sub does not work?
Paulvk
PostPosted: Thu Jul 03, 2014 10:59 am    Post subject: sub does not work? Reply with quote
Why does the sub not work?
All I have done is to put the two lines of code into a sub so not to have to repeat them multiple times the variables are global!
Regards Paul
                     Wsize = Len(txbuffer)
                     ' Bsize = Len(txbuffer)
                      'Call Buffer_send                      ' (Bsize global)
                       Call Activate_wiz812
                     Tempw = Tcpwrite(i , Txbuf(1) , Wsize) ' i global
   End Select
End Sub
Sub Buffer_send
        Local Tempj As Word
                      Tempj = Tcpwrite(i , Txbuf(1) , Bsize)       ' write data  (I global)
End Sub
PostPosted: Thu Jul 03, 2014 11:44 am    Post subject: Reply with quote
when you move code to a sub it should work just fine as long as you have enough $hwstack since it will create an additional stack level.
you really should post something we can check. for example the version that works, and the version you modified and doesnt.
Paulvk
PostPosted: Thu Jul 03, 2014 12:30 pm    Post subject: Reply with quote
Hello Mark
Trouble is posting a version that works is its too big, now 14 inter-related subs I can only put the whole lot up as a zip but I just posted the small bit of code to show that simply putting it into the sub it did not work , it compiles ok just does not work , as you say just moving it to a sub should work Note the stacks are fine I added 100 to each to test if they were the problem.
Just for interest sake and it shows how to do redirection in the browser, here is the whole sub with multiples of those 2 lines you can see where I commented the calls. Also I tried making Wsize global I am not going to try to find this it wastes too much time it works ok with multiples of the 3lines of code, just thought maybe I was doing something wrong.
Regards Paul
' send data from SD Card
'error codes
'66 file not found
Sub Sd_html
   Local Fl As Long
  ' Local Wsize As Word
   Local Tempw As Word
   Local Lb As Byte
   Local Lc As Byte
   Local Lz As Byte
   Local Lf As Word                                         'we keep track of the number of bytes in the buffer
   Local Ltxt As String * 30
   Lf = 0
   Txbuffer = ""                                            'clear buffer
   '=Redirection of pages    this will be needed for later
 '     Http / 1.1 301 Moved Permanently
'      Location : Http : / / Www.example.org/
   Select Case Redirect
    Case 0                                                  'no redirection
      Txbuffer = "HTTP/1.0 200 OK{013}{010}"                'put the OK response in the buffer
 '==as we have a file type variable need to re write this
           Select Case Ext
               Case "ico" : Txbuffer = Txbuffer + "Content-Type: image/x-icon{013}{010}"
               Case "gif" : Txbuffer = Txbuffer + "Content-Type: image/gif{013}{010}"
               Case "jpg" : Txbuffer = Txbuffer + "Content-Type: image/jpeg{013}{010}"
               Case "js" : Txbuffer = Txbuffer + "Content-Type: application/x-javascript{013}{010}"
               Case "css" : Txbuffer = Txbuffer + "text/css{013}{010}"
               Case Else : Txbuffer = Txbuffer + "Content-Type: text/html{013}{010}"
           End Select
          '#if Cdebug
             Print "send " ; Shtml ; " on Sock= " ; I
           '#endif
           Call Activate_sdcard()
      Fl = Filelen(shtml)                                   'find the length of the file
          '  #if Cdebug
              Print "size :" ; Fl
           ' #endif
       If Fl > 0 Then
           ' This header indicates the number of bytes in the response.
           'This information is needed only if the browser is using a persistent (keep-alive) HTTP connection.
             Tempw = Instr(buffer , "keep-alive")
              If Tempw > 0 Then
                   Txbuffer = Txbuffer + "Content-Length: " + Str(fl) + "{013}{010}"
                 Txbuffer = Txbuffer + "{013}{010}"         ' add additional CR and LF
                 Lf = Len(txbuffer)
                 Tempw = Tcpwrite(i , Txbuf(1) , Lf )       'send response
              Open Shtml For Binary As #4
                If Filetype = 4 Then                        'this is a cgi file
                          ' Print "filetype=4"
                         Lf = 0
                          Get #4 , Lb , , 1                 'get one byte
                          Decr Fl                           'we have read one byte
                      If Lb = 126 Then                      'then its ~
                        Get #4 , Tmpb(1) , , 2              'get the next two bytes as this is the hex value
                          Replacemnt = ""
                        Call Hex_replace(tmp2)              'tmp2 contains the hex value as a string
                        Lc = Len(replacemnt)                'find out how many bytes we insert
                            If Lc > 0 Then                  'there are bytes in string
                              For Lz = 1 To Lc
                                  Incr Lf                   'move to next free byte in buffer
                                  Txbuf(lf) = Rpl2(lz)      'insert byte from string replacemnt
                           Decr Fl                          'we have read 2 bytes
                           Decr Fl
                         Else
                           Incr Lf                          'add 1 to the buffer size pointer
                          Txbuf(lf) = Lb                    'put byte into buffer
                        If Lf > 800 Then                    'buffer is full  with 200 bytes  of space for inserted bytes
                           Exit Do
                   Loop Until Fl = 0
                          Wsize = Lf                        'number of bytes in the tx buffer
                     Lf = 0
                  Else                                      'send the file
                         ' Print "Not CGI >" ; Filetype
                         If Fl > 1000 Then                  'send 1000 Bytes
                               Get #4 , Txbuf(1) , , 1000
                               Fl = Fl - 1000 : Wsize = 1000
                           Else
                              Get #4 , Txbuf(1) , , Fl      'send the rest
                                 Wsize = Fl : Fl = 0
                   'Print "Wsize>" ; Wsize
                    'Print "Fl>" ; Fl
                   ' Call Buffer_send                        ' (wsize)
                      Tempw = Tcpwrite(i , Txbuf(1) , Wsize)       ' write data
                    If Tempw <> Wsize Then
                       #if Cdebug
                          Print Tempw ; " - " ; Wsize ; " written : error"       'when error
                       #endif
                       Exit Do
            Loop Until Fl = 0
         Close #4
          Else                                              'file does not exist
              Print "file does not exist"
          Txbuffer = ""
                   Shtml = "error404.htm"                   'make a variable so this can be set
             Fl = Filelen(shtml)                            'custom error file
               If Fl > 0 Then                               'there is a custom error file
                  Tempw = Tcpwrite(i , "HTTP/1.0 404 Not Found{013}{010}{013}{010}" )       'send response
                           Else
                                 Wsize = Fl : Fl = 0
                      'Call Buffer_send                      ' (wsize)
                   Loop Until Fl = 0
                   Close #4
                   Else
                      '==send page from flash
                  ' Print "Send file not found page"
                    'Call Activate_wiz812
                    Txbuffer = ""
                    Restore Notfound_page                   'restore the data pointer
                       Read Ltxt                            'read data
                       If Ltxt = "endblock" Then            'end of data
                               Exit Do
                      Txbuffer = Txbuffer + Ltxt
                      'Print "Buffer is >" ; Wsize ; "<Bytes"
                      'Print Txbuffer
     Case 1                                                 'we will be redirecting to a url
              Txbuffer = Txbuffer + "Refresh: 0; Url=Http://192.168.0.192/"
              Txbuffer = Txbuffer + Shtml
              Txbuffer = Txbuffer + "{013}{010}{013}{010}"
              Txbuffer = Txbuffer + " Content -type : Text / Html{013}{010}"
              Print "REDIRECT"
              Print Txbuffer
   End Select
End Sub
Sub Buffer_send
        Local Tempj As Word
End Sub
PostPosted: Thu Jul 03, 2014 12:45 pm    Post subject: Reply with quote
of course i mean you need to zip it.
just as with support, i do not have time to look at big programs. so i usually ask for 2 versions : one that is ok, and one that is modified. Or the code can have some remarks that must be unremarked or remarked to show the problem. i then check both codes with windiff or so and also the output. but posting fragments of code is not helping since i can not compile. i do not have time to add in the missing vars. and even when i have, i could use different types which lead to possible different results.
now you said you just moved the lines. but that is not true for the code you show. (at least when you mean buffer_send)
- you added a new var and also use a new name now for the return result. maybe your code depends on the first used var name?
if you really only move code then it means you select, cut and replace with a call.
