Posted: Wed May 07, 2014 2:44 pm Post subject: Find file using Dir(*.*) and Dir() Bascom AVR Version 2.0.7.
Hi all,
I have a simple sub that searches a directory and gives error if the file is not found.
Makes no sense to me why this does not work.
Here is the code.
Dim File_error As Bit 'Flag to reset if file is found
Dim Myfile As String * 12 'File I want to find
Dim Mydirectory As String * 12 'Directory I want to search
Config Submode = New
Sub Findfile(byref Filetofind As String , Byval Directory As String * 12)
Local File_read As String * 12
Chdir "\" 'Be sure we start at root
Chdir Directory 'Move to new directory
Set File_error 'Set fault flag before we begin
Print #1 , "File to find= " ; Filetofind
Fileread = Dir( "*.*") 'Get 1st file name in directory
While File_read <> "" 'loop until my file is found or end of directory
Print #1 , "Dir file= " ; File_read 'For disgnostics to see files being checked
If File_read = Filetofind Then 'If the present file name matches the search reset file_err flag and exit
Reset File_error
Exit While
File_read = Dir() 'get the next file name
Wend
The file is there and it get's printed but the check does not reset the file_error flag.
Here is what get's printed when the file is run.
File to find=ENGCFG1.mnu
Dir file= GERCFG2.MNU
Dir file= ITACFG1.MNU
Dir file= ITACFG1.SEL
Dir file= ITACFG2.MNU
Dir file= POLCFG1.MNU
Dir file= POLCFG1.SEL
Dir file= POLCFG2.MNU
Dir file= PORCFG1.MNU
Dir file= PORCFG1.SEL
Dir file= PORCFG2.MNU
Dir file= SPACFG1.MNU
Dir file= SPACFG1.SEL
Dir file= SPACFG2.MNU
Dir file= ENGCFG1.MNU 'This is the file I'm looking for
Dir file= ENGCFG1.SEL
Dir file= ENGCFG2.MNU
Dir file= FRECFG1.MNU
Dir file= FRECFG1.SEL
Dir file= FRECFG2.MNU
Dir file= GERCFG1.MNU
Dir file= GERCFG1.SEL
File_error= 1
Any idea what I'm doing wrong?
Maybe there is another simple way to do this?
Thanks,
Jerry
