FT800
Goto page 1, 2, 3, 4  Next
PostPosted: Sat Oct 11, 2014 12:25 am    Post subject: FT800 Reply with quote
As you might know, PeterM made it his mission to write support for the FTDI FT800 graphic chip.
Peter wrote a bascom library in the form of include files and created reusable functions and procedures. I think he spend a small fortune talking to FTDI support to clear up issues.
He also converted a lot of arduino samples into bascom.
When everything worked i converted the code into a special FT800 library and some compiler statements/functions were added, and in the process some nice features were added to the compiler as well.
At this stage Peter is writing the help which is a lot of work since there are really a lot and i mean a lot! of subs/functions.
Since some of you want to experiment with FT800 i created a beta version. You can get this by writing to support. You must have a registered bascom version in order to get the beta.
You really should start to read the ftdi pdf files/documentation. While i did work hard on this project the last weeks, i am not an expert. In fact, i still need to study everything myself!
That might sound odd but when you see the demo code below you might understand it. Very Happy
Peter might have time to answer questions. But otherwise you need to wait till the official release which should be available this month too.
' Demo Set 0
' FT800 platform.
' Original code http://www.ftdichip.com/Support/SoftwareExamples/EVE/FT800_SampleApp_1.0.zip
' Requires Bascom 2.0.7.7 beta or greater
$Regfile = "M328pdef.dat"
$Crystal = 8000000
$Baud = 19200
$HwStack = 80
$SwStack = 80
$FrameSize = 350
$NOTYPECHECK
Config ft800=spi , ftsave=0, ftdebug=0
Config Base = 0
Config Submode = New
Config Spi = Hard, Interrupt = Off, Data_Order = Msb, Master = Yes, Polarity = Low, Phase = 0, Clockrate = 4, Noss = 1
SPSR = 1  ' Makes SPI run at double speed
ft800_CS Alias Portb.2
Config ft800_CS = Output
ft800_CS = 1
ft800_Pd Alias PortB.0
Config ft800_Pd = Output
ft800_Pd = 1
Declare Sub Screen (ByVal Characters As String)
Declare Sub Points
Declare Sub Line_s
Declare Sub Rectangles
Declare Sub Bitmap
Declare Sub BitmapPalette
Declare Sub Fonts
Declare Sub Text_8x8
Declare Sub Text_VGA
Declare Sub Bar_Graph
Declare Sub LineStrips
Declare Sub EdgeStrips
Declare Sub Scissor
Declare Sub Polygon
Declare Sub Cube
Declare Sub Ball_Stencil
Declare Sub FtdiString
Declare Sub StreetMap
Declare Sub AdditiveBlendText
Declare Sub MacroUsage
Declare Sub AdditiveBlendPoints
Declare Function Lerp (ByVal t As Single, ByVal a As Single, ByVal b As Single) As Long
Declare Function smoothlerp (ByVal t As Single, ByVal a As Single, ByVal b As Single) As Single
$Include "XXFT800.inc"
$Include "XXFT800_Functions.inc"
Spiinit
Dim Header_Format(3) As Byte
Dim Header_Width(3) As Integer
Dim Header_Height(3) As Integer
Dim Header_Stride(3) As Integer
Dim Header_Arrayoffset(3) As Long
    Header_Format(0 + _base) = RGB565
    Header_Width(0+_base) = 40
    Header_Height(0+_base) = 40
    Header_Stride(0+_base) = 80
    Header_Arrayoffset(0+_base) = 0
    Header_Format(1+_base) = PALETTED
    Header_Width(1+_base) = 40
    Header_Height(1+_base) = 40
    Header_Stride(1+_base) = 40
    Header_Arrayoffset(1+_base) = 0
    Header_Format(2+_base) = PALETTED
    Header_Width(2+_base) = 480
    Header_Height(2+_base) = 272
    Header_Stride(2+_base) = 480
    Header_Arrayoffset(2+_base) = 0
' Type FT_Gpu_Fonts_t
' FT800 font table structure
' Font table address in ROM can be found by reading the address from 0xFFFFC location.
' 16 font tables are present at the address read from location 0xFFFFC
' Width of each character font from 0 to 127
Dim FontWidth (Ft_Numchar_Per_Font) As Byte
' Bitmap format of font wrt bitmap formats supported by FT800 - L1, L4, L8
Dim FontBitmapFormat As Dword
' Font line stride in FT800 ROM
Dim FontLineStride As Dword
' Font width in pixels
Dim FontWidthInPixels As Dword
' Font height in pixels
Dim FontHeightInPixels As Dword
' Pointer to font graphics raw data
Dim PointerToFontGraphicsData As Dword
Dim Display_fontstruct As Byte At FontWidth(_base) Overlay
  if FT800_Init()=1 Then END    ' Initialise the FT800
'<< Un-Rem any of the demo's, compile and run ! >>
' Set 0  Demo's
' Unremark one or more demos and compile
  Screen "Set0 START"
 ' Points
'  Line_s
'  Rectangles
'  Bitmap
'  BitmapPalette
'  Fonts
'  Text_8x8
'  Text_VGA
'  Bar_graph
'  LineStrips
'  EdgeStrips
'  Scissor
'  Polygon
'  Cube
'  Ball_Stencil
'  FtdiString
'  StreetMap
'  AdditiveBlendText
'  MacroUsage
'  AdditiveBlendPoints ' requires Const Qsincos  = 1 in FT800.inc
  Screen "Set0 END!"
   ClearColorRGB &HFF, &HFF, &HFF  ' background colour
   Clear_B 1, 1, 1
   ColorRGB &H80, &H80, &H00
   CmdText FT_DispWidth/2, FT_DispHeight/2, 31, OPT_CENTER, Characters
   UpdateScreen
   Wait 1
End Sub ' Screen
Sub Points
   ' Example code to display few points at various offsets with various colors
   ' Construct Display List of points
   Wr32 RAM_DL + 0 , _ClearColorRGB(128, 128, 128)
   Wr32 RAM_DL + 4 , _Clear_B(1,1,1)
   Wr32 RAM_DL + 8 , _ColorRGB (128, 0, 0)
   Wr32 RAM_DL + 12, _PointSize(5 * 16)
   Wr32 RAM_DL + 16, _Begin_G (FTPOINTS)
   Wr32 RAM_DL + 20, _VERTEX2F( FT_DispWidth / 5 * 16, FT_DispHeight / 2 * 16)
   Wr32 RAM_DL + 24, _ColorRGB (0, 128, 0)
   Wr32 RAM_DL + 28, _PointSize (15 * 16)
   Wr32 RAM_DL + 32, _VERTEX2F(FT_DispWidth * 2 / 5 * 16, FT_DispHeight / 2 * 16)
   Wr32 RAM_DL + 36, _ColorRGB (0, 0, 128)
   Wr32 RAM_DL + 40, _PointSize (25 * 16)
   Wr32 RAM_DL + 44, _VERTEX2F (FT_DispWidth * 3 / 5 * 16, FT_DispHeight / 2 * 16)
   Wr32 RAM_DL + 48, _ColorRGB (128, 128, 0)
   Wr32 RAM_DL + 52, _PointSize (35 * 16)
   Wr32 RAM_DL + 56, _VERTEX2F (FT_DispWidth * 4 / 5 * 16, FT_DispHeight / 2 * 16)
   Wr32 RAM_DL + 60, _Display_E()  ' display the image
   ' Do a swap
   DLSwap
   Wait 1
End Sub ' Points
Sub Line_s
   ClearScreen   ' Always use this on your Second line
   ColorRGB 128, 0, 0
   LineWidth 5 * 16
   Begin_G LINES
   Vertex2F (FT_DispWidth / 4) * 16, (FT_DispHeight - 25) / 2 * 16
   Vertex2F (FT_DispWidth / 4) * 16, (FT_DispHeight + 25) / 2 * 16
   ColorRGB 0, 128, 0
   LineWidth 10 * 16
   Vertex2F (FT_DispWidth * 2) / 4 * 16, (FT_DispHeight - 40) / 2 * 16
   Vertex2F (FT_DispWidth * 2) / 4 * 16, (FT_DispHeight + 40) / 2 * 16
   ColorRGB 128, 128, 0
   LineWidth 20 * 16
   Vertex2F (FT_DispWidth * 3) / 4 * 16, (FT_DispHeight - 55) / 2 * 16
   Vertex2F (FT_DispWidth * 3) / 4 * 16, (FT_DispHeight + 55) / 2 * 16
   UpdateScreen
   Wait 1
End Sub ' Lines
Sub Rectangles
   ColorRGB 0, 0, 128
   LineWidth 1 * 16 ' LINE_WIDTH is used for corner curvature
   Begin_G RECTS
   Vertex2F ((FT_DispWidth/4) - 2) * 16, ((FT_DispHeight - 25)/2) * 16
   Vertex2F ((FT_DispWidth/4) + 2) * 16, ((FT_DispHeight + 25)/2) * 16
   ColorRGB 0, 128, 0
   LineWidth 5 * 16
   Vertex2F ((FT_DispWidth * 2) / 4 - 5) * 16, (FT_DispHeight - 40) / 2 * 16
   Vertex2F ((FT_DispWidth * 2) / 4 + 5) * 16, (FT_DispHeight + 40) / 2 * 16
   LineWidth 10 * 16
   Vertex2F ((FT_DispWidth * 3) / 4 - 10) * 16, (FT_DispHeight - 55) / 2 * 16
   Vertex2F ((FT_DispWidth * 3) / 4 + 10) * 16, (FT_DispHeight + 55) / 2 * 16
   UpdateScreen
   Wait 1
End Sub  ' Rectangles
Sub Bitmap
   Local BMoffsetx As Integer
   Local BMoffsety As Integer
   Local Ln1 As Dword
   Local Ln2 As Dword
   ' Copy raw data into address 0 followed by generation of bitmap
   TempDW = Loadlabel(Bitmap_RawData)
   RdFlash_WrFT800 RAM_G, TempDW , Header_Stride(0+_base) * Header_Height(0+_base)
   ClearScreen
   ColorRGB 255, 255, 255
   BitmapSource RAM_G
   BitmapLayout  Header_Format(0+_base), Header_Stride(0+_base), Header_Height(0+_base)
   BitmapSize NEAREST, Border, Border, Header_Width(0+_base), Header_Height(0+_base)
   Begin_G BITMAPS ' start drawing bitmaps
   Const AW = (FT_DispWidth / 4)
   Ln1 = Header_Width(0+_base) / 2
   Const AX = FT_DispHeight / 2
   Ln2 = Header_Height(0+_base) / 2
   BMoffsetx = AW - Ln1
   BMoffsety = AX - Ln2
   Vertex2II BMoffsetx, BMoffsety, 0, 0
   ColorRGB 255, 64, 64  ' red At (200, 120)
   Const AY = FT_DispWidth * 2 / 4
   Const AZ = FT_DispHeight / 2
   BMoffsetx = AY - Ln1
   BMoffsety = AZ - Ln2
   ColorRGB 64, 180, 64 ' green At (216, 136)
   BMoffsetx = BMoffsetx + Ln1
   BMoffsety = BMoffsety + Ln2
   ColorRGB 255, 255, 64 ' transparent yellow At (232, 152)
   Color_A 150
   Color_A 255
   Vertex2F -10 * 16, -10 * 16 'For -ve coordinates use vertex2f instruction
   UpdateScreen
   Wait 1
End Sub ' Bitmap
Sub BitmapPalette
   Local Ln1 As Dword
   Local Ln2 As Dword
   TempDW = Loadlabel(paletteraw)
   RdFlash_WrFT800 RAM_G,   TempDW , Header_Stride(1+_base) * Header_Height(1+_base)
   TempDW = Loadlabel(paletteLUT)
   RdFlash_WrFT800 RAM_PAL, TempDW , 1022
   ClearScreen
   BitmapSource RAM_G
   BitmapLayout Header_Format(1+_base), Header_Stride(1+_base), Header_Height(1+_base)
   BitmapSize NEAREST, Border, Border, Header_Width(1+_base), Header_Height(1+_base)
   Const DA = FT_DispWidth / 4
   Ln1 = Header_Width(1+_base) / 2
   Const DB = FT_DispHeight / 2
   Ln2 = Header_Height(1+_base) / 2
   BMoffsetx = DA - Ln1
   BMoffsety = DB - Ln2
   UpdateScreen
   Wait 1
End Sub ' BitmapPalette
Sub Fonts
' Inbuilt Font example For proportionate And non proportionate Text - hello world
   Local B As Byte
   Local i As byte
   Local j As byte
   Local hoffset As word
   Local voffset As word
   Local stringlen As byte
   Local FontTableAddress As Dword
   Local Display_string As String * 20
   Display_string = "Hello World"
   hoffset = FT_DispWidth - 100
   hoffset = hoffset / 2
   voffset = FT_DispHeight / 2
   ' Read the Font address From &HFFFFC location
   FontTableAddress = Rd32(&HFFFFC)
   stringlen = Len(Display_string)
   For i = 0 To 15
      ' Read the Font table From hardware
      TempDW = i * FT_FONT_TABLE_SIZE
      TempDW = TempDW  + FontTableAddress
      RdFT800_WrMem TempDW, Display_fontstruct, FT_FONT_TABLE_SIZE
      Clear_B 1, 1, 1 ' Clear Screen
      ColorRGB 255, 255, 255 ' Clear Screen
      ' Display String At the center Of Display
      Begin_G BITMAPS
      hoffset = FT_DispWidth - 120
      voffset = FT_DispHeight - FontHeightInPixels
      voffset = voffset / 2
      ' Display hello world by offsetting wrt char Size
      For j = 1 To stringlen
         B = Asc(Display_string, j)
         Vertex2II hoffset, voffset, i + 16, B
         hoffset = hoffset + FontWidth(B+_base)
      Next j
      UpdateScreen
      Wait 1
   Next i
End Sub ' Fonts
Sub Text_8x8
' Display text8x8 Of abcdefgh
   Local Text_Array As String * 10
   Local String_size As Long
   ' Write the Data into RAM_G
   Text_Array = "abcdefgh"
   String_size = Len(Text_Array)
   RdMem_WrFT800 RAM_G, Text_Array, String_size
   ClearScreen
   BitmapSource RAM_G
   BitmapLayout TEXT8X8, 8 , 1 ' L1 format, Each Input Data element is in 1 byte size
   BitmapSize NEAREST, Border, REPEAT, 8 * 8, 8 * 2 ' Output Is 8x8 format - draw 8 characters In horizontal repeated In 2 Line
   Begin_G BITMAPS
   ' Display Text 8x8 At hoffset, voffset location
   VerteX2F 16 * 16, 16 * 16
   BitmapLayout TEXT8X8, 4, 2 ' L1 format And Each datatype Is 1 Byte Size
   BitMapSize NEAREST, REPEAT, Border, 8 * 16, 8 * 2 ' Each character Is 8x8 In Size -  so draw 32 characters In horizontal And 32 characters In vertical
   VerteX2F (FT_DispWidth / 2) * 16, (FT_DispHeight / 2) * 16
   UpdateScreen
   Wait 1
End Sub ' Text_8x8
Sub Text_VGA
' Display textVGA Of Random values
   Local i As Long
   Local Char As Dword
   Dim Text_Array(320) As Byte
   For i = 0 To 319
      Text_Array(i+_base) = Rnd(255)
   Next i
   'Char = VarPtr(Text_Array(0+_base))
   String_size = 320
   RdMem_WrFT800 RAM_G, Text_Array(_base), String_size
   ClearScreen
   BitmapSource RAM_G
   ' mandatory For textvga As background Color Is also one Of the parameter In textvga format
   BlendFunc ONE, ZERO
   'draw 8x8
   BitmapLayout TEXTVGA, 2 * 4, 8 'L1 format, but Each Input Data element is of 2 bytes in size
   BitmapSize NEAREST, Border, Border, 8 * 8, 8 * 8 'Output Is 8x8 format - draw 8 characters In horizontal And 8 vertical
   Begin_G BITMAPS
   VerteX2F 32 * 16, 32 * 16
   End_G
   'draw textvga
   BitMapLayout TEXTVGA, 2 * 16, 8 'L1 format but Each datatype Is 16Bit Size
   BitmapSize NEAREST, Border, REPEAT, 8 * 32, 8 * 32 '8 Pixels per character And 32 rows/colomns
   Begin_G BITMAPS
   ' Display textvga At hoffset, voffset location
   Vertex2F (FT_DispWidth / 2) * 16, (FT_DispHeight / 2) * 16
   End_G
   UpdateScreen
   Wait 1
End Sub ' Text_VGA
Sub Bar_Graph
   Local i As Long
   Local tmpval As Long
   Local tmpidx As Long
   Local tmpL1 As Long
   Local tmpL2 As Long
   Dim Y_Array(512) As Byte
   For i = 0 To 511
      Y_Array(i+_base) = Rnd(128) + 64 'within range
   Next i
   String_size = 512
   RdMem_WrFT800 RAM_G, Y_Array(_base), String_size
   ClearColorRGB 255, 255, 255
   Clear_B 1, 1, 1
   BitmapSource RAM_G
   BitmapLayout BARGRAPH, 256, 1
   ColorRGB 128, 0, 0
   BitmapSize NEAREST, Border, Border, 256, 256
   Begin_G BITMAPS
   Vertex2II 0, 0, 0, 0
   Vertex2II 256, 0, 0, 1
   UpdateScreen
   ' Download the DL into DL RAM
   Wait 1
   For i = 0 To 512
      ' tmpval = 128 + (i/3 * qsin(-65536 * i / 48 )) / 65536
      tmpidx = i
      tmpL1 = -65536 * i
      tmpL1 = tmpL1 /48
      tmpL2 = qsin(tmpL1)
      tmpL1 = i/3
      tmpL1 = tmpL1 * tmpL2
      tmpL1 = tmpL1 / 65536
      tmpval = tmpL1 + 128
      Y_Array(i+_base) = tmpval And &Hff
   Next i
   String_size = 512
   Wait 1
   BitmapSource RAM_G
   Begin_G BITMAPS
   ColorRGB 255, 0, 0
   ' Display bargraph At hoffset, voffset location
   ColorRGB 0, 0, 0
   Vertex2II 0, 4, 0, 0
   Vertex2II 256, 4, 0, 1
   UpdateScreen
   Wait 1
End Sub ' Bar_Graph
Sub LineStrips
   ClearColorRGB 5, 45, 10
   ColorRGB 255, 168, 64
   Clear_B 1 ,1 ,1
   Begin_G LINE_STRIP
   Vertex2F 16 * 16, 16 * 16
   Vertex2F (FT_DispWidth * 2 /3)  * 16, (FT_DispHeight * 2 / 3) * 16
   Vertex2F (FT_DispWidth - 80) * 16, (FT_DispHeight - 20) * 16
   UpdateScreen
   Wait 1
End Sub ' LineStrips
Sub EdgeStrips
   Clear_B 1 ,1 ,1
   Begin_G EDGE_STRIP_R
   Vertex2F (FT_DispWidth * 2 / 3)  * 16, (FT_DispHeight * 2 / 3) * 16
   UpdateScreen
   Wait 1
End Sub ' EdgeStrips
Sub Scissor
   Clear_B 1,1,1
   ScissorXY 40, 20 ' Scissor rectangle top Left At (40, 20)
   ScissorSize 40, 40 ' Scissor rectangle Is 40 x 40 Pixels
   ClearColorRGB 255, 255, 0 ' CLEER To yellow
   Clear_B 1, 1, 1
   UpdateScreen
   Wait 1
End Sub ' Scissor
Sub Polygon
   Clear_B 1, 1, 1 ' CLear Screen
   ColorRGB 255, 0, 0
   StencilOP Incrx, Incrx
   ColorMask 0,0,0,0 'mask All the colors
   Begin_G EDGE_STRIP_L
   Vertex2II FT_DispWidth / 2, FT_DispHeight / 4 , 0, 0
   Vertex2II FT_DispWidth * 4 / 5, FT_DispHeight * 4 / 5, 0, 0
   Vertex2II FT_DispWidth / 4, FT_DispHeight / 2 , 0, 0
   Vertex2II FT_DispWidth / 2, FT_DispHeight / 4, 0, 0
   End_G
   ColorMask 1,1,1,1 'Enable All the colors
   StencilFunc EQUAL,1,255
   Vertex2II FT_DispWidth, 0, 0, 0
   Vertex2II FT_DispWidth, FT_DispHeight,0,0
   End_G
   ' Draw Lines At the BORDERs To make sure anti aliazing Is also done
   StencilFunc ALWAYS, 0, 255
   LineWidth 1 * 16
   ColorRGB 0, 0, 0
   Begin_G Lines
   Vertex2II (FT_DispWidth * 4) / 5, (FT_DispHeight * 4) /5, 0, 0
   Vertex2II FT_DispWidth / 4, FT_DispHeight / 2, 0, 0
   End_G
   UpdateScreen
   Wait 1
End Sub ' Polygon
Sub Cube
   Local cnt As Byte
   Local F0 As Integer, F1 As Integer, F2 As Integer, F3 As Integer, F4 As Integer, F5 As Integer, F6 As Integer
   Local x As Long, y As Long, i As Long, z As Long, f As Long, g As Long
   Local xoffset As Integer, yoffset As Integer, CubeEdgeSz As Integer
   Dim point(30)  As Long
   Dim colorsA(3) As Word
   Dim colorsB(3) As Word
   Dim colorsC(3) As Word
   Dim colorsD(3) As Word
   Dim colorsE(3) As Word
   Dim colorsF(3) As Word
   ' Color vertices
   colorsA(0+_base) = 255
   colorsA(1+_base) = 0
   colorsA(2+_base) = 0
   colorsB(0+_base) = 255
   colorsB(1+_base) = 0
   colorsB(2+_base) = 150
   colorsC(0+_base) = 0
   colorsC(1+_base) = 255
   colorsC(2+_base) = 0
   colorsD(0+_base) = 110
   colorsD(1+_base) = 120
   colorsD(2+_base) = 110
   colorsE(0+_base) = 0
   colorsE(1+_base) = 0
   colorsE(2+_base) = 255
   colorsF(0+_base) = 128
   colorsF(1+_base) = 128
   colorsF(2+_base) = 0
   ' Cube dimention Is Of 100 * 100 * 100
   CubeEdgeSz = 100
   xoffset = FT_DispWidth / 2
   xoffset = xoffset - CubeEdgeSz
   yoffset = FT_DispHeight - CubeEdgeSz
   yoffset = yoffset  / 2
   ' xy plane(front)
   point(0+_base) = _Vertex2F(xoffset * 16, yoffset * 16)
   F0 = xoffset + CubeEdgeSz
   F1 = yoffset + CubeEdgeSz
   point(1+_base) = _Vertex2F(F0 * 16, yoffset * 16)
   point(2+_base) = _Vertex2F(F0 * 16, F1 * 16)
   point(3+_base) = _Vertex2F(xoffset * 16, F1 * 16)
   point(4+_base) = point(0+_base)
   'yz plane (Left)
   F2 = CubeEdgeSz / 2
   x = xoffset + F2            ' xoff+w/2
   y = yoffset - F2            ' yoff-h/2
   F3 = y + CubeEdgeSz
   point(5+_base) = point(0+_base)
   point(6+_base) = _Vertex2F(x * 16, y * 16)
   point(7+_base) = _Vertex2F(x * 16, F3 * 16)
   point(8+_base) = point(3+_base)
   point(9+_base) = point(5+_base)
   'xz plane(top)
   F4  = x + CubeEdgeSz
   point(10+_base) = point(0+_base)
   point(11+_base) = point(1+_base)
   point(12+_base) = _Vertex2F( F4 * 16, y * 16)
   point(13+_base) = point(6+_base)
   point(14+_base) = point(10+_base)
   'xz plane(bottom)
   point(15+_base) = point(3+_base)
   point(16+_base) = point(2+_base)
   point(17+_base) = _Vertex2F(F4 * 16, F3 * 16)
   point(18+_base) = point(7+_base)
   point(19+_base) = point(15+_base)
   'yz plane (Right)
   point(20+_base) = point(2+_base)
   point(21+_base) = point(17+_base)
   point(22+_base) = point(12+_base)
   point(23+_base) = point(1+_base)
   point(24+_base) = point(20+_base)
   'yz plane (back)
   point(25+_base) = point(6+_base)
   point(26+_base) = point(7+_base)
   point(27+_base) = point(17+_base)
   point(28+_base) = point(12+_base)
   point(29+_base) = point(25+_base)
   Clear_B 1, 1, 1
   LineWidth 16
   Clear_B 1, 1, 1
   ' Draw a cube
   Color_A 192
   For z = 0 To 5
      Clear_B 0, 1, 1         ' Clear Stencil buffer
      ColorMask 0, 0, 0, 0    ' Mask All the colors And draw one surface
      StencilFunc ALWAYS, 0, 255  ' Stencil Function To increment All the values
      For i = 0 To 4
         cnt = z * 5
         cnt = cnt + i
         Cmd32 point(cnt+_base)
      End_G
      ' Set the Color And draw a strip
      ColorMask 1, 1, 1, 1
      StencilFunc EQUAL, 1 , 255
      Select Case z
         Case 0
            ColorRGB colorsA(0+_base), colorsA(1+_base), colorsA(2+_base)
         Case 1
            ColorRGB colorsB(0+_base), colorsB(1+_base), colorsB(2+_base)
         Case 2
            ColorRGB colorsC(0+_base), colorsC(1+_base), colorsC(2+_base)
         Case 3
            ColorRGB colorsD(0+_base), colorsD(1+_base), colorsD(2+_base)
         Case 4
            ColorRGB colorsE(0+_base), colorsE(1+_base), colorsE(2+_base)
         Case 5
            ColorRGB colorsF(0+_base), colorsF(1+_base), colorsF(2+_base)
      End Select
      F5 = CubeEdgeSz * 2
      F6 = CubeEdgeSz * 2
      Begin_G RECTS
      Vertex2II xoffset, 0, 0, 0
      Vertex2II xoffset + F5, yoffset + F6, 0, 0
      End_G
   UpdateScreen
   Wait 1
End Sub ' Cube
Sub Ball_Stencil
   ' First draw points followed by Lines To Create 3d ball kind Of effect
   Local xball As Integer, yball As Integer, rball As Integer, numpoints As Integer, numlines As Integer
   Local i As Integer, asize As Integer, aradius As Integer, gridsize As Integer
   Local asmooth As Long, loopflag As Long, dispa As Long, dispr As Long, displ As Long, Temp1 As Long, Temp2 As Long
   Local dispb As Long, xflag As Long, yflag As Long, tempsmooth As Long
   Local TempDB As Single
   xball   = FT_DispWidth/2
   yball   = 120
   rball   = FT_DispWidth/8
   numpoints = 6
   numlines= 8
   gridsize= 20
   dispr   = FT_DispWidth - 10
   displ   = 10
   dispa   = 10
   dispb   = FT_DispHeight - 10
   xflag   = 1
   yflag   = 1
   Temp1 = dispr - displ
   Temp2 = Temp1 Mod gridsize
   dispr = dispr - Temp2
   Temp1 = dispb - dispa
   dispb = dispb - Temp2
   ' Write the Play sound
   Wr16 Reg_Sound, &H50
   loopflag = 100
   While loopflag > 0
      Temp1 = xball + rball
      Temp1 = Temp1 + 2
      Temp2 = xball - rball
      Temp2 = Temp2 - 2
      If Temp1 >= dispr Or Temp2 <= displ Then
         xflag = xflag Xor 1
         Wr8 Reg_Play, 1
      Temp1 = yball + rball
      Temp1 = Temp1 + 8
      Temp2 = yball - rball
      Temp2 = Temp2 - 8
      If Temp1 >= dispb Or Temp2 <= dispa Then
         yflag = yflag Xor 1
         Wr8 Reg_Play, 1
      If xflag > 0 Then
         xball = xball + 2
      Else
         xball = xball - 2
      If yflag > 0  Then
         yball = yball + 8
      Else
         yball = yball - 8
      ClearColorRGB 128, 128, 0
      StencilOP IncrX, IncrX
      ColorRGB 0, 0, 0
      ' draw grid
      LineWidth 16
      Begin_G LINES
      Temp1 = Temp1 / gridsize
      For i = 0 To Temp1
         Temp2 = gridsize * i
         Temp2 = Temp2 + displ
         Vertex2F Temp2 * 16, dispa * 16
         Vertex2F Temp2 * 16, dispb * 16
      Next i
      For i = 0 To Temp1
         Temp2 = Temp2 + dispa
         Vertex2F displ * 16, Temp2 * 16
         Vertex2F dispr * 16, Temp2 * 16
      Next i
      End_G
      ColorMask 0, 0, 0, 0 'mask All the colors
      PointSize rball * 16
      Begin_G FTPOINTS
      Vertex2F xball * 16, yball * 16
      StencilOP Incrx, Zero
      StencilFunc GEQUAL, 1, 255
      ' one side points
      For i = 1 To numpoints
         asize = i * rball
         asize = asize * 2
         Temp1 = numpoints + 1
         asize = asize / Temp1
         TempDB = 2 * rball
         Temp2 = TempDB
         TempDB = asize / TempDB
         asmooth = smoothlerp(TempDB, 0, Temp2)
         If asmooth > rball Then
            'change the offset To -ve
            tempsmooth = asmooth - rball
            Temp1 = rball * rball
            Temp2 = tempsmooth * tempsmooth
            Temp1 = Temp1 + Temp2
            Temp2 = 2 * tempsmooth
            aradius = Temp1 / Temp2
            PointSize aradius * 16
            Temp1 = xball - aradius
            Temp1 = Temp1 + tempsmooth
            Vertex2F Temp1 * 16, yball * 16
         Else
            tempsmooth = rball - asmooth
            Temp1 = xball+ aradius
            Temp1 = Temp1 - tempsmooth
      Next i
      End_G
      Begin_G LINES
      ' draw Lines - Line should be At least radius diameter
      For i = 1 To numlines
         Temp1 = i * rball
         Temp1 = Temp1 * 2
         Temp1 = Temp1 / numlines
         asize = Temp1
         TempDB = 2 * rball
         Temp2 = TempDB
         asmooth = smoothlerp (TempDB, 0 , Temp2)
         LineWidth asmooth * 16
         Temp1 = xball - rball
         Vertex2F Temp1 * 16, Temp2 * 16
      Next i
      End_G
      ColorMask 1, 1, 1, 1 ' Enable All the colors
      StencilFunc ALWAYS, 1, 255
      StencilOP KEEP, KEEP
      Begin_G FTPOINTS
      Temp1 = xball - 1
      Temp2 = yball - 1
      ColorRGB 0, 0, 0 ' shadow
      Color_A 160
      Temp1 = xball + 16
      Temp2 = yball + 8
      Color_A 255
      ColorRGB 255, 0, 0
      StencilFunc GEQUAL, 1, 1
      End_G
      UpdateScreen
      Waitms 30
      Decr loopflag
   Wend
End Sub ' Ball_Stencil
   Local TempS As Single
   TempS = 1 - t
   TempS = TempS * a
   TempS = TempS + t
   TempS = TempS * b
   Lerp = TempS
End Function ' Lerp
   Local TempT As Single
   TempS = 3 * t
   TempS = TempS * t
   TempT = 2 * t
   TempT = TempT * t
   TempT = TempT * t
   smoothlerp = lerp (TempS-TempT, a, b)
End Function ' smoothlerp
Sub FtdiString
   Local hoffset As Integer, voffset As Integer, PointSz As Integer
   voffset = FT_DispHeight - 49 '49 Is the Max height of inbuilt Font Handle 31
   hoffset = FT_DispWidth - 144
   PointSz = 20
   hoffset = hoffset + PointSz
   Wr32 RAM_DL + 0, _Clear_B(1, 1, 1) ' Clear Screen
   Wr32 RAM_DL + 4, _Begin_G(BITMAPS) ' start drawing bitmaps
   Wr32 RAM_DL + 8, _Vertex2II (hoffset, voffset, 31, 70) ' ascii F in font 31
   hoffset = hoffset + 24
   Wr32 RAM_DL + 12, _Vertex2II (hoffset, voffset, 31, 84) ' ascii T
   hoffset = hoffset + 26
   Wr32 RAM_DL + 16, _Vertex2II (hoffset, voffset, 31, 68) ' ascii D
   hoffset = hoffset + 29
   Wr32 RAM_DL + 20, _Vertex2II (hoffset, voffset, 31, 73) ' ascii I
   Wr32 RAM_DL + 24, _End_G()
   Wr32 RAM_DL + 28, _ColorRGB (160, 22, 22) ' change Color To red
   Wr32 RAM_DL + 32, _PointSize(PointSz * 16) ' Set Point Size
   Wr32 RAM_DL + 36, _Begin_G (FTPOINTS)  ' start drawing points
   Wr32 RAM_DL + 40, _Vertex2II (hoffset, FT_DispHeight / 2, 0, 0)  ' red Point
   Wr32 RAM_DL + 44, _End_G()
   Wr32 RAM_DL + 48, _Display_E() ' Display the image
   DLSwap
   Wait 2
End Sub ' FtdiString
Sub StreetMap
   ' Call And Function Example - simple graph
   ClearColorRGB 236, 232, 224 'light gray
   Clear_B 1, 1, 1
   ColorRGB 170, 157, 136 'medium gray
   LineWidth 63
   Call_C 19 ' draw the streets
   ColorRGB 250, 250, 250 'white
   LineWidth 48
   Call_C 19 'draw the streets
   ColorRGB 0, 0, 0
   Begin_G BITMAPS
   Vertex2II 240,91,27,77 'draw 'Main st.' At (240,91)
   Vertex2II 252,91,27,97
   Vertex2II 260,91,27,105
   Vertex2II 263,91,27,110
   Vertex2II 275,91,27,115
   Vertex2II 282,91,27,116
   Vertex2II 286,91,27,46
   End_G
   Display_E
   Begin_G  Lines
   Vertex2F -160,-20
   Vertex2F 320,4160
   Vertex2F 800,-20
   Vertex2F 1280,4160
   Vertex2F 1920,-20
   Vertex2F 2400,4160
   Vertex2F 2560,-20
   Vertex2F 3040,4160
   Vertex2F 3200,-20
   Vertex2F 3680,4160
   Vertex2F 2880,-20
   Vertex2F 3360,4160
   Vertex2F -20,0
   Vertex2F 5440,-480
   Vertex2F -20,960
   Vertex2F 5440,480
   Vertex2F -20,1920
   Vertex2F 5440,1440
   Vertex2F -20,2880
   Vertex2F 5440,2400
   End_G
   Return_C
   UpdateScreen
   Wait 2
End Sub ' StreetMap
   ' Usage of Additive Blending - Draw 3 'G's
   Begin_G BITMAPS
   Vertex2II 50, 30, 31, &H47
   Color_A 128
   Vertex2II 58, 38, 31, &H47
   Color_A  64
   Vertex2II 66, 46, 31, &H47
   End_G
   UpdateScreen
   Wait 1
End Sub ' AdditiveBlendText
Sub MacroUsage
   ' Usage Of Macro
   Local xoffset As Long, yoffset As Long, xflag As Long, yflag As Long, flagloop As Long
   Local Temp1 As Integer
   ' Local p_bmhdr As SAMAPP_Bitmap_header_t
   xflag = 1
   yflag = 1
   flagloop = 1
   xoffset = FT_DispWidth / 3
   yoffset = FT_DispHeight / 2
   ' First Write a valid Macro instruction into macro0
   Wr32 REG_MACRO_0, _Vertex2F(xoffset * 16, yoffset * 16)
   RdFlash_WrFT800 RAM_G, TempDW, Header_Stride(0+_base) * Header_Height(0+_base)
   BitmapSource RAM_G
   Begin_G BITMAPS ' start drawing %BITMAPS
   Macro_R 0 ' draw the image At (100,120)
   End_G
   UpdateScreen
   flagloop = 300
   While flagloop > 0
       Temp1 =  xoffset + Header_Width(0+_base)
       If  Temp1 >= FT_DispWidth Or xoffset <= 0 Then
           xflag  = xflag Xor 1
       Temp1 = yoffset + Header_Height(0+_base)
       If Temp1 >= FT_DispHeight Or yoffset <= 0 Then
           yflag = yflag Xor 1
       If xflag > 0 Then
           Incr xoffset
       Else
           Decr xoffset
       If yflag > 0 Then
           Incr yoffset
       Else
           Decr yoffset
       '  update just the Macro
       Waitms 10
       Decr flagloop
   Wend
End Sub ' MacroUsage
   ' Additive blending Of points - 1000 points
   Local i As Long, hoffset As Long, voffset As Long, flagloop As Long ,j As Long
   Local hdiff As Long, vdiff As Long, PointSz As Long, t As Long
   Local Temp1 As Long, Temp2 As Long, Temp3 As Integer, Temp4 As Integer
   PointSz = 4
   flagloop = 20
   While flagloop > 0
      ColorRGB 20, 91, 20 ' green Color For additive blending
      BlendFunc SRC_ALPHA, ONE 'Input Is Source alpha And destination Is whole Color
      PointSize PointSz * 16
      Begin_G FTPOINTS
      ' First 100 Random values
      For i = 0 To 99
         hoffset = Rnd(FT_DispWidth)
         voffset = Rnd(FT_DispHeight)
         Vertex2F hoffset * 16, voffset * 16
      Next i
      ' Next 480 are sine values Of two cycles
      For i = 0 To 159
         ' i is x offset, y is sinwave
         hoffset = i * 3
         Temp1 = FT_DispWidth / 6
         Temp2 = -65536 * i
         Temp2 = Temp2 / Temp1
         Temp1 = qsin(Temp2)
         Temp2 = FT_DispHeight / 2
         Temp2 = Temp2 * Temp1
         Temp2 = Temp2 / 65536
         Temp1 = FT_DispHeight / 2
         Temp2 = Temp2 + Temp1
         voffset = Temp2
         For j = 0 To 3
            Temp3 = Rnd(24)
            hdiff = Temp3 - 12
            Temp4 = Rnd(24)
            vdiff = Temp4 - 12
            Temp1 = hoffset + hdiff
            Temp2 = voffset + vdiff
      End_G
      UpdateScreen
      Waitms 10
      Decr flagloop
   Wend
End Sub ' AdditiveBlendPoints
$inc Bitmap_RawData, nosize, "Bitmap_RawData.raw"       ' used in SUB Bitmap and SUB MacroUsage
$inc paletteraw, nosize, "lenaface40_palette.raw"       ' used in SUB BitmapPalette
$inc paletteLUT, nosize, "lenaface40_palette_LUT.raw"   ' used in SUB BitmapPalette
PostPosted: Wed Oct 15, 2014 1:55 pm    Post subject: Reply with quote
FT800 seems to be a very good product, typicaly English ! clever as Vinculum.
Is your lib works also with audio file ?
I saw also : $NOTYPECHECK and nothing in the help file about, But may be my view is not so accurate ?
Again bravo !
JP Wink
PeterM
PostPosted: Wed Oct 15, 2014 9:05 pm    Post subject: Reply with quote
JP
Audio files need to be converted to a Raw type of file before played (FTDI has utilities for this).
$NOTYPECHECK will stop the compiler complaining when assigning values to different variables types.
things like word to byte etc.. (Mark will explain more).
Peter
jhulsbergen
PostPosted: Thu Nov 13, 2014 3:44 pm    Post subject: Reply with quote
Hello Is the new bascom version, with the FT800 library allready done?
PostPosted: Thu Nov 13, 2014 3:59 pm    Post subject: Reply with quote
it is done but when you mean available, you either need SLA access or wait for the 2078 release. the homepage will have a newsitem when there is a new release. and when you have auto update notification on, you will notice at startup of bascom too.
Per Svensson
PostPosted: Tue Nov 18, 2014 5:51 pm    Post subject: FT800 Reply with quote
Although Mark already emphasized the great job that PeterM has done I would like to say it again.
I know he has performed an ENORMOUS task in this porting to Bascom, because i have seen his struggle
while helping out with a little testing and other small jobs. Remember that when you smoothly navigate
through the powerful functions. Peter did the hard work for you for free !!! (And Mark too of course)
My benefit from following the process has been to realize the enormous graphic power that lurks inside this tiny FT800 chip.
It can do things that an AVR would have no chance of coming even close to. It is a true graphics engine and once you take the
trouble of learning its command syntax (which can be daunting) you will never want any other Display.
The only drawback is that it comes with LCD's that are rather weak on luminance. In bright daylight it can be hard to see.
I imagine that the resistive touch film has something to do with it too. Slightly obscuring the display, Once the capacitive touch is available, it will probably be better.
I have used the FT800 display for an interactive Autopilot frontend with keyboard, Clock, Sliders, Rotating objects and other widgets.
It works very well, but was sometimes be hard to debug because the result on screen can go totally nuts when you write something wrong.
I remember I intended to display a rotating boat-hull (seen from above) and built it up as two mirrored copies of a half hull to save ROM image space in the AVR.
I almost got gray hair before I understood how to transfer the half-image. Then creating an FT800 ram copy. Then cloning a mirrored image. Then rotating them synchronously around a certain point along the joint...
But I learnt a lot, and the best is that it automatically get a very professional look.
Take your time to learn its features and you will just love it.
Then send flowers to Australia Smile !
/Per
olhexy
PostPosted: Fri Jan 16, 2015 10:12 pm    Post subject: Reply with quote
I landed here to discover more about qsin and qcos. It is not a question about the FTDI FT800 graphic chip.
Help says: http://avrhelp.mcselec.com/index.html
var = QSIN( source )
A numeric integer variable that is assigned with sinus of variable source.
source
The integer variable to get the sinus of.
What is meant with source? Radians? Degrees? Or an other subdivision of a circle? Or is it a hyperbolicly super inverse squared thing?Rolling Eyes
As far as I understand these "var" integers are 0, 1, 2, 3, 4... and so on. But usually every sine is a fp between -1 and +1 Rolling Eyes
I would like to be informed about the magic that creates the integers from the fp's from -1 to +1!
Please give a more accurate definition of this official new "qsin" and "qcos" words in Bascom!
PeterM
PostPosted: Sat Jan 17, 2015 10:46 am    Post subject: Reply with quote
Olhexy
The qsin/qcos have a precision is 16 bit, but if you look at the
FT800 Gauges.bas demo, with your Maths knowledge it should
give you some answers.
(Otherwise give me a couple of days and I will sort it out for you).
Peter
olhexy
PostPosted: Sat Jan 17, 2015 1:26 pm    Post subject: Reply with quote
Hi Peter,
Please sort it out for us. Give the facts.
I will give my thoughts.
bascom integer
Value: -32768 bis +32767
To discribe all possible angles with this integer I (but I am not Bascom) would define +/- 180° = +/-32768 = "source"
(Or should the mutiplier be 32767?)
79° gives 79°/180° x32768 for "source". So "source" =14381,51111.
It is up to the programmer to round to 14382 or chop at 14381.
In the same way I would define "var" = {sine represented as fp} * 32768
If this value should be rounded or chopped is not defined. Probably the definition should be: "var"/32768 = sine represented as fp.
This is my interpretation of what Bascom could try to achieve.
It is only a bloody guess.
BTW: we also have a 2 byte Word (value 0 to 65535) that could perfectly be used to represent an angle for 0° up to 360°.
I think it is Bascom and not me who should give the definitions.
EDIT: It could be an implementation of http://www.mikrocontroller.net/articles/AVR_Arithmetik/Sinus_und_Cosinus_%28Lineare_Interpolation%29 that gives a fast (max 60...74 cycles) 16bit result.
Per Svensson
PostPosted: Mon Feb 09, 2015 5:07 pm    Post subject: Reply with quote
Olhexy,
Run this small test and you will see that the argument range is -32768 to +32767
and the output range is also -32768 to +32767
So:
-32768 correspond to -180 deg (or -Pi)
+32767 correspond to +180 deg (or +Pi)
-32768 correspond to SIN(-180deg) or SIN(-Pi)
+32767 correspond to SIN(+180deg) or SIN(+Pi)
End of guesswork?
/Per
Dim I As Integer
Dim Trig As Integer
Print "SINTABLE"
For I = -32768 To 32767 Step 4096
Trig = Qsin(i)
Print I ; " " ; Trig
Next I
Print
Print "COSTABLE"
For QSINE
this becomes:
SINTABLE
-32768 0
-28672 -12539
-24576 -23169
-20480 -30272
-16384 -32767
-12288 -30272
-8192 -23169
-4096 -12539
0 0
4096 12539
8192 23169
12288 30272
16384 32767
20480 30272
24576 23169
28672 12539
32767 0
Robert_d1968
PostPosted: Sat Feb 28, 2015 12:50 pm    Post subject: Reply with quote
Thank you guys,
I have been working with the FT800 and the STM32F407 series of MCU's.
I was wondering if Bascom would put this together, Now that you have I would like to get the beta release for this ft800 controller.
I will be sending an email to support ASAP!
Thanks again,
Robert
PostPosted: Sat Feb 28, 2015 12:58 pm    Post subject: Reply with quote
Beta is closed and in current release 2078. So no need to mail support. Just look at the samples and help.
mototest2
PostPosted: Sat Feb 28, 2015 6:59 pm    Post subject: Reply with quote
Hi Guys
I need help, how detect pressed key created by CmdButton ?
and I have one question , in demo files in some demos is lline "'RdMem_WrFT800.." it always generate errors when I use Xmega, how I can resolve it ?
I have display 4.3" 480x272
Thanks
Bob
PeterM
PostPosted: Sun Mar 01, 2015 2:41 am    Post subject: Reply with quote
Bob
Before you create a Button (CmdButton) you need to assign it with a TAG number (or a label) so
it can be identified (this applies for any Object/Graphic you want to create to you can identify it).
Then you need to poll and read the value from Rd8(Reg_Touch_Tag) so it can tell you which Object you
clicked on (similar to Inkey,Waitkey, Input).
If you look at Widget_Keys_Interactive.bas and FT800 Keyboard.bas
it will give you a better understanding.
As for the Xmega error, may have to wait for Mark to check.
Peter
PostPosted: Mon Mar 02, 2015 12:08 am    Post subject: Reply with quote
bob,
use this code :
   For Ti = 1 To Count
      R24 = Inp(varadr)
      !call _ft_spi
'#if _xmega
'    Print #10, Varadr
'#Else
'    Spiout Tb , 1
'#EndIf
      Incr Varadr
the problem is that the SPI is not opened with #10. so you could also open the SPI channel in the main code.
But a better solution is to call the lib directly as the code above does.
Page 1 of 4
