xmega frequency meter with 32bit counter
Debu
PostPosted: Thu May 29, 2014 11:57 am    Post subject: xmega frequency meter with 32bit counter Reply with quote
All
I'm trying to make a frequency meter with xmega32a4 here is the code.
I only put 1KHz square wave to PORTC.0. Display show 32976.
I want to count pulse in every second.
I connect 32.768KHz Cristal with TOSC1&2.
I want measure at list 16MHz with more accuracy & less error.
No multiply coz error will be multiply also no capture pulse width.
In this system I want to make "Start TC>1Hz RTC interrupt> Stop TC> Read 32bit > Reset TC> start next count".
Or every interrupt read value CCA&CCB>Restart count> add two 16bit> Display.
A block diagram in attach file. don't know it is right or wrong.
My problem is in code. I get wrong result in LCD display(32976Hz).
Please help !!!!!!!!
Sorry for my bad English.
$regfile = "Xm32A4def.dat"
$crystal = 32000000
$hwstack = 84
$swstack = 80
$framesize = 80
Dim A As Long
Dim Dig As Bit,update_display as  Bit
Dig = 0
Dim Dig_1 As Bit
Dig_1 = 0
Dim Result_1 As Single , Result_2 As Single
'Config Osc = Enabled , 32mhzosc = Enabled
'Config Sysclock = 32mhz
'Config LCD 4-Bit Mode 3.3 Volt and R/W --> GND
Config Lcdpin = Pin , Db4 = Porta.3 , Db5 = Porta.2 , Db6 = Porta.1 , Db7 = Porta.0 , E = Porta.4 , Rs = Porta.5
Config Lcd = 16x2 , Chipset = Dogm162v3
'Config PIN as input, PORTC.0 as input for capture
Config Xpin = Portc.0 , Invertio = Enabled , Slewrate = Disabled , Outpull = Buskeeper , Sense = Rising
'Config EVENT
Config Event_system = Dummy , _
Mux0 = Portc.0 , _
Mux1 = Rtc_cmp , _
Mux2 = Tcc0_ovf , _
Mux3 = Tcc0_ccb
Config Clock = Soft , GOSUB = SECTIC,Rtc = 1KHZ_INT32KHZ_ULP '{rcosc}  Select the internal 1 KHz clock from the 32KHz internal oscillator ULP
Config Priority = Static , Vector = Application , Lo = Enabled       ' the RTC uses LO priority interrupts
Config Tcc0 = Normal , Prescale = 1 , Comparea = Enabled , Compareb = Enabled , Comparec = Enabled , Compared = Enabled , Event_source = E0 , Event_action = Freq
Config Tcc1 = Normal , Prescale = 1 , Comparea = Enabled , Compareb = Enabled , Comparec = Enabled , Compared = Enabled , Event_source = E2 , Event_action = Freq
Config Portc = Input
Cursor Off, NoBlink
Locate 1 , 1 : Lcd "TIMRE TEST#2a EX"
Locate 2 , 1 : Lcd "TEST  COUNTER#2a"
'----------------------------------Main---------------------------------------------
If update_display = 1 Then
Toggle Dig                     'for program run check
'for add need shift Result_2
Result= Result_1+ Result_2          (32976????)
Locate 1 , 1 : Lcd "F=" ; result ; " Hz    "
Locate 1 , 1 : Lcd "F=" ; Tcc0_ccabuf ; " Hz  LSB"
Locate 2 , 1 : Lcd Tcc1_ccbbuf ; Result_1 ; " MSB  "
Locate 2 , 13 : Lcd Dig ; RTC_INTCTRL ; Dig_1
update_display=0
End                                                         'end program
SECTIC:
update_display=1
Result_1= Tcc0_ccabuf
Result_2= Tcc0_ccbbuf
Toggle Dig_1          'for program run check
Tcc0_ccabuf = 0       'Clear the Tcc0_ccabuf Or reset timer0
Tcc0_ccbbuf = 0
return
'------------------------------------------END--------------------------------
(BASCOM-AVR version : 2.0.7.6 , Latest : 2.0.7.7 )
Please login to see attach file
View user's profile AIM Address Yahoo Messenger MSN Messenger
PostPosted: Sat May 31, 2014 10:51 am    Post subject: Reply with quote
just some tips, of an old man!
1) Never let too much code in a interruption, you could loss some informations, let a flag :
dim flag as byte
flag=0
Sectic:
flag=1
return
and in the main code:
if flag=1 then
'your action
flag=0
endif
2) dim a bit is not necessary, Byte is easier to use : your ÁP work with word of 1 byte, it compare word of 8bits to find a bit inside a room place (a byte) it need more time
3) for your variable forget name as "dim A as byte" , when you debug you could search A and then the editor will stop for each A, prefer : dim Abyte as byte, Aword as word, Ainteger as integer
and enjoy Bascom
JP Wink
Debu
PostPosted: Sat May 31, 2014 12:54 pm    Post subject: Reply with quote
Thank you !!!!!
for your advice.
I change the code in interrupt but result is same.
Also change bit to byte but when I write toggle then that variable toggle 1 to 255.
That is not important I write those for check program run or not. I can erase those.
but I can't get the result yet.
I think something wrong in config but I can't find that.
SECTIC:
update_display=1
return
Debu
PostPosted: Mon Jun 02, 2014 12:23 pm    Post subject: Reply with quote
When I put low frequency the display value is high also
when I increase frequency the display shown low value.
So it is actually measure the pulse width, I want count the number of pulse.
Have you any idea ????????
Debu
PostPosted: Wed Jun 18, 2014 11:02 am    Post subject: Reply with quote
closer to success
Now I put 1KHz from external RTC but display show F= 1006 Hz.
Here the system count extra 6 Hz.
If I change clock source for internal {rtc Rtc = 1khz_int32khz_rcosc} to {Rtc = 1khz_int32khz_ulp} then frequency show F= 995 Hz.
For this error when I put 4 MHz the system show F= 4024000Hz Same error in ULP
$crystal = 32000000
$hwstack = 84
$swstack = 80
$framesize = 80
Dim Dig As Byte , Update_display As Byte
Dig = 0
Dim Dig_1 As Byte
Dig_1 = 0
Dim Result_1 As Single , Result_2 As Single , Result_f As Single
Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled , Startup = 32khz
'Config EVENT
Mux0 = Portc.0 , _
Mux1 = Rtc_ovf , _
Mux2 = Tcc0_ovf , _
Mux3 = Tcc0_ccb
Config Portc.0 = Input
                              '1khz_int32khz_ulp,1KHZ_32KHZ_CRYSTOSC ,1KHZ_INT32KHZ_RCOSC,32KHZ_32KHZ_CRYSTOSC
Config Clock = Soft , Gosub = Sectic , Rtc = 1khz_int32khz_rcosc       '{rcosc}  Select the internal 1 KHz clock from the 32KHz internal oscillator ULP
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled       ' the RTC uses LO priority interrupts
'rtc_ctrl=&b011
Config Tcc0 = Normal , Prescale = E0 ,  Event_source = E0 , Event_action = Capture
Config Tcc1 = Normal , Prescale = E2 , Event_source = E2 , Event_action = Freq
'Tcc0_per = 50
Cursor Off, NoBlink
Locate 1 , 1 : Lcd "TIMRE TEST#3b EX"
Locate 2 , 1 : Lcd "TEST  COUNTER#4a"
'--------------------------Main-----------------------------------------------------
   Shift Result_2 , Left , 16
   Result_f = Result_2 + Result_1
   Locate 1 , 1 : Lcd "F=" ; Result_f ; "Hz       "
   Locate 2 , 1 : Lcd Result_2 ; "+" ; Result_1             'for show Tcc0_cnt and Tcc1_cnt vallue
   Update_display = 0
    Incr Dig
    If Dig > 8 Then Dig = 0
Locate 2 , 16 : Lcd Dig
End                                                         'end program
'------------------------------ 1 Sec INT-------------------------------------------
SECTIC:
Update_display = 1
  Result_1 = Tcc0_cnt
  Result_2 = Tcc1_cnt
   Tcc0_cnt = 0
   Tcc1_cnt = 0
return
