Posted: Wed Jan 07, 2015 7:17 pm Post subject: Inserting bytes into a word
I know i should probably know the answer to this, but its been awhile since I had done it.
I do know you can break a word down into two bytes by using Low() and High().
But what about the other way around? I have a byte array and I need to insert bytes at location 5, and 6 into a word variable. as bytes(5) and bytes(6) make up the low/high of a word.
If you need only word-spaced access, you can overlay the byte array with a word array, so wordarr(3) would access bytes(5) and (6).
Assumed CONFIG BASE<>0.
You won't be able to access for example bytes(4) and (5) as a word. And sure, Makeint() will work.
