Wilfred
Posted: Sun Jan 04, 2015 6:34 pm Post subject: ESP8266 WIFI to serial board gets NTP time |
Quote: | Hello friends,
Here a first try with my newest little toy. this thing is so simple, even I can write some code for it to get it going
There is no code for when something goes wrong in the communication. (when the NTP server says huh?, the program stops)
but for a quick try out this does the thing.
My xmega's internal clock is waaay to fast (several minutes every hour) . so I have to come up with a solution to slow it down
Have fun!
Wilfred. |
Code: |
' ESP8266 pinout
' top view
' CH_PD to GND to activate (Chip powers down (when high))
' _ _ _ ________
' | |_| |_| |_| antenna on top
' GND GPIO2 GPIO0 RX
' TX CH_PD RST Vcc
'VCC=3.3V !
$regfile = "xm128a3udef.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 40
$framesize = 64
Const Ssid = "Your ssid"
Const Passwort = "your password"
Const Offset_gmt = 3600 'in seconds. I live in GMT+1
Dim Sec_to_ntp_update As Integer
Config Osc = Enabled , 32mhzosc = Enabled ' enable 2 MHz and 32 MHz internal oscillators
'Select the oscillator source for the system clock and prescaler (this must match with $crystal = XXXXXX).
'The following configure the internal 32MHz oscillator as system clock without prescaler so the system
'clock is 32MHz which Match With $crystal = 32000000
$lib "datetime.lbx"
$lib "xmega.lib" : $external _xmegafix_clear : $external _xmegafix_rol_r1014
'First Enable The Osc Of Your Choice , make sure to enable 32 KHz clock or use an external 32 KHz clock
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
'For the CLOCK we use the RTC so make sure the 32 KHZ osc is enabled!!!
'configure the systemclock
Config Clock = Soft , Rtc = 1khz_int32khz_ulp , Gosub = Sectic ' we select the internal 1 KHz clock from the 32KHz internal oscillator
Config Priority = Static , Vector = Application , Lo = Enabled ' the RTC uses LO priority interrupts so these must be enabled !!!
' COM1 --> Usartc0 --> RX=pc2(pin18) TX=pc3(pin19)
Config Com1 = 9600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM1:" For Random As #1
'pin nummer 40 41 42 43 39 38
Config Lcdpin = Pin , Db4 = Porte.4 , Db5 = Porte.5 , Db6 = Porte.6 , Db7 = Porte.7 , E = Porte.3 , Rs = Porte.2
Config Lcd = 16 * 2
Config Pina.2 = Output
Led1 Alias Porta.2
Config Date = Dmy , Separator = Minus
Dim Rxstring As String * 100
Dim Check As Bit
' Ntp Stuff
Dim Tt(4) As String * 1
Dim Ss(4) As Byte
Dim L1 As Long At Ss Overlay ' Overlay a long variable to receive-string
Dim L2 As Long ' with overlay you need no transfer from the byte-array to a long-variable
Declare Sub Init_esp8266
Declare Sub Ntp
Declare Sub Wait_for_string(byval B As String)
Declare Function Read_string() As String
'init
Sec_to_ntp_update = 600
Cls
Locate 1 , 1 : Lcd "init ESP"
Init_esp8266
Locate 1 , 1 : Lcd "Getting NTP time"
Ntp ' we don't have the correct time so lets start with that
Cls
If Sec_to_ntp_update = 0 Then ' update time every hour. At least when you set the seconds to 3600
Ntp
Locate 1 , 9 : Lcd Time$
Locate 2 , 9 : Lcd Date$
Locate 1 , 1 : Lcd Sec_to_ntp_update
Sectic:
Decr Sec_to_ntp_update
'*********************** Ask Time From Timeserver Esp8266: ******************************************
Sub Ntp
Print "AT+CIPMUX=1"
Waitms 100
Print "AT+CIPSTART=1," ; Chr(34) ; "UDP" ; Chr(34) ; "," ; Chr(34) ; "193.67.79.202" ; Chr(34) ; ",37"
Waitms 100
Print "AT+CIPSEND=1,3"
Waitms 100
Print "X" 'send capital X to ntp server and you obtain the time
Wait_for_string "+IPD,1,4:" 'behind the : will be the time.... 4 bytes
Reset Check
Rxstring = Read_string()
Wait_for_string "OK" 'reply from ESP8266
Loop Until Check = 1 'check is set in wait_for string
Reset Check
Tt(1) = Mid(rxstring , 4 , 1) 'from big endian to little endian
Tt(2) = Mid(rxstring , 3 , 1) 'swap the bytes
Tt(3) = Mid(rxstring , 2 , 1)
Tt(4) = Mid(rxstring , 1 , 1)
Ss(1) = Asc(tt(1)) 'this is L1 split in 4s by overlay
Ss(2) = Asc(tt(2))
Ss(3) = Asc(tt(3))
Ss(4) = Asc(tt(4))
L2 = L1 + 1139293696
L2 = L2 + Offset_gmt
Time$ = Time(l2) 'set the time
Date$ = Date(l2) 'set the date
Waitms 250
Print "AT+CIPCLOSE=1"
End Sub
Sub Init_esp8266
'init the ESP8266
'AT+RST
'AT+CIPMUX=1
'AT+CWMODE=3
'AT+CIPSERVER=1,23
'AT+CWLAP 'we don't do this one because we allready know our wifi network ssid and password
'AT+CWJAP="ssid","password"
Print "AT+RST" 'reset the ESP8266
Wait_for_string "ready" 'reply from ESP8266
Reset Check
Print "AT+CIPMUX=1"
Waitms 100 'the answer here is "link is builded" but i don't know if that's changed in another version
Print "AT+CWMODE=3"
Waitms 100
Print "AT+CIPSERVER=1,23"
Reset Check
Print "AT+CWJAP=" ; Chr(34) ; Ssid ; Chr(34) ; "," ; Chr(34) ; Passwort ; Chr(34)
Reset Check
Waitms 250
End Sub
Sub Wait_for_string(byval B As String) As String
Local Ii As Byte
Local Cc As Byte
Ii = 1
M1:
Cc = Inkey()
If Cc <> Mid(b , Ii , 1) Then
Goto M1
Else
Incr Ii
If Ii > Len(b) Then Goto M2
Goto M1
M2:
Set Check
End Sub
Local Cc As Byte
Local Sss As String * 100
Local Stringlen As Integer
Sss = ""
While Cc <> Chr(13)
Cc = Inkey()
If Cc = Chr(10) Then Cc = " "
Sss = Sss + Chr(cc)
Wend
Stringlen = Len(sss) - 1
Read_string = Left(sss , Stringlen)
End Function
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.8 ) |
Flyby123
Posted: Wed Jan 07, 2015 11:49 am Post subject: |
Hi Wilfred, what/which firmware did you use for (ESP-01?)?
Nice work, thanks for posting.
Jim |
Wilfred
Posted: Wed Jan 07, 2015 3:16 pm Post subject: |
Hi Jim,
thanks
I don't know yet, as I am not at home until tomorrow
But If you look at the AT commands, and the AT commands of your version, and they match
you can probably use this code.
Wilfred |
Wilfred
Posted: Thu Jan 08, 2015 8:34 pm Post subject: |
Jim,
the version is 0.9.2.4 |
bzijlstra
Posted: Sun Feb 22, 2015 8:36 pm Post subject: small miracle... |
Wilfred. Now I got my own module I see what a small miracle this esp8266 is. Thanks for your code. It gives a good head start.
Have fun
Ben Zijlstra |
Evert :-)
Wilfred
Posted: Tue Feb 24, 2015 10:17 am Post subject: |
Hi Ben,
Nice to do something back (after hunting your website for years )
that was exactly what this code was intended for.
To get you started.
73, Wilfred |
Evert :-)
Dave
Posted: Thu Mar 05, 2015 5:25 am Post subject: |
Wilfred,
Thanks for posting. That will be a big help.
Evert,
I've been playing with an esp-01 running Lua. So far I can run only about two pages of code before it's out of memory. I hope that is something I'm doing wrong but many people out there complain about memory so I don't know. Still I have it sending me an email when ever some event happens. That by it's self is useful.
The esp8266 comes in several flavors. The esp-01, esp-02, esp-03... I've tried the esp-01 and esp-03. The esp-01 is working as described but the two esp-03 that I tried don't work. AT commands did not work at all. I tried loading Lua and that sort of works with lot of problems. I'm taking a chance and ordered five esp-12. All for about 18 bucks from a US seller. The seller claims they have all been tested. The esp-12 have the io that makes the most sense. So i'll keep you posted.
Dave |
hg7kaz
Posted: Sat Mar 14, 2015 3:04 pm Post subject: Re: ESP8266 WIFI to serial board gets NTP time |
I want to try this program on my xm256a3b board.
Here are the program's first some rows:
Code: | $regfile = "xm256a3bdef.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 40
$framesize = 40
$lib "xmega.lib"
$lib "i2c_twi.lbx" '
Config Clock = Soft , Rtc = 1KHZ_INT32KHZ_ULP , gosub = sectic
Dim Sec_to_ntp_update As Integer |
I receive many error messages after compiling the program.
These errors show signs of one single row: config clock = soft, rtc = 1KHZ_INT32KHZ_ULP, gosub = sectic
What's wrong? |
bzijlstra
Posted: Sat Mar 14, 2015 6:07 pm Post subject: wiki |
There is a item in the wiki. 7 inch display using i2c. |
Tubeampman
Posted: Tue Mar 31, 2015 11:18 pm Post subject: |
Hi
thanx for sharing Your code
Am into making a selfadjusting alarmclock and was suposed to use a gps, but this module makes the solution far better.
Your program Works Perfect, but now i want to correct a timekeeping DS3221.
Am able to do this by getting the byte variables _sec _min _ and _day which comes With the config clock = soft.
Is there a way to get lets say these bytevariables web_sec web_min and web_hour directly from L2 without using the config clock ?.
Best regards
Øyvind |
