TCXO for atmega 8, 168 or 328
F5JTZ
PostPosted: Wed Oct 22, 2014 9:52 am    Post subject: TCXO for atmega 8, 168 or 328 Reply with quote
Hello
someone should put in place unn TCXO 10, 16 or 20,000 Mhz instead of one quartz on Atmega 8, 168, or 328 or otherwise ?
If you have a schema for TCXO with output square wave or sinusoidal, thanks in advance.
Pat / France
(BASCOM-AVR version : 2.0.7.3 , Latest : 2.0.7.7 )
sidknox
PostPosted: Thu Oct 23, 2014 1:51 am    Post subject: TCXO Reply with quote
Pat,
I am not sure what you are asking, but maybe this?
Here are many TCXO, some quite inexpensive.
http://www.ebay.com/sch/i.html?_odkw=crystal+oscillator&_ftrt=901&_sop=12&_sadis=15&_dmd=1&_osacat=0&_ipg=50&_ftrv=1&_from=R40&_trksid=p2045573.m570.l1313&_nkw=crystal+oscillator+TXCO+TCXO&_sacat=0
73, Sid W7QJQ
SidK
Oklahoma
USA
F5JTZ
PostPosted: Thu Oct 23, 2014 9:01 am    Post subject: Reply with quote
Hello
I research the wiring between a TCXO and an Atmega diagram.
Depending on whether the output of the TCXO is sinusoidal or square what adjustment needs to be done ?
O-Family
PostPosted: Thu Oct 23, 2014 10:26 am    Post subject: Reply with quote
Hi
The power supply voltage of AVR and a TCXO oscillator is the same, and if the output of TCXO is a square wave, the direct entry of it will be carried out to the [XTAL1] pin of AVR.
If the output of TCXO becomes in a clipped sine wave (DC cut), you must add an offset voltage to the clock.
In this case, the voltage of the sine wave is required 2Vp-p or more if 5V power supply voltage.
Frequency Counter 1
http://pub.idisk-just.com/fview/Lx0Fg4Aso3y4650JY6VZcfKvW3vbgygRZx7T5pHF9q78z63Qfh8SGWPr41Is9iUIPUNRxncg-sjTSFBSweYLEX076a-emQeMDBWZCAW7-t8.gif
Frequency Counter 3
http://www.ne.jp/asahi/shared/o-family/ElecRoom/AVRMCOM/AVRFrqCun3/FrqCun3Cir.pdf
F5JTZ
PostPosted: Thu Oct 23, 2014 11:39 am    Post subject: Reply with quote
Hello
Thanks for this information very precise
Pat / France
