Ethernet Bootloader for Easy TCP/IP
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
TR6
PostPosted: Sun Aug 03, 2014 5:40 pm    Post subject: Ethernet Bootloader for Easy TCP/IP Reply with quote
just a short question: is there any source code / demo code available for the above topic.
Thanx in advance.
Best regards,
Arera
PostPosted: Wed Aug 06, 2014 12:05 pm    Post subject: Reply with quote
Hi Mark and welcome!
I'm afraid there is no simple answer, that why there is no response yet.
I got an ethernet bootloader running, but you cannot just copy it, unless you use
-WIZ820IO module
-ATmega1284
-external EEPROM 24A1025
BTW it would take me hours to strip down my prog to leave only the BL part.
Here's how it works:
A little proggy on a PC loads up the .hex file to the ATmega1284 line by line.
Data of each line is stored away to the EEPROM.
Then the bootloader is started and writes data from the external EEPROM to the megas flash.
Marc
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
