Tacho
Tubeampman
PostPosted: Thu Jun 26, 2014 9:59 pm    Post subject: Tacho Reply with quote
Hi
has someone made a tachometer with 1 rpm resolution and can give me som hints on how this can be done.
Let say we have an engine with a sensor that give us one puls pr. revolution.
If i calculate the frequency i can get more than 60rpm resolution.
Am not asking for someone to make the code for me, just a formula or some basics.
Thanx
Øyvind
kimmi
Moderator
PostPosted: Thu Jun 26, 2014 11:09 pm    Post subject: Reply with quote
Hi Øyvind
did you see AN #138 - RPM meter
/ Kim
View user's profile Visit poster's website MSN Messenger
AdrianJ
PostPosted: Fri Jun 27, 2014 3:52 am    Post subject: Reply with quote
AN 138 seems remarkably complicated.
With 1 pulse per rev, just measure the time between pulses using a high speed timer, like eg timer1. The timer input capture function works well for this. Set the prescaler to give a count which does not overflow at the lowest possible engine speed.
Then the rpm is just 60,000,000/timer count, if the count is in microsec. Scaling the count to the actual clock frequency and divider used is pretty obvious.
Adrian Jansen
O-Family
PostPosted: Fri Jun 27, 2014 9:10 am    Post subject: Reply with quote
Original page
http://www.ne.jp/asahi/shared/o-family/ElecRoom/AVRMCOM/RevCounter/RevCounter.html
Google translation
http://translate.google.com/translate?hl=ja&sl=ja&tl=en&u=http%3A%2F%2Fwww.ne.jp%2Fasahi%2Fshared%2Fo-family%2FElecRoom%2FAVRMCOM%2FRevCounter%2FRevCounter.html&sandbox=1
Tubeampman
PostPosted: Fri Jun 27, 2014 2:54 pm    Post subject: Reply with quote
Hi
Thanx to all of you for helping me, now i have the formula from Adrian and finished code to look at Smile
Øyvind
