pwm with smoothly frequency and duty cycle with timer0
mototest2
PostPosted: Fri Jul 11, 2014 10:54 am    Post subject: pwm with smoothly frequency and duty cycle with timer0 Reply with quote
Hi All
Please help me, I need make PWM with timer0 with adjusted frequency 0-250Hz and duty cycles 0-100%
with Timer1 all work good, but I must use timer0 and it don't work , can you help me ?
here is with TIMER1 :
Dim Duty_cycle_count As Long
Dim Frequency As Single
Dim Period As Single
Dim Timer_count As Long
Dim Duty_cycle As Byte
Const Timer_tick = 1000000000 / _xtal * 2
Tccr1a = &B01100011
Tccr1b = &B00010001
Config Portb.2 = output
Config Portb.1 = input
' in timer1 pinb.2 and b.1 are connected together
frequency = 180
duty_cycle = 50
do
call pwm_parameters
loop
sub pwm_parameters
Period = 1000000000 / Frequency
Timer_count = Period / Timer_tick
Tmp = Timer_count / 256
Ocr1ah = Tmp
Tmp = Timer_count Mod 256
Ocr1al = Tmp
Period = Timer_count * Duty_cycle
Duty_cycle_count = Period / 100
Compare1b = Duty_cycle_count
end sub
Thanks
Bob[/code]
PostPosted: Fri Jul 11, 2014 8:25 pm    Post subject: Reply with quote
Used micro is important thing i this case Wink
mototest2
PostPosted: Fri Jul 11, 2014 8:29 pm    Post subject: Reply with quote
Atmega48
PostPosted: Wed Jul 16, 2014 4:16 pm    Post subject: Reply with quote
Sorry for long time for answear. My holidays with mor of % Very Happy ....This is even for Timer2 so if You don`t have done it yet I can help.
mototest2
PostPosted: Wed Jul 16, 2014 4:22 pm    Post subject: Reply with quote
I tried different method and don't work, must be timer0 not timer2 ,because I have free only pind.5 or pind.6
PostPosted: Wed Jul 16, 2014 8:48 pm    Post subject: Reply with quote
If I understand datasheet enough.. This config means : Mode 11,PWM Phase Correct, No prescale.
If Im not wrong then in Timer0 CompareB You can use only in CTC mode.
When for Timer1 ByteH and ByteL is used then for 8Bit timer propably..all must be recalculated.
PostPosted: Thu Jul 17, 2014 9:17 am    Post subject: Reply with quote
I`m not profi with programming and steel learning but this is my little idea.
 Output_pin Alias Portb.5
Dim Freq As Word
Dim Freq_copy As Word
Dim Duty_cycle As Word
Dim Duty_copy As Word
Dim Timer_load As Byte
Dim Change_flag As Bit
' Timer0 in CTC mode, Freq and Duty must be calculated first
' for crystal
If Output_pin = 1 Then
 Select Case Freq _copy
   Case 0
     Change_flag = 1
     Duty_copy = Duty_cycle
     If Duty_copy > 255 Then
     Timer_load = 255
     Duty_copy = Duty_copy - 255
     Else
     Timer_load = Duty_copy
     Duty_copy = 0
   Case Is < 255
     Timer_load = Freq_copy
     Freq_copy = 0
   Case Is > 255
    Timer_load = 255
    Freq_copy = Freq_copy - 255
  End Select
If Output_pin = 0 Then
 Select Case Duty_copy
    Case 0
     Change_flag = 1
     Freq_copy = Freq
     If Freq_copy > 255 Then
     Timer_load = 255
     Else
     Freq_copy = 0
    Case Is < 255
     Duty_copy = 0
    Case Is > 255
     Timer_load = 255
  End Select
Timer0_isr:
Compare0a = Timer_load
If Change_flag = 1 Then
   Change_flag = 0
   Toggle Output_pin
I dont know is this fast enough and whats happend when value for freq or duty be close to 0. Today don`t have time for testing.
I forgot that Cases must be 0 - <255 - >255 and I fix it now.
