changing polarity off the sclk spi bus at runtime
Tiny
PostPosted: Mon Nov 24, 2014 8:33 pm    Post subject: changing polarity off the sclk spi bus at runtime Reply with quote
Hello,
i want to communicate with a MS5541C spi pressure senser.
but there for i need to change the polarity off the SCLK after sending 16 bits to read back the data.
how can i do that?
Regards Tiny
PostPosted: Mon Nov 24, 2014 10:16 pm    Post subject: Reply with quote
If it's an XMega, do a re-Config, if it's for example an ATMega32, the bit CPOL in SPCR is responsible for clock polarity, depending on the sensors data sheet, you need to check CPHA too.
Tiny
PostPosted: Mon Nov 24, 2014 10:35 pm    Post subject: Reply with quote
sorry i forgot to tell which chip it was, it is a atmega644a
PostPosted: Mon Nov 24, 2014 11:14 pm    Post subject: Reply with quote
Also the ATMega644A has a datasheet and the registers and config-bits even have the same name. Wink
Tiny
PostPosted: Tue Nov 25, 2014 6:39 am    Post subject: Reply with quote
Thank you, i found it
Tiny
PostPosted: Tue Nov 25, 2014 6:40 am    Post subject: Reply with quote
