Micha
Posted: Sun Jan 18, 2015 5:35 pm Post subject: PDF-Update not working |
I use the current version 2.0.7.8 BasomAVVR and have problems with Download and Update PDF-Files.
I use in Menu Tools and click on PFD-Update. The windows open and I Click to Button Check.
Many Files generates Errors. Look at the follow Log.
Did anybody know this problem?
Does exist a solution?
Start checking existing pdf files
Found : at90s1200.pdf
Found : at90s2313.pdf
Found : at90s2323_2343.pdf
Found : at90s2333_4433.pdf
Found : at90s4414_8515.pdf
Found : at90s4434_8535.pdf
Found : at86rf401.pdf
Found : at90pwm1.pdf
Found : at90pwm216_316.pdf
Found : at90pwm2_3.pdf
Found : attiny11_12.pdf
Found : attiny13.pdf
Found : attiny13a.pdf
Found : attiny15.pdf
Found : attiny1634.pdf
Found : attiny87_167.pdf
Found : attiny20.pdf
Found : attiny22.pdf
Found : attiny2313.pdf
Found : attiny2313a_4313a.pdf
Found : attiny24_44_84.pdf
Found : attiny25_45_85.pdf
Found : attiny26.pdf
Found : attiny261_461_861.pdf
Found : attiny2313a_4313.pdf
Found : attiny43u.pdf
Found : attiny441_841.pdf
Found : attiny48_88.pdf
Found : attiny828.pdf
Found : atmega103_603.pdf
Found : atmega640_1281_1280_2561_2560.pdf
Found : atmega128.pdf
Found : atmega1284.pdf
Found : atmega1284p.pdf
Found : at90can32_64_128.pdf
Found : atmega128rfa1.pdf
Found : atmega161.pdf
Found : atmega162.pdf
Found : atmega163.pdf
Found : atmega164a_324a_644a.pdf
Found : atmega164apa_324apa_644apa.pdf
Found : atmega164p_324p_644p.pdf
Found : atmega165.pdf
Found : atmega48_88_168.pdf
Found : atmega48p_88p_168p_328p.pdf
Found : atmega169pa_329pa_649pa_3290pa_6490pa.pdf
Found : atmega169_revatoe.pdf
Found : atmega169p.pdf
Found : atmega16a.pdf
Found : atmega16.pdf
Found : atmega16m1_32m1_64m1_32c1_64c1.pdf
Found : atmega8u2_162_32u2.pdf
Found : atmega16u4_32u4.pdf
Found : atmega323.pdf
Found : atmega164pa_324pa_644pa.pdf
Found : atmega325p_3250p.pdf
Found : atmega325_3250_645_6450.pdf
Found : atmega48_88_168_328.pdf
Found : atmega329_3290_649_6490.pdf
Found : atmega32a.pdf
Found : atmega32.pdf
Found : atmega406.pdf
Found : atmega164_324_644.pdf
Found : atmega165a_pa_325a_pa_3250a_pa_645a_p_6450a_p.pdf
Found : atmega64.pdf
Found : atmega8515.pdf
Found : atmega8535.pdf
Found : atmega48a_88a_168a.pdf
Found : atmega8.pdf
Found : atmega8u2.pdf
Found : at90usb646_647_1286_1287.pdf
Found : at90usb82_162.pdf
Found : atxmega64a1_128a1_192a1_256a1_384a1.pdf
Found : atxmega64a1u_128a1u.pdf
Found : atxmega64a3_128a3_192a3_256a3.pdf
Found : atxmega64a3u_128a3u_192a3u_256a3u.pdf
Found : atxmega16a4u_32a4u_64a4u_128a4u.pdf
Found : atxmega64b1_128b1.pdf
Found : atxmega64d3_128d3_192d3_256d3.pdf
Found : atxmega16d4_32d4_64d4_128d4.pdf
Found : atxmega16a4_32a4_64a4_128a4.pdf
Found : atxmega8e5_16e5_32e5.pdf
Found : atxmega_256a3b.pdf
Found : atxmega_256ab3u.pdf
Found : atxmega_256a3u.pdf
Found : atxmega384c3.pdf
Preparing to check server...
Checking : http://www.mcselec.com/atmelpdf/at90s1200.pdf
Checking : http://www.mcselec.com/atmelpdf/at90s2313.pdf
Checking : http://www.mcselec.com/atmelpdf/at90s2323_2343.pdf
Checking : http://www.mcselec.com/atmelpdf/at90s2333_4433.pdf
Checking : http://www.mcselec.com/atmelpdf/at90s4414_8515.pdf
Checking : http://www.mcselec.com/atmelpdf/at90s4434_8535.pdf
Checking : http://www.mcselec.com/atmelpdf/at86rf401.pdf
Checking : http://www.mcselec.com/atmelpdf/at90pwm1.pdf
Checking : http://www.mcselec.com/atmelpdf/at90pwm216_316.pdf
Checking : http://www.mcselec.com/atmelpdf/at90pwm2_3.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny11_12.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny13.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny13a.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny15.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny1634.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny87_167.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny20.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny22.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny2313.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny2313a_4313a.pdf
Error, could not retrieve header
Checking : http://www.mcselec.com/atmelpdf/attiny24_44_84.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny25_45_85.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny26.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny261_461_861.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny2313a_4313.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny43u.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny441_841.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny48_88.pdf
Checking : http://www.mcselec.com/atmelpdf/attiny828.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega103_603.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega640_1281_1280_2561_2560.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega128.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega1284.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega1284p.pdf
Checking : http://www.mcselec.com/atmelpdf/at90can32_64_128.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega128rfa1.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega161.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega162.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega163.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega164a_324a_644a.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega164apa_324apa_644apa.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega164p_324p_644p.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega165.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega48_88_168.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega48p_88p_168p_328p.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega169pa_329pa_649pa_3290pa_6490pa.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega169_revatoe.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega169p.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega16a.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega16.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega16m1_32m1_64m1_32c1_64c1.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega8u2_162_32u2.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega16u4_32u4.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega323.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega164pa_324pa_644pa.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega325p_3250p.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega325_3250_645_6450.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega48_88_168_328.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega329_3290_649_6490.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega32a.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega32.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega406.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega164_324_644.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega165a_pa_325a_pa_3250a_pa_645a_p_6450a_p.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega64.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega8515.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega8535.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega48a_88a_168a.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega8.pdf
Checking : http://www.mcselec.com/atmelpdf/atmega8u2.pdf
Checking : http://www.mcselec.com/atmelpdf/at90usb646_647_1286_1287.pdf
Checking : http://www.mcselec.com/atmelpdf/at90usb82_162.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega64a1_128a1_192a1_256a1_384a1.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega64a1u_128a1u.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega64a3_128a3_192a3_256a3.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega64a3u_128a3u_192a3u_256a3u.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega16a4u_32a4u_64a4u_128a4u.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega64b1_128b1.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega64d3_128d3_192d3_256d3.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega16d4_32d4_64d4_128d4.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega16a4_32a4_64a4_128a4.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega8e5_16e5_32e5.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega_256a3b.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega_256ab3u.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega_256a3u.pdf
Checking : http://www.mcselec.com/atmelpdf/atxmega384c3.pdf
Done
Posted: Sun Jan 18, 2015 9:26 pm Post subject: |
I got only this error :
Checking : http://www.mcselec.com/atmelpdf/atxmega16c4-32c4.pdf
but that is because this is a new file and is not present on the MCS server yet.
The MCS server runs a script each day to check all pdfs on the atmel server.
if urls are invalid (atmel changes them) the urls are changed.
bascom always checks the mcs server so you always get the files which are at most 1 day old.
in this case it seems there was a problem with the connection or server load.
simply try again. _________________ Mark |
Micha
Posted: Sun Jan 18, 2015 10:10 pm Post subject: |
Thanks. I try it later. |
Posted: Sun Jan 18, 2015 10:21 pm Post subject: |
I tried it just before posting. I did not had any other reports, but does not mean much in all cases.
the server is backed up in the morning , that is my morning . So users from Austrlia could have some problems because of the increased server load. I would not expect users from Europe to have problems, other than regular network problems that occur around the world. _________________ Mark |
Micha
Posted: Mon Jan 19, 2015 6:28 am Post subject: |
I have Proplems with my provider "Kabel BW". Ping does not work.
It's possible that this is the reason for this problem? |
Posted: Mon Jan 19, 2015 10:20 am Post subject: |
ping should work. _________________ Mark |
Micha
Posted: Mon Jan 19, 2015 6:12 pm Post subject: Test from other location |
I have tryed to make PDF-Update with an other PC and other location.
On this PC I have an other licenze.
On this location an different provider ist used and Ping works!
I have different files than can't download. But many errors: Header could not received.
The problem is with other PC and Provider more or less the same.
I don't know what make that problem. |
Posted: Tue Jan 20, 2015 12:04 am Post subject: |
on this other PC the update works? (because ping works)
or is there a problem too?
when ping does not work it is because the server does not support ping or that the port is not open. that could be in your network or your pc. while blocking ping for input is normal, i never seen it for outgoing.
the download tool uses the PC internet settings. if these are ok, and there is no firewall or other software preventing to download pdf files, it should work. you can try to manual download a pdf file from the server.
your internet explorer is working ok? _________________ Mark |
Micha
Posted: Tue Jan 20, 2015 6:43 am Post subject: Test with third PC |
A friend of me uses the currend verion, too.
He has the same problems. Some PDF-Files will not be downloaded.
I have tested his Ping and is perfect!
He uses a other provider as me and the second pc I tested.
So we have 3 PC, 3 provider, 2 PC with perfect Ping and no PDF-Updade works.
At all pc the same problem. All pc locations are in germany.
I will try to download the files manuelly and you get info about the result. |
Posted: Tue Jan 20, 2015 10:43 am Post subject: |
you can best write to support. just refer to this topic.
Tomi can run some tests where we check your IP and the server web server response. _________________ Mark |
Micha
Posted: Tue Jan 20, 2015 5:22 pm Post subject: I've written a support-mail |
Hello,
I've testet do download the Files manually. by browser and it works.
This only for Info here.
I've now written a supportmail ti (I hope) to solve this problem.
Thanks for help! |
Dibor
Posted: Tue Jan 20, 2015 8:49 pm Post subject: |
Hello.
I got same issue.
Also while pdf checking Bascom IDE is stuck and only www.mcselec.com is not responding via browser.
After killing BASCOM process website is coming back after 1 minute.
Regards. |
Posted: Tue Jan 20, 2015 10:14 pm Post subject: |
Which file gives the first error?
That during the download the ide becomes less responsive is because the way the used tcp/ip component work. In the mean time we determined that the server does not get the head request.
If you write to support you can run some tests too.
This is very hard to test since it always work from our 2 locations. I also ran a test : running a VM with ubuntu and wine on a win-7 PC and it also works. Since the code was not changed for a long time it is a bit of a mystery why it does not work for some files. _________________ Mark |
Dibor
Posted: Wed Jan 21, 2015 10:02 am Post subject: |
it seems to happen on the same file. don't know why a HEAD to the server could work out different but if you write to support i can enable a test version that will give result codes. _________________ Mark |
