tm + 2 Overlay
Dim D As Byte At Tm + 3 Overlay
Dim Month As Byte At Tm + 4 Overlay
'configure the used port pin for I2C
Config I2cdelay = 5 ' default slow mode
Config Sda = Portc.4
Config Scl = Portc.5
' not needed since the pins are in the right state
'I2cinit
Call Settime(56 , 1 , 1 , 29 , 11) 'set time
Print Chr(27) ; "[2J"; 'clear screen
Print "PCF8583 Clock Sample"
Call Gettime
'since the values are stored in BCD format we can use Hex() to display them
Print Chr(27) ; "[2;2f"; ' VT100 emulation set pos to 2,2
Print Hex(h) ; ":" ; Hex(m) ; ":" ; Hex(s) ; " Err:" ; Err
Sub Gettime()
'there are 2 ways to get the time. With low level i2c calls or with a high level call
'first the high level call
Tm(1) = 2 ' point to second register
I2creceive &HA0 , Tm(1) , 1 , 5 ' write the second address and get 5 bytes back
'i2creceive will first write 1 byte from tm(1) which is 2, and then will read 5 bytes and store it onto tm(1)-tm(5)
'and optional with low level calls
' For I = 1 To 5
' Temp = I + 1
' I2cstart
' I2cwbyte &HA0 'write addres of PCF8583
' I2cwbyte Temp 'select register
' I2cstart 'repeated start
' I2cwbyte &HA1 'write address for reading info
' I2crbyte Tm(i) , Nack 'read data
' Next
' I2cstop
Sub Settime(s1 As Byte , M1 As Byte , H1 As Byte , D1 As Byte , Month1 As Byte)
'values are stored as BCD values so convert the values first
Tm(1) = Makebcd(s1) 'seconds
Tm(2) = Makebcd(m1) 'minutes
Tm(3) = Makebcd(h1) 'hours
Tm(4) = Makebcd(d1) 'days
Tm(5) = Makebcd(month1) 'months
I2cstart 'generate start
I2cwbyte &HA0 'write address
I2cwbyte 0 'select control register
I2cwbyte 8 'set year and day bit for masking
I2cwbyte &HA0 'write mode
I2cwbyte 2 'select seconds Register
For I = 1 To 5
I2cwbyte Tm(i)
Next 'write seconds
I2cstop
_________________ Mark |
