Config Porta.0 = Output : Porta.0 = 0 : LED Alias Porta.0
Toggle LED
Waitms 500
after compilation I received error : Error : 202 Line : 1 .EQU not found, probably using functions that are not supported by the selected chip [WDTCR] , in Files : D:\ .....
second problem :
when I selected attiny841.dat then I received error : DAT File: ATTINY841.DAT, not found
and it is true, not this file no MCS Bascom folders but when early made updates, I saw information : " attiny441 and attiny841 dat files added "
from the 2077 history : - attiny441 and attiny841 dat files added. Not tested with a sample chip yet.
as usual, it is a bad idea to provide untested dat files. but as there was no sample chip (and we never got them from atmel) i had to wait for farnell which was also delayed. a customer send me a tiny441 so i could finally test it.
the 441 has a changed design so some mods were required for the compiler and the dat file as well. These are great chips with lot of hardware on board. And small and cheap!
you do need an update. just the dat files are not sufficient otherwise i would upload them.
you can contact support and ask for a beta. _________________ Mark
