snipsnip
Posted: Thu Feb 26, 2015 6:49 am Post subject: problem with string / function |
Hi all,
I've got a problem with a function that returns a string of 21 characters. Works ok with 20 characters.
For some reason when the string is 21 chrs long an extra (null) "thingy" is added to it which prints out as a white square after the actual string.
I thought it was a problem with the GLCD library (ssd1289), but no, it works ok when I give it a 21+ chr variable in the main loop (global)
I've disabled all other functions - in case it was an external problem, but still the same
I've commented out all code in the function below, but still the same - nothing to do with the contained code in the function.
Trimming the string makes no difference either?
Got me stuffed, Any ideas?
cheers
, Declare Function Timestamp(byval Timezone As Word , Byval Plusneg As Byte) As String * 23
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Function Timestamp(timezone As Word , Plusneg As Byte)as String
'Local X As Byte
'Local Timez As String * 8 : Local Datez As String * 8 : Local Dayz As String * 4
'Local Tmp As String * 2 : Local Tmp1 As String * 2 : Local Tmp2 As String * 2 : Local Tmp3 As String * 23
'Local Sissec As Long
' Timez = Commapos(1 , "GPRMC")
' Timez = Left(timez , 6)
' Tmp = Left(timez , 2)
' Tmp1 = Mid(timez , 3 , 2)
' Tmp2 = Right(timez , 2)
' Timez = Tmp + ":" + Tmp1 + ":" + Tmp2
' Datez = Commapos(9 , "GPRMC")
' Datez = Left(datez , 6)
' Tmp = Left(datez , 2)
' Tmp1 = Mid(datez , 3 , 2)
' Tmp2 = Right(datez , 2)
' Datez = Tmp + "/" + Tmp1 + "/" + Tmp2
' Sissec = Syssec(timez , Datez)
' Timezone = Timezone * 3600
' If Plusneg = 0 Then Sissec = Sissec - Timezone
' If Plusneg = 1 Then Sissec = Sissec + Timezone
' Datez = Date(sissec)
' Timez = Time(sissec)
' X = Dayofweek(sissec)
'Dayz = Lookupstr(x , Weekdays)
'Timestamp = Dayz + Timez + " " + Datez
Timestamp = "123456789012345678901"
End Function
Posted: Thu Feb 26, 2015 9:45 am Post subject: |
Best to show a complete sample : include $regfile, $hwstack,$swstack and $framesize. And how it is used.
But my guess :
- check if the string you assign it to is long enough to hold that result.
- check if $framesize is big enough to hold a temp string (depends on how you use the function)
In any case, it works for me. _________________ Mark |
snipsnip
Posted: Thu Feb 26, 2015 10:04 am Post subject: |
Thanks,
Yep My bad Had a temp variable too small to accept the return.
I seriously spent MANY MANY hours checking the program, I knew to look for this problem as the #1 culprit.
and its not like its a massive / complex beast of a program.
Think I might have lysdexia.
Cheers. |
Posted: Fri Feb 27, 2015 10:49 am Post subject: |
this forum is a friendly corner, and when you spend to much time when you turn crazy it is the place to ask help of the friends
I did it , I do it, and I will do it again !
jp |
