I2C slave with Mega88a
Plons
PostPosted: Thu Nov 06, 2014 10:51 pm    Post subject: I2C slave with Mega88a Reply with quote
Hi folks,
From the m88adef.dat file:
    [I2CSLAVE]
    POSSIBLE=YES ; software slave mode not possible
    PORT=D,4,2 ; PORTD , SCL D.4(T0) , SDA D.2(INT0)
The 2nd line puzzles me: Is I2C slave possible or not ?
Edit: corrected tags
Bascom AVR ver 2.0.8.1
ProtectedParallelPortProgrammingDongle: http://www.aplomb.nl/TechStuff/PPPD/PPPD%20English.html
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel"
PostPosted: Thu Nov 06, 2014 10:58 pm    Post subject: Reply with quote
yes, you can create an I2C slave using the TWI. : config twislave
when the AVR has TWI,USI, TWIC,TWID,TWIE or TWIF it is always possible to create a hardware i2c slave.(using the add on)
when these hardware source are not present in the avr, you can create a software twi slave in most cases.
Plons
PostPosted: Thu Nov 06, 2014 11:38 pm    Post subject: Reply with quote
Thanks Mark.
But my puzzle is with the contradiction (in red font)
Cheers
Nard
PostPosted: Thu Nov 06, 2014 11:55 pm    Post subject: Reply with quote
Did you actual tried to create the i2c slave? and is there a problem?
Or are you really creating a topic because of comment in a dat file?
Plons
PostPosted: Fri Nov 07, 2014 12:38 am    Post subject: Reply with quote
Sorry Mark, I was not working on I2C slave but was going through the .dat-file to find something else when I noticed this contradiction. It just puzzled me.
Correct .dat-files are crucial IMO
Nard
PostPosted: Fri Nov 07, 2014 11:26 am    Post subject: Reply with quote
you start your topic with :
then i take the time to answer, and then it turns out that it was not about the i2cslave but just if the remark was ok. Please be clear when you want to point to what you think is an error.
I wonder what good it is to post it on a user forum? Do you expect a user to know the answer? About an internal compiler setting that is not intended to be altered/used by the user?
When you suspect that something is wrong just write so. And best send it to support, the only place where it (at some stage) will be read. Something that is not guaranteed here.
btw:
The dat files in bascom-avr are not intended to be edited by the user. otherwise i would have included a dat file editor. of course you are free to alter but an update will overwrite these changes.
Plons
PostPosted: Fri Nov 07, 2014 12:56 pm    Post subject: Reply with quote
Point taken, bad judgement from me, it was late. I apologize for that.
Nard
PostPosted: Fri Nov 07, 2014 1:17 pm    Post subject: Reply with quote
no problem. all my answers are for all users and never personal.
