Split Integer into 2 bytes
KenHorse
PostPosted: Fri Nov 14, 2014 8:19 pm    Post subject: Split Integer into 2 bytes Reply with quote
Ok, so why doesn't this work?
$regfile = "m128def.dat"
$hwstack = 800
$swstack = 600
$framesize = 100
$baud = 9600
 Dim TempInteger As Integer
 Dim TempByte As Byte
 Dim TempByte2 As Byte
TempInteger = 1006
TempByte = High(TempInteger)
TempByte2 = Low(TempInteger)
Print Tempbyte ; TempByte2
Result is 3238
I was expecting 1006?
PostPosted: Fri Nov 14, 2014 8:57 pm    Post subject: Reply with quote
numbers of base 10 system which we use, can not be stored in a computer with base 10 since the computer only knows 0 and 1.
So numbers are binary coded. And we group 8 bits into a byte. For 8 bits, we can represent maximum 255 : 1111_1111 : 128+64+32+16+8+4+2+1
If we want bigger numbers for an integer/word we use 2 bytes. The LSB is still representing 0-255 but the MSB has a different weight : 256+512+1024+2048 etc.
If you use low() you get the LSB. If you use high() you get the MSB. But when printing these bytes, they loose their weight/significance. And you print as a decimal number.
So 3 means 3*256 and 238 need to be added : (3*256) + 238 which should make 1006.
Use the simulator to have a look at the bits and bytes.
consider what you was expecting for values like 32000 and 3271 ?
KenHorse
PostPosted: Fri Nov 14, 2014 10:00 pm    Post subject: Reply with quote
I didn't take into account the weighting issue when trying to print those values.
My main concern is that an integer with a value of 1006 can be split into 2 bytes with actual values of 10 and 6 respectively. Are you saying low() and high() do that but that can't actually be printed but the bytes do contain the correct values for other uses?
PostPosted: Fri Nov 14, 2014 10:13 pm    Post subject: Reply with quote
when you use someInt=1006, it will be assigned with a binary number, the only number that can be used. have a look in the simulator.
1006 is just like we humans want to see a number. when you use INPUT , this decimal number is converted into binary. and when you use PRINT, this binary number is converted into a decimal string.
you can use str() to get a string, and then use left/right/mid or str2digits.
KenHorse
PostPosted: Fri Nov 14, 2014 10:27 pm    Post subject: Reply with quote
Thanks Mark
I was hoping to have smaller compiled code than using strings but I guess it is what it is......
PostPosted: Fri Nov 14, 2014 11:18 pm    Post subject: Reply with quote
A = I \ 100
B = I MOD 100
KenHorse
PostPosted: Fri Nov 14, 2014 11:36 pm    Post subject: Reply with quote
MWS wrote:
A = I \ 100
B = I MOD 100
Nope
Produces "2" and "38"
PostPosted: Fri Nov 14, 2014 11:54 pm    Post subject: Reply with quote
If 1006 divided by 100 gives you 2, you do something seriously wrong.
PostPosted: Fri Nov 14, 2014 11:57 pm    Post subject: Reply with quote
if you want integer division, the assigned variable need to be an integer too.
KenHorse
PostPosted: Sat Nov 15, 2014 12:34 am    Post subject: Reply with quote
Indeed
TempInteger2 = TempInteger \ 100
Byte1 = TempInteger2
TempInteger2 = TempInteger MOD 100
Byte2 = TempInteger2
Works just fine (and saves quite a bit of compiled space compared to handling the string equivalent)
Danke!
