Function generator Attiny13
Debu
PostPosted: Sun Jun 01, 2014 11:01 am    Post subject: Function generator Attiny13 Reply with quote
Every one
I am trying to make a frequency generator with tiny13.
Now I can generate 9KHz to 520KHz by timer0 CTC mode.
Here is my question is it possible to generate 4MHz or 2MHz ?????
Here is my Code
$regfile = "attiny13.dat"
$crystal = 9600000
$hwstack = 16
$swstack = 16
$framesize = 16
dim friq_com as  Byte
dim adc_value as  Word
dim div_1 as  Byte
'Config Portb = Output
Config Timer0 = Timer , Prescale = 1 , Clear_timer = 1 , Compare_a = Toggle
CONFIG ADC = single, PRESCALER = AUTO, REFERENCE = INTERNAL
 Compare0a = friq_com
  Toggle Portb.3
  Waitms 10
  adc_value = getadc(2)
  friq_com=adc_value/4
(BASCOM-AVR version : 2.0.7.6 , Latest : 2.0.7.7 )
View user's profile AIM Address Yahoo Messenger MSN Messenger
JC
PostPosted: Sun Jun 01, 2014 5:52 pm    Post subject: Reply with quote
I assume you have an External Crystal attached to your micro?
Have you changed the Fuses to switch the micro's clock source to use the External Crystal?
If not, the micro is still running on its internal RC oscillator, (at 1 MHz, or whatever the data sheet says it is).
Be careful in changing the Fuses.
An external crystal is a two lead device, and uses two external capacitors.
This is probably what you have.
An external oscillator is a small module, with its own V+ and Ground pins, and it outputs a square wave. This is probably NOT what you have.
JC
Debu
PostPosted: Sun Jun 01, 2014 6:47 pm    Post subject: Reply with quote
Thank you
JC
for your replay.
I don't connect external x-tal.
I use internal 9.6MHz rc by fuse H(FF) L(6A).
I think it have another way to generate high frequency by config Timer0.
Thanks again.
for_ro
PostPosted: Sun Jun 01, 2014 7:38 pm    Post subject: Re: Function generator Attiny13 Reply with quote
Hi Debu,
this will not do what you want, as friq_com will only get values from 0 .. 63
This would do:
adc_value = getadc(2) / 4
friq_com=adc_value
With COMPARE0A = 0 you will get a frequency of _XTAL/2, whatever _XTAL the µc is really running on.
Visovian
PostPosted: Mon Jun 02, 2014 7:29 am    Post subject: Reply with quote
With CTC you can get only frequencies
$crystal / 2
$crystal / 4
$crystal / 6
$crystal / 8
and so on
PostPosted: Mon Jun 02, 2014 8:31 am    Post subject: Reply with quote
$crystal / 2
$crystal / 4
$crystal / 6
$crystal / 8
and so on
Using OSCCAL you get some of the in-betweens. No guarantee of course, as this is heavily detuning of the internal RC out of specs.
But for hobby-use - who cares? Very Happy
Debu
PostPosted: Mon Jun 02, 2014 9:30 am    Post subject: Re: Function generator Attiny13 Reply with quote
Hi Debu,
This would do:
friq_com=adc_value
Thank you
FOR_RO
for your replay
Now I get to 2.33KHz to 592.24KHz
Debu
PostPosted: Mon Jun 02, 2014 10:59 am    Post subject: Reply with quote
Hurray
Laughing
Thanks to all
Now it is run 18.5KHz to 4.76MHz by fuse sating CKDIV8.
But, suddenly it jump 800KHz to 1.20MHz to 2.42MHz to 4.80MHz.
18KHz to 800KHz work linearly.
Workable but not perfect yet.
