remix
Posted: Mon May 12, 2014 9:29 pm Post subject: problem with send single variable to spi bus |
hi
i want send a single data to spi bus
but slave cant read from master
this code working with long ,int,byte,word but just not working in single
please help me
MASTER CODE:
$regfile = "m32def.dat"
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
Config Lcd = 20 * 4
Config Lcdpin = Pin , Rs = Portc.0 , E = Portc.1 , Db4 = Portc.2 , Db5 = _
Portc.3 , Db6 = Portc.4 , Db7 = Portc.5
Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = Yes , Polarity = High , Phase = 0 , Clockrate = 128
Config Single = Scientific , Digits = 5
Dim B As Byte
Dim A(10) As Single
Spiinit
A(1) = 111.22
B = 5
Spiout A(1) , B
SLAVE CODE :
$baud = 19200
$hwstack = 32
$swstack = 10
$framesize = 40
Config Lcd = 20 * 4
Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = No , Polarity = High , Phase = 0 , Clockrate = 128
Dim B As Byte
Dim A(10) As Single
Spiinit
B = 5
Spiin A(1) , B
Locate 1 , 1
Lcd A(1)
Posted: Tue May 13, 2014 7:48 am Post subject: Re: problem with send single variable to spi bus |
remix wrote: |
A(1) = 111.22
B = 5
Spiout A(1) , B
You shift out 5 bytes, but a single is 4 bytes long. _________________ www.evertdekker.com Bascom code vault |
remix
Posted: Tue May 13, 2014 8:24 pm Post subject: |
Read this http://wiki.mcselec.com/bavr/CONFIG_SINGLE
Maybe You dont need this in the master uC. Try send without this option.
Also You can convert it to String or if you have eg. 2 digits after decimal point multiply this by 100 and after all calculations /100..
..and look in samples for spi and spi-slave - I see some diferents in config but if this work on Word and Long maybe this is nomather
Dim A(10) As Single
Dim Help as Long ' or something that contain your single*100
A(1) = 111.22
A(1) = 111.22 * 100
Help = A(1)
Spiout Help...
Posted: Wed May 14, 2014 9:23 am Post subject: |
first, show us your code that works with longs. _________________ Mark |
kmswong
Posted: Fri May 23, 2014 4:01 pm Post subject: |
Example in help!
Dim A(10) As Byte
Config Spi = Soft , Din =Pinb.0 , Dout =Portb.1 , Ss =Portb.2 , Clock =Portb.3
Spiinit
Spiout A(1), 4 'write 4 bytes a(1), a(2) , a(3) and a(4)
End |
