XMEGA RST_STATUS
enniom
PostPosted: Tue Oct 28, 2014 7:20 pm    Post subject: XMEGA RST_STATUS Reply with quote
The BASCOM example code shown in "XM128-reset.bas" demonstrates that reading the register RST_STATUS provides the indication/reason of the last restart.
'-------------------RESET STATUS------------------------------------------------
Print Bin(rst_status)                                       'print reason for reset
If Rst_status.0 = 1 Then
   Print "Power On Reset"
   Set Rst_status.0                                         'clear it
If Rst_status.1 = 1 Then
   Print "External Reset"
   Set Rst_status.1                                         'clear it
If Rst_status.2 = 1 Then
   Print "Brown out Reset"
   Set Rst_status.2                                         'clear it
If Rst_status.3 = 1 Then
   Print "Watchdog Reset"
   Set Rst_status.3                                         'clear it
If Rst_status.4 = 1 Then
   Print "Program and Debug Interface Reset"
   Set Rst_status.4                                         'clear it
If Rst_status.5 = 1 Then
   Print "Software Reset"
   Set Rst_status.5                                         'clear it
My experience is that the value of RST_STATUS is always 0 - whether accessed from the Bootloader or Main Flash memory areas.
Is there a different way to determine the reason for the re-start?
Thank-you.
PostPosted: Tue Oct 28, 2014 8:20 pm    Post subject: Reply with quote
Looks like the sample is wrong. the reset status register Rst_status is cleared in the course of startup, so it makes no sense to read it.
Try it this way:
$swstack = 40
$framesize = 40
Dim r_stat as  Byte
!STS  {r_stat}, R0
Print "test reset"
Print Bin(r_stat)                                       'print reason for reset
If r_stat.0 = 1 Then
enniom
PostPosted: Tue Oct 28, 2014 8:33 pm    Post subject: Reply with quote
Thank-you MWS for taking the time to help.
As expected, your solution worked perfectly - incredible.
PostPosted: Tue Oct 28, 2014 8:44 pm    Post subject: Reply with quote
yes this sample is not right anymore. It was working right till the moment rst_status was reset at startup. (same as in normal AVR).
I have added this to the sample :
dim bReset as Byte 'reset byte
bReset=Getreg(r0)
complete sample :
'                  (c) 1995-2014, MCS
'                      xm128-reset.bas
'  This sample demonstrates how to read out the reson for reset
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 40
$framesize = 40
bReset=Getreg(r0)       ' reset is in R0 so get it early at startup
'configure the systemclock
Config Portd.0 = Output
Config Portd.1 = Output
Set Portd.0                                                 ' special xmega handling for set,reset and toggle
Waitms 1000
Reset Portd.0
Waitms 1000
Toggle Portd.0
Print "test reset"
Print Bin(bReset)                                       'print reason for reset
If bReset.0 = 1 Then
If bReset.1 = 1 Then
If bReset.2 = 1 Then
If bReset.3 = 1 Then
If bReset.4 = 1 Then
If bReset.5 = 1 Then
   Waitms 5000                                              'wait 5 secs
   Cpu_ccp = &HD8                                           ' write protecion register
   Rst_ctrl.0 = 1                                           ' software reset
