GPS Functions
Goto page 1, 2  Next
snipsnip
PostPosted: Tue Dec 23, 2014 2:20 am    Post subject: GPS Functions Reply with quote
hi all,
just want to share and collect GPS functions
only got a couple of rough ones at the moment - haven't really optimised them yet (WIP)
please if you have GPS functions to share, post them here Smile
1st one below sucks out data fields between commas - needs header info and the start comma number
Function Commapos(startcomma As Byte , Header As String) As String
Local N As Byte , Q As Byte , Comma As Byte , X As String * 1 , Endcomma As Byte , Ch As String * 1 , Ggps As String * 5
Local Gps1 As String * 80
'CLEAR BUFFER, LOOPS 'TILL NOTHING LEFT
  While Ischarwaiting() > 0
   Ch = Inkey()
   Wend
'SCROLL BUFFER AND GET GET THE SENTENCE THAT STARTS WITH "HEADER"  IE - GPRMC,GPGGL......
    Ggps = ""                                               'CLEAR GGPS JUST IN CASE
    While Ggps <> Header
       Ch = Inkey()
       Loop Until Ch = "$"
    Input , Gps1 Noecho                                     'GET A FULL SENTENCE
    Ggps = Left(gps1 , 5)                                   'CHECK IT FOR A MATCH
    Wend
 'n=start posistion  q=end posistion
 'q also = grab string length ie- mid(var,n,q)
 'find index(N) for start comma posistion
  Comma = 0 : N = 0 : Q = 0                                 'INITIALISE VARIABLES
  Endcomma = Startcomma + 1
    While Comma < Startcomma                                'COMMA HOLD THE COMMA COUNT AMOUNT
     Incr N
     X = Mid(gps1 , N , 1)
     If X = "," Then Incr Comma
     Wend
  'find index(Q) for end comma posistion
    Q = N
    While Comma < Endcomma
     Incr Q
     X = Mid(gps1 , Q , 1)
    Wend
 'not quite right-TWO COMMAS IN A ROW CAUSE PROBLEMS  - fix it here Wink
 N = N + 1
 If Q = N Then
 Cls                                                        'START COUNT AND END COUNT NEED A SEPERATION OF MORE THAN 0 Smile
   Lcd "GOT A DOUBLE"                            'just for debugging - maybe a good way to check for a VALID sentence
   Wait 1
  N = N - 1
  Q = Q - N
  Q = Q - 1
  N = N + 1
  'suck out the needed string componant
  Commapos = Mid(gps1 , N , Q)
  End Function
second one below converts nmea lat lon to signed degree format
field 1 is the lat or lon to convert, field 2 is N,S,E or W
inputs are strings, output is a single.
Function Convert(field1 As String , Field2 As String , ) As Single
Local Y As String * 7 , X As String * 3 , Z As Byte , W As Single
Z = 0 : X = "" : Y = ""
Z = Len(field1)
Y = Right(field1 , 7)
If Z = 9 Then X = Left(field1 , 2)
If Z = 10 Then X = Left(field1 , 3)
 W = Val(x)
 Convert = Val(y)
 Convert = Convert / 60
 Convert = Convert + W
'make it neg for south or west
 If Field2 = "S" Then Convert = -convert
 If Field2 = "W" Then Convert = -convert
 Convert = Convert
 End Function
snipsnip
PostPosted: Tue Dec 23, 2014 9:42 am    Post subject: Reply with quote
Found distance and some more here http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=10035&highlight=gps+string
Thanks Glena. Very Happy
'======[ Calc Distance of lat lon ]=============================================
Sub CalcBearing(CB_Lat1, CB_Lon1, CB_Lat2, CB_Lon2)
'using arcsin formula rather than arccos
'calc dist and bearing in radians of pos2 from pos1
'positions in radians
'result in nm and true bearing from north
'x1,y1 are long,lat of source, x2, y2 long, lat of dest
    Local CB_X1    as single   : Local CB_Y1 As single
    Local CB_X2    as single   : Local CB_Y2 As single
    Local CB_Dx    as single   : Local CB_Dy As single
    Local CB_Cosd  as single
    Local CB_Nu    as single
    Local CB_De    as single
    Local CB_Be    as single
    Local CB_Ad    as single
    Local CB_Dq    as single
    CB_Dx= CB_Lon2 - CB_Lon1   : CB_Dx= CB_Dx / 2
    CB_Dx= Sin(CB_dx)          : CB_Dx= CB_Dx * CB_Dx
    CB_Dy= CB_Lat2 - CB_Lat1   : CB_Dy= CB_Dy / 2
    CB_Dy= Sin(CB_dy)          : CB_Dy= CB_Dy * CB_Dy
'the arc cos function fails for very small dx
'cosd = Sin(Y1) * Sin(Y2) + Cos(Y1) * Cos(Y2) * Cos(X2 - X1)
'so use:
'd=2*asin(sqrt((sin((lat1-lat2)/2))^2 + cos(lat1) * cos(lat2) *(sin((lon1 -lon2) / 2)) ^ 2))
'be=atan((sin(lon1-lon2)*cos(lat2))/(cos(lat1)*sin(lat2)-sin(lat1)*cos(lat2)*cos(lon1-lon2))
    CB_X1= sin(CB_lat1)  : CB_Y1= Cos(CB_lat1)
    CB_X2= sin(CB_lat2)  : CB_Y2= Cos(CB_lat2)
    CB_Dx= CB_Dx * CB_Y1 : CB_Dx= CB_Dx * CB_Y2
    CB_De= CB_Dy + CB_Dx : CB_De= Sqr(CB_de)
    CB_Dq= Asin(CB_de)   : CB_Dq = CB_Dq * 2.0   ' Dq gives distance in radians
    GPSDist = CB_Dq * CB_Crad2meters
    'now calc bearing
    CB_Dx= CB_Lon2 - CB_Lon1 : CB_Nu= sin(CB_Dx) : CB_Nu= CB_nu * CB_Y2
    CB_De= cos(CB_Dx) :
    CB_De= CB_De * CB_Y2 : CB_De= CB_De * CB_X1
    CB_X2= CB_X2 * CB_Y1 : CB_De= CB_X2 - CB_De
    CB_Ad = 0.0
    If CB_Nu <> 0.0 Then
       If CB_De <> 0.0 Then
          CB_Be= CB_Nu / CB_De
          CB_Be= Atn(CB_be)                     ' bearing in radians
          If CB_De < 0.0 Then
             CB_Ad = CB_Cpi
          EndIf
          If CB_Nu < 0.0 And CB_De > 0.0 Then
             CB_Ad= CB_C2pi
          EndIf
       Else
          If CB_Lon2 > CB_Lon1 Then
             CB_Ad = CB_Cpi / 2.0
          Else
             CB_Ad = 1.5 * CB_Cpi
    Else
       If CB_Lat2 > CB_Lat1 Then
          CB_Be = 0.0
       Else
          CB_Be = CB_Cpi
    CB_Be= CB_Be + CB_Ad
    GPSBear = RAD2DEG(CB_be)
    if GPSBear <> 0.0 then GPSBear = 360.0 - GPSBear
End Sub
snipsnip
PostPosted: Tue Dec 23, 2014 12:40 pm    Post subject: Reply with quote
found a site with some good gps formulas -
http://www.movable-type.co.uk/scripts/latlong.html
see below for a basic 3d distance calc based on formula from above site (flat earth), not mega accurate but should suitable for small distance, ie logging
only given it a quick test, but google earth agrees with it. (checked distance of 15 kilometres north heading)
I still need to prove it properly Smile
 '3d distance calculation function
 'altitude =  in meters
 'lat lon must be in decimal
 'output in kilometers
Function 3ddistance(startlat , Startlon , Endlat , Endlon , Startalt , Endalt)as Single
Local R As Single , D As Single , X As Single , Y As Single
Local Tmp1 As Single , Tmp2 As Single , Tmp3 As Single , Height As Single
'first convert decimal lat lon to radians
'r=d*pi/180
Startlat = Startlat * 3.14158 : Startlat = Startlat / 180
Startlon = Startlon * 3.14158 : Startlon = Startlon / 180
Endlat = Endlat * 3.14158 : Endlat = Endlat / 180
Endlon = Endlon * 3.14158 : Endlon = Endlon / 180
'now lets butcher some maths
'2d distance - simple method ok for small distance
'ripped from this site - http://www.movable-type.co.uk/scripts/latlong.html
'x=(startlon-endlon)*cos((startlat+endlat)/2)
'y=(endlat-startlat)
'distance=sqrt(x*x+y*y)*6371     6371=earths radius in k's
Tmp1 = 0 : Tmp2 = 0 : Tmp3 = 0
 Tmp1 = Startlon - Endlon
 Tmp2 = Startlat + Endlat
 Tmp2 = Tmp2 / 2
 Tmp3 = Cos(tmp2)
 X = Tmp1 * Tmp3
 Y = Endlat - Startlat
 Tmp1 = X * X
 Tmp2 = Y * Y
 Tmp3 = Tmp1 + Tmp2
 Tmp3 = Sqr(tmp3)
 'd=2d distance in kilometers
 D = Tmp3 * 6371
'now the 3d distance
'3d*3d=(d*d)+(height*height)
 Height = Endalt - Startalt
 'convert from meters to kilometers
 Height = Height / 1000
 Tmp1 = D * D
 Height = Height * Height
 Tmp2 = Tmp1 + Height
 3ddistance = Sqr(tmp2)
 End Function
nicofer
PostPosted: Wed Dec 24, 2014 5:58 pm    Post subject: Reply with quote
Hi
I am playing with gps info at the moment and have a question or 2 - I repost it here .
I am busy with a gps runner watch ( mega128 with a GTOP 16x16 mm gps ) - no fun in buying a working one Wink
I can get all the parts working , oled display , sd card for track log , and all the other bits.
I do have a problem with the gps data .
When standing still the lat and long values tend to drift a bit ,as expected , and I have a filter to detect if the delta distance between 2 readings exceed the limit.
This seems to help to prevent false distance readings due to small changes when not moving.
The bigger problem is that at times the distance reading jump quite high when the signal is low or for what ever reason and then the total distance jumps up quite fast .
I notice Kalman filters are used for GPS but I cant seem to find a good working sample .
I also notice the MCS gps distance sample make use of DOUBLE precision , and code from your program above make use of SINGLE precision . Which is better , good enough , for this application?
Any help to prevent this false readings would be highly appreciated.
Best wishes.
Nico
snipsnip
PostPosted: Wed Dec 24, 2014 9:27 pm    Post subject: Reply with quote
Hi Nico,
I'm thinking about the same problem,
maybe using a accel/gyro to check for rubbish gps jumps?
or maybe use $GPGGA field6 "Horizontal Dilution of Precision (HDOP)"
keep a running average of this and check its current value against the average, then recheck the position data if HDOP is high?
should only need to run the function when not moving?
Would there be enough samples / time for a Kalman filter?
re- single. Seems ok so far. I cant fault the distance measurement (yet). dead on over 15klms - according to google earth
I think using longs should be ok to?? not sure how the whole math/floating point thing works
Very Happy
nicofer
PostPosted: Wed Dec 24, 2014 10:33 pm    Post subject: Reply with quote
Hi
I have looked at the HDOP and speed values and by adding them in some sort of filter will help.
I do however notice LARGE false readings even when the HDOP value is low.
The Gtop gps module is hooked up to an external mag mount antenna to get signal while the sensor is hooked to the programmer and serial port.
Normally one would be moving so the small error should not be a problem . I also have an upper limit for values based based on previous distance values. The idea is to reject any sudden
large distance jumps since it will be used in this case only for running but I might want to take it for a cycle ride later with larger changes in speed / distance so it have to be self adjusting.
The filter limit small changes but now there is another problem , what if you are moving very slow, so that the filter rejects the values , you still need to update your current position and distance.
I run with an android phone with a good performance gps sensor and the STRAVA app. But even the gps and subsequent distance values tend to drift a bit when not moving .
The TomTom Runner watch however does not increment while stationary and the final track is more smooth so they have a working filter algorithm .
The Runner has a accel/gyro sensor since it can be used "off road " so this might be the best to use this extra movement sensor since normally your arm is moving when running.
Cheers
snipsnip
PostPosted: Wed Dec 24, 2014 11:58 pm    Post subject: Reply with quote
there would be a way to use a 6DOF (stand alone) mems to pretty accurately map distance and direction travelled. Reckon the maths and integration would be pretty full on Shocked
There will be some code somewhere on google for this - i'll see if I can track some down and convert it.
snipsnip
PostPosted: Thu Dec 25, 2014 12:06 am    Post subject: Reply with quote
Also,
what about taking a lat lon - offset this by say a kilometre N
take the (average of last 10 reading) offset this 100m south
final reading is the halfway point between the two -450m?
Just quick thoughts, could be very flawed
Very Happy
snipsnip
PostPosted: Thu Dec 25, 2014 12:30 am    Post subject: Reply with quote
Embarassed just found the mcs gps distance calculator in the samples.
'                  (c) 1995-2008
'                 MCS Electronics
' This program will calculate the distance between GPS coordinates
' It also calculates course
$regfile = "m128def.dat"
$framesize = 320
$hwstack = 160
$swstack = 160
$crystal = 16000000
Const Pi = 3.14159265358979
Const Mpi = Pi / 180
Const Radiusearth = 6371000
Dim Calc_distance As Double
Dim Calc_course_d As Double
Dim Calc_course_m As Double
Dim Calc_course_s As Double
Declare Sub Get_distance_course(byval Lat1 As Double , Byval Lon1 As Double , Byval Lat2 As Double , Byval Lon2 As Double)
Call Get_distance_course( -9.9666 , 18.0374 , 52.8273 , -8.4409)
If Calc_distance > 1000 Then Calc_distance = Calc_distance / 1000
Print "Distance: " ; Calc_distance
Print "Course: " ; Calc_course_d ; "D " ; Calc_course_m ; "M " ; Calc_course_s ; "S"
  Local Tmp As Double , A As Double , B As Double , C As Double , T2 As Double
        ' 1 Degree is 69.096 miles, 1 mile is 1609.34 m
        A = Lat1 * Mpi                                      'Mpi
        A = Cos(a)
        T2 = Lat2 * Mpi : T2 = Cos(t2) : A = A * T2
        T2 = Lon1 * Mpi : T2 = Cos(t2) : A = A * T2
        T2 = Lon2 * Mpi : T2 = Cos(t2) : A = A * T2
        B = Lat1 * Mpi : B = Cos(b)
        T2 = Lon1 * Mpi : T2 = Sin(t2) : B = B * T2
        T2 = Lat2 * Mpi : T2 = Cos(t2) : B = B * T2
        T2 = Lon2 * Mpi : T2 = Sin(t2) : B = B * T2
        C = Lat1 * Mpi : C = Sin(c)
        T2 = Lat2 * Mpi : T2 = Sin(t2) : C = C * T2
        T2 = A + B
        T2 = T2 + C
        A = Abs(t2)
        If A >= 1 Then
           Calc_distance = 0
        Else
           T2 = Acos(t2) : Tmp = T2 : T2 = T2 * Radiusearth
           Calc_distance = T2
       'Calculate bearing course
        A = Lat2 * Mpi : A = Sin(a)
        B = Lat1 * Mpi : B = Sin(b)
        T2 = Cos(tmp) : B = B * T2
        C = Lat1 * Mpi : C = Cos(c)
        T2 = Sin(tmp) : C = C * T2
        A = A - B
        A = A / C
        A = Acos(a)
        A = Rad2deg(a)
        B = Lon2 * Mpi
        C = Lon1 * Mpi
        Tmp = B - C
        If Tmp < 0.0 Then A = 360 - A
        Calc_course_d = Int(a)
        Tmp = Frac(a)
        Tmp = Tmp * 60
        Calc_course_m = Int(tmp)
        Tmp = Frac(tmp)
        Tmp = Tmp * 60
        Calc_course_s = Round(tmp)
End Sub
snipsnip
PostPosted: Thu Dec 25, 2014 2:11 am    Post subject: Reply with quote
anchor / proximity alarm, not tested yet
'anchor / proximity alarm returns "anchor" in meters from target when setdistance is exceded
'lat,lon in decimal                                       meters,
'to_from.. 0=to 1=from ie 1=anchor and 0=proximity alarm conviguration
Function Anchor(anchlat , Anchlon , Curlat , Curlon , Setdistance , To_from) As Single
Local Tmp As Single
Setdistance = Setdistance / 1000
   'couldnt be stuffed rewiting the dist function here. if stack / portability is an issue rewrite it Smile
   Tmp = 3ddistance(anchlat , Anchlon , Curlat , Curlon , 1 , 1)
   If To_from = 1 And Tmp > Setdistance Then
     Tmp = -tmp
     Elseif To_from = 0 And Tmp < Setdistance Then
     Tmp = -tmp
'convert to meters
Tmp = Tmp * 1000
Anchor = Tmp
End Function
End Function
snipsnip
PostPosted: Sun Dec 28, 2014 10:42 am    Post subject: Reply with quote
Another that returns the bearing from two points - Thanks to AdrianJ's code
needs lat / lon in decimal degrees
returns angle from north in degrees
Function Bearing(lat1 , Lon1 , Lat2 , Lon2)as Single
'positions in de degrees converted here to radians
'result = true bearing from north
Const Cpi = 3.14159265
Const C2pi = 6.2831854
Const Crad2nm = 3437.746771                                 ' radians to nautical miles
Const Cnm2ft = 6080.0                                       ' nautical miles to feet
Local Bear As Single
Local X1 As Single
Local X2 As Single
Local Y1 As Single
Local Y2 As Single
Local Dx As Single
Local Dy As Single
Local Cosd As Single
Local Nu As Single
Local De As Single
Local Be As Single
Local Ad As Single
Local Dq As Single
'conver decimal lat,lons to radians
Lat1 = Lat1 * Cpi : Lat1 = Lat1 / 180
Lat2 = Lat2 * Cpi : Lat2 = Lat2 / 180
Lon1 = Lon1 * Cpi : Lon1 = Lon1 / 180
Lon2 = Lon2 * Cpi : Lon2 = Lon2 / 180
 Dx = Lon2 - Lon1 : Dx = Dx / 2 : Dx = Sin(dx) : Dx = Dx * Dx
 Dy = Lat2 - Lat1 : Dy = Dy / 2 : Dy = Sin(dy) : Dy = Dy * Dy
'so use:
 X1 = Sin(lat1) : Y1 = Cos(lat1)
 X2 = Sin(lat2) : Y2 = Cos(lat2)
 Dx = Dx * Y1 : Dx = Dx * Y2
 De = Dy + Dx : De = Sqr(de)
 Dq = Asin(de) : Dq = Dq * 2.0
 'now calc bearing
 Dx = Lon2 - Lon1
 Nu = sin(Dx)
 Nu = nu * Y2
 De = Cos(dx) : De = De * Y2 : De = De * X1 : X2 = X2 * Y1 : De = X2 - De
 Ad = 0.0
If Nu <> 0.0 Then
   If De <> 0.0 Then
     Be = Nu / De
     Be = Atn(be)                                            ' bearing in radians
     If De < 0.0 Then
       Ad = Cpi
     If Nu < 0.0 And De > 0.0 Then
       Ad = C2pi
   Else
     If Lon2 > Lon1 Then
       Ad = Cpi / 2.0
     Else
       Ad = 1.5 * Cpi
Else
   If Lat2 > Lat1 Then
     Be = 0.0
   Else
     Be = Cpi
 Be = Be + Ad
 Bear = Be                                                  ' in radians
'to convert from radians to degrees, multiply by 180/pi.
 Tmp1 = 180 / Cpi
 Bear = Bear * Tmp1
 Bearing = Bear
End Function
nicofer
PostPosted: Mon Dec 29, 2014 10:44 pm    Post subject: Reply with quote
I focused more on data logging to upload to STRAVA since they do filtering and smoothing and provide you with impressive graphical displays . Strava is not the only or the best for this but ,
since I have history with them ,I use them .
I now save the lon / lat / elev / time and date direct as a GPX format file that afterwards I use the upload page from Strava to upload the file , file syntax very critical.
The results are quite impressive - just as good as TomTom Runner - or Android Strava app.
So the bottom line is that for a few $$, a few scrap parts and some BASCOM code you can have a GPS runners watch that is on par with the best , for the logging part of it at least.
The embedded software , display , battery life and other bells and whistles is what sets the units apart.
I had some problems with my prototype Nokia 128x129 type lcd display - not good for use outside . So at the moment I have only logging - zero display.
The quick and dirty pcb has a 0.96 " OLED but still not sure if I should run it via I2c or SPI - I prefer SPI since it should be faster but I prefer to keep the display and sd card separated.
Any suggestions about this ?
Regards
Nico
snipsnip
PostPosted: Thu Jan 01, 2015 1:15 am    Post subject: Reply with quote
Hi, Nico
Sorry mate, I've got no suggestions. I haven't yet got logging or a glcd setup yet. Was hoping you'd tell me the best way to go about it Smile
But its pretty common to share card and screen on spi?
Got any pics of your watch setup that you want to share. Sounds pretty cool.
nicofer
PostPosted: Fri Jan 02, 2015 9:23 am    Post subject: Reply with quote
Hi
Did a 10 km run and the gps log of the track is 100 % with my temporary setup .
Biggest issue is the final external hardware and mounting since unit is visible and needs to be functional.
Busy with the proto pcb with the oled display - will post files soon.
To limit power drain I do not use the lcd display with led backlight - not readable outdoors anyway so it is only logging for now - plan is to have short vibration every km done and the display to
light up for a few seconds.
Circuit diagram not 100 % cast in stone.
Cheers
snipsnip
PostPosted: Fri Feb 20, 2015 6:26 am    Post subject: Reply with quote
just another basic function.
converts Knots (string) to KPH(string) 2 decimal points with a trailing "Kph"
 Function Speed(knots As String)as String
  Local Oput As String * 10 : Local X As Single : Local Y As Byte : Local Z As Byte
  X = Val(knots)
  X = X * 1.852
  Oput = Str(x)
  Y = Charpos(oput , ".")
 Z = Y + 3 : Insertchar Oput , Z , " "
 Z = Y + 4 : Insertchar Oput , Z , "K"
 Z = Y + 5 : Insertchar Oput , Z , "p"
 Z = Y + 6 : Insertchar Oput , Z , "h"
 Oput = Left(oput , Z)
 Speed = Oput
 End Function
Goto page 1, 2  Next
Page 1 of 2
