SPI Soft Bit order
StefanHamburg
PostPosted: Mon Nov 10, 2014 10:05 am    Post subject: SPI Soft Bit order Reply with quote
Hello,
one question regarding the configuration for Soft-SPI:
In BASCOM-8051 the Help says
CONFIG SPI = SOFT, DIN = PIN, DOUT = PIN , CS = PIN, CLK = PIN ,DATA ORDER = DO, NOCS =
DATA ORDER
Use MSB or LSB. With MSB, MS bit will be sent first. LSB option will send the LS bit first.
whereas in BASCOM-AVR the Help says:
Syntax for software SPI
CONFIG SPI|SPISOFT = SOFT, DIN = PIN, DOUT = PIN , SS = PIN|NONE, CLOCK = PIN , SPIIN=value , MODE=mode
How can I configure the Bitorder in BASCOM AVR for Soft-SPI?
(I understand that MODE is for configuring cpol and cpha)
Thank you
Regards
Stefan
PostPosted: Mon Nov 10, 2014 10:46 am    Post subject: Reply with quote
hi Stefan
The soft spi is MS bit first. And this is fixed. But if you require it,send me a private email and we can discuss it.
