double < 0
uga237
PostPosted: Tue Aug 12, 2014 2:20 am    Post subject: double < 0 Reply with quote
Dim test as double
test = 12345
IF test < 0 then 'some time fail
IF test < 0.0 then 'work good
why?
PostPosted: Tue Aug 12, 2014 9:05 am    Post subject: Reply with quote
0 and 0.0 are the same and will give the same result. if you compile 2 different samples and compare the output you will find they are (binary) identical.
so please produce a sample that demonstrates this problem.
Or send a sample/code to support.
six1
PostPosted: Tue Aug 12, 2014 2:18 pm    Post subject: Reply with quote
http://wiki.mcselec.com/bavr/Language_Fundamentals/#Floating-Point_Complications
For technical reasons, the signature is on the back of this message.
uga237
PostPosted: Thu Aug 14, 2014 6:05 am    Post subject: Reply with quote
http://wiki.mcselec.com/bavr/Language_Fundamentals/#Floating-Point_Complications - and?
six1
PostPosted: Thu Aug 14, 2014 10:32 am    Post subject: Reply with quote
in my mind, you didn't understand, that in binary system you can not show all possible floatingpoint numbers.
Read the help and think about.
regards, michael
uga237
PostPosted: Thu Aug 14, 2014 2:13 pm    Post subject: Reply with quote
Michael.
You don't understand my question about compare Double and Zero.
Think about.
Ivan.
six1
PostPosted: Thu Aug 14, 2014 4:22 pm    Post subject: Reply with quote
ahh, ok... that can be the solution...
i do not understand and therefore your code doesn't work... Laughing
You ask about precision and have doubt about my skill?
Maybe you better start debug and have a look for what exactliy going on in your micro...
best, michael
uga237
PostPosted: Fri Aug 15, 2014 3:44 am    Post subject: Reply with quote
You ask about precision and have doubt about my skill? - no
Some time positive double value lower then Zero.
Why precision?
my code is very big size. i try simulate this on small code and post here.
And sorri my english ) I am from Russia.
P. S. ..and have doubt about my skill?.. - i smile )))
