BootLoader with NM7010
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
WXYZ
PostPosted: Sun Apr 07, 2013 3:43 pm    Post subject: BootLoader with NM7010 Reply with quote
Welcome.
I have a question about NM7010A Wiznet module. I have several of them and I wanted to do (based on them) LAN BootLoader. However, the statement
TCPIP Config in the BootLoader section of ATmega644P does not execute. Perhaps because it is necessary to start interrupts (INT0 or INT1). I know that in the help file in the $Loader is clearly written that the BootLoader can not use interrupts, but only because the upload will overwrite interrupt vector on the begining of flash. However, an interrupt vector can be loaded to BootLoader section (which I did by putting the specified bit in a register MCUCR). But it still do not work. Please Mark for help me and explain.I use Bascom 2.0.7.6
Best regards.
PostPosted: Fri Apr 26, 2013 10:16 pm    Post subject: Reply with quote
in the next release i added $bootvector which will include the vector table. it will require more space. and you need to set the IVSEL bit yourself before using the interrupts. And : your normal program should reset the bit.
WXYZ
PostPosted: Sat Apr 27, 2013 3:31 pm    Post subject: LAN BootLoader Reply with quote
Welcome.
Thank you for your reply. As I have several of these modules (NM7010) and ready the device cooperating with them. BootLoader have been captured on the module WIZ810MJ but the possibility of software upgrade via LAN using NM7010A is very useful to me. And the question. When you plan the next version (not yet had time to register my copy of Bascom)?
Regards
WXYZ
PostPosted: Thu May 15, 2014 3:51 pm    Post subject: Bootloader works Reply with quote
Thank You Mark for $bootvector and Config Intvectorselection in Bascom 2077 release. Now I can use NM7010 module in BootLoader area. Some minutes ago I checked it and ping command worked. http://www.mcselec.com/components/com_forum//images/smiles/icon_biggrin.gif Thank You once more.
Regards.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
