mcupwr
snipsnip
Posted: Sun Mar 15, 2015 2:32 pm Post subject: |
you should be able to mod something from here..
http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm
copied from above.
plotLine(x0,y0, x1,y1)
dx=x1-x0
dy=y1-y0
D = 2*dy - dx
plot(x0,y0)
y=y0
for x from x0+1 to x1
if D > 0
y = y+1
'maybe just randomise whether x,y are plotted here?????
plot(x,y)
D = D + (2*dy-2*dx)
else
plot(x,y)
D = D + (2*dy) |
JC
Joined: 15 Dec 2007 Posts: 585 Location: Cleveland, OH
Posted: Tue Mar 17, 2015 1:38 am Post subject: |
Remember you can only have one math function per line, in Bascom.
This is a line plotting routine in Bascom, using Bresenham's algorithm.
Obviously this isn't the full program, but perhaps it will help get you started.
Glcdline:
'Draw a Straight Line on the GLCD, Pixel Coordinates.
'Use Bresenham's algorithm.
'On Entry have: (GX1,GY1) and (GX2,GY2)
'GX1, GX2: Columns: 0-127, Left to Right
'GY1, GY2: Rows: 0-63, Top Down
'Supports the Inverse Mode Flag, as does Text.
'Error Checks for valid location prior to plotting, (within GPixSet).
'Uses GPixSet
'Set Pixel Value for subsequent GPixSet routine
If I = 1 Then
Pv = 0 'Pixel = Off, Inverted
Pv = 1 'Pixel = On, black on Clear
'First look at Delta X & Delta Y, see slope of line, most flat or vert
Gdx = Gx2 - Gx1
Gdx = Abs(gdx)
Gdy = Gy2 - Gy1
Gdy = Abs(gdy)
Vert = 0 'Line is mostly horz, Slope < 45 degrees
If Gdy > Gdx Then
Vert = 1 'Line is mostly vertical, Slope > 45 deg
'If line is mostly vertical, swap the coordinates
If Vert = 1 Then
Swap Gx1 , Gy1
Swap Gx2 , Gy2
'If line is R to L, then Swap
If Gx1 > Gx2 Then
Swap Gx1 , Gx2
Swap Gy1 , Gy2
Gdx = Gx2 - Gx1
Gdy = Gy2 - Gy1
Gdy = Abs(gdy)
Lerr = Gdx / 2
Gly = Gy1
If Gy1 < Gy2 Then
Ystep = 1
Ystep = -1
For Glx = Gx1 To Gx2 'Plot the points
If Vert = 1 Then
'Plot (Gly,Glx)
Pc = Low(gly)
Pr = Low(glx)
'Plot (Glx,Gly)
Pr = Low(gly)
Pc = Low(glx)
Gosub Gpixset 'Plot the point
Lerr = Lerr - Gdy
If Lerr < 0 Then
Gly = Gly + Ystep
Lerr = Lerr + Gdx
Next Glx
Posted: Tue Mar 17, 2015 9:06 am Post subject: Re: Pset to Line |
mcupwr wrote: |
X,Y are words... |
Think that PSET expects bytes for X and Y. _________________ www.evertdekker.com Bascom code vault |
