PWM problems on atmega328
boeseturbo
PostPosted: Fri Jun 27, 2014 2:03 pm    Post subject: PWM problems on atmega328 Reply with quote
I tried to use PWM (timer0) on atmega328. I didnt got any output on pwm. If I toggle the pin directly (toggle outputpin) I can change the level from low to high and high to low. But no PWM on this pin Sad
$regfile = "m328def.dat"
$baud = 38400
$hwstack = 300
$swstack = 300
$framesize = 300
Config Pind.5 = Output
Config Timer0 = Pwm , Prescale = 1 , Compare B Pwm = Clear Up
Enable Timer0
Start Timer0
pwm0b =128
pind.5 keeps still low Sad
I used before atmega168 and this code worked well Sad
Has anybody an idea?
Cheers
PostPosted: Fri Jun 27, 2014 6:47 pm    Post subject: Reply with quote
hello,
Are you sure your fuse bits are the same setting ?
JP
Visovian
PostPosted: Sat Jun 28, 2014 5:52 am    Post subject: Reply with quote
Bascom 2075 demo
For mega328 this Config sets uncorrect values:
TCCR0A = 0
TCCR0B = 1
Try to set manually
'Config Timer0 = Pwm , Prescale = 1 , Compare B Pwm = Clear Up
Tccr0a = &H21
Tccr0b = 1
'Enable Timer0  'do not do this
'Start Timer0
pwm0b = 128
boeseturbo
PostPosted: Sat Jun 28, 2014 1:46 pm    Post subject: Reply with quote
thank you very much . will try it on monday and will report .
cheers
boeseturbo
PostPosted: Mon Jun 30, 2014 7:57 am    Post subject: Reply with quote
just tested it... it works... Thank you for your help!
Cheers
